Question about Refrigerators
How to fix a leaky refrigerator - Refrigerators
    New Friend:
    Problem Solver:
  • 5 Answers
Refrigerator patch kit. They got them at Walmart in the bicycle tire tubes aisle and sometimes oddly enough near the sewing goods and crafts aisle...Get 2 kits though as the first time using it is a bit wonky. Glad to help you, you'll get er...
Posted on Jul 15, 2019
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 19 Answers
If leaking from the back and outside of the box, you need to tighten the water line. If it is leaking water from inside the box , bottom front then you need to defrost the fridge and after you defrosted check that the fan or fans are operating when it's on and no more ice is left.
SOURCE:
How do i know which valve is used for the icemaker feed when the feed tube freezes up?
You simply have to replace the dual valve assembly you cannot fix it it's like a leaky faucet that cannot be fixed. what is the model number of your refrigerator?
Appliance 911 Sea Breeze
Sep 25, 2015 | Refrigerators
How can I fix my fridgidaire refrigerator model #frs26h58sb4 leaky water dispenser.
Good Morning Friend,
I understand you are trying to repair the leaky water dispenser on your Frigidaire refrigerator, model# FRS26H58SB4. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals for this repair. I suggest contacting your local authorized technician for further assistance. I hope this is helpful.
-Best Regards-
WP
Jun 21, 2014 | Frigidaire Refrigerators
Good Morning Scott,
-Best Regards-
WP
How to fix a leaking water dispenser?
remove the service panel, look for a loose or leaky hose. hose is inexpensive and easy to replace. if its coming from the cylinder and is cracked or split, it will need to be replaced. many companys will give you a 1 year contract of buying there water they deliver and you get a free water cooler.
Apr 23, 2014 | Kenmore Side by Side Refrigerator
My fridge is freezing everything I have the control board replaced and it didn't fix it what is causing the fridge to freeze
an overworked motor is normally the problem.
could also be a faulty thermostat.or even a leaky door seal.try the cheapest solution first.....
Jun 18, 2010 | Frigidaire FRS26H5AS Side by Side...
Leaky water dispenser. How to fix
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Dec 15, 2009 | Amana Refrigerators
I have a leaky spigot what can I do
If the spigot means the end of the water tube in the water dispenser, and it steadily drips even if the dispenser is not used for 10 minutes or so - replace the water valve. If the dispenser drips water mostly wright after you used it - you might have some air bubbles in the refrigerator water tubing.
Oct 17, 2009 | GALAXY Microsystems 25.4 cu. ft....
I have an LG french door fridge and its water flow is very slow from the water dispenser. Can someone please help me fix this problem.
it indicates the problem of a leaky water tube or a jammed ice chute,check it. most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs. please do not forget to rate the solution.thanks
Jun 12, 2009 | LG LRFD25850 French Door Refrigerator
Slow Ice maker
How much ice does it make per day?
There are several things that affect ice making capability, such as -
1) How often the doors are opened
2) Leaky door gaskets
3) Bad ice mold thermostat
4) Light in refrigerator does not go off when doors are closed (easy to test).
Jan 23, 2009 | Frigidaire FRT21H8 Top Freezer...
Refrigerators Logo
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
