Question about Radio Communications
Problems with electronic equipment that exhibits a fault after being switched on for some time can often be traced to a thermal fault. Most usually part of the circuit exhibits high resistance due to a microscopic gap opening up in a component or a defective soldered joint. If removing the jack plug and replacing it clears the fault for a while this suggests that one of the terminals of the socket may be badly soldered. This can sometimes be identified by visual inspection of the joints. Look for a soldered connection which appears as a bead of solder apparently not wetting the circuit track or the pin. If not obvious suggest you carefully resolder all the joints to the jack socket. To get a good joint you may have to clean up areas around existing joints so that the solder wets the metal. Take care not to overheat any surrounding components.
Posted on Aug 28, 2009
Aug 17, 2011 | Audio Players & Recorders
May 31, 2011 | Sony Playstation 3 (PS3) Console
Feb 26, 2011 | Tascam Audio Players & Recorders
Aug 11, 2010 | Pioneer CDJ-1000 CD Player
Mar 31, 2017 | 2001 Chevrolet Venture
Jan 25, 2009 | Samsung WEP180 Wireless Headset
Nov 21, 2007 | Lexmark Wheelwriter 1000 Typewriter
Mar 04, 2007 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Feb 28, 2007 | RCA P46924 46" Rear Projection Television
Feb 26, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
62 people viewed this question
