Philips DVP3962 DVD Player
Problem for Philips DVP3962 DVD Player
Dvd player always says no disc
By shaunbroadna on Aug 28, 2009
dvd player always says no disc . will not load
Best Solution
posted on Aug 28, 2009
Very Helpful)
ginko
Rank: Guru  Philips Televisions & Videos  Expert
Rating: 89%, 5066 votes
That happens because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only few CD, DVD. After more prolonged usage , often the unit will start losing the rest of functions, and ends up not reading anything at all.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD cleaner disk to clean the lens. If that does not work you will need to disassemble the player, and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Oct 13, 2009
Not Rated)
bbobby301
Rank: Apprentice  Televisions & Videos  Expert
Rating: 0%, 0 votes
Dvd player always says no discDVP3962 DVD Player
Was this helpful?
Yes
No
Popular Solutions for Philips DVP3962 DVD Player
Questions and Unsolved Problems for Philips DVP3962 DVD Player
Do you recommend Philips DVP3962 DVD Player?
Answer
Answer
the colors are wrong on the screen. everything is orange and green and pink. just started after 6... (More)
Answer
came with no remote. need to know how to program it to a rca scenium
Answer
a black and white dvd now plays in bright green and pink and the picture is hardly recognizable. The... (More)
Answer
dvd pauses in the middle and plays automatically. cant control this. for all dvds... which played... (More)
Answer
The DVD window says no. The tv says no disc. The unit is three years old & has been used... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Philips DVP3962 DVD Player:
Top DVD Player Experts
Rank: Guru Guru
Solutions: 769
Experience: 30 Years of professional repair and design.
Ask Me
Find more DVD Player Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
