Question about Zenith D52WLCD 52" Rear Projection HDTV-Ready Television
Get a weird zapping noise
My tv will not turn on, when i push the power button you can hear a zapping noise like one of the pesky outdoor bug zappers. What should I do?
    President:
  • 4,402 Answers
Sounds like theres a short, most likely the flyback transformer
take in for service
Posted on Dec 05, 2007
Should my 1.5 acre stinger bug zapper zap when I plug it up
Intuitively, I glean it zaps when you turn it on only if you are a bug. Zapping is caused by the bug encountering the zapper. Otherwise, it would zap you even if you were not a big bug, simply because you were in close proximity.
Aug 20, 2017 | Air Purifiers
Why is my bug zapper not zapping bugs?
no high voltage being produced
have it checked out or buy a new one
May 24, 2016 | Air Purifiers
Did Bernie Sanders ever collect welfare or food stamps
sounds like it, but honestly who cares?
Bernie Sanders Has Secret
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gregg_27a4d257e54e7920
Mar 04, 2016 | Tools & Hardware - Others
I have a flowtron bk-2125 bug zapper, looking at the troubleshooting, it said check for power on the grid, how do i do that. I changed bulb and it is not coming on, it said if i have power then the starter...
If you have no power from the grid then bug zapper is not problem. If bug zapper is a corded plug in application then unplug and plug into a plug in that you know works. Check your breaker panel for a tripped breaker and reset if necessary. Or try a different appliance by plugging something that you know is operational into the same plug. If it works, there is likely an internal problem in bug zapper.
Oct 08, 2014 | Cars & Trucks
Lennox air purifier zapping sound
This may be an electronic style air filter which causes a bug zapper noise when "zapping" dust. I was out doing some research myself on them which is how I came upon your question. It seems they need to be cleaned carefully; which I am seeking instructions for. Best of luck in your ventures! Do some research, they are expensive to repair if you break them in the process of trying to clean or remove them. This page did a decent job at explaining the why it zaps part. http://dhclimatecontrol.com/filter.htm
Jun 19, 2012 | Heating & Cooling
Why is my Oreck XL is my air purifier arcing?
If it was just clean recently, it's probably picking up dust particles and that's what you hear or see arching, like a bug zapper.And conversely, if it has been cleaned recently, dust particles on the filter are breaking off and getting zapped. In which case, you need to clean the filter.
Thanks for choosing FixYa.
Aug 25, 2011 | Oreck XL Professional Air Purifier
I recently bought a chefmate racket bug zapper from target, but can't seem to get it going. I pressed the buttons over and over so it would make it's high pitch sound and then i would know it was...
If this is a grid type of item then something has to be touching the grid to complete the zapping circuit. What you have is basically a direct current device that has a positive charge on one grid and a negative charge on the other and only if something touches both grids will it actually zap anything. Merely pressing the button only charges the grids and does not cause arcing of electricity between them. If you want to test it find a dead bug and drop it onto the grid while pressing the button - then shake it sideways so the insect touches both sides and you will see it works.
Nov 19, 2017 | Vacuums
51MP392H/17 Makes Zapping sound on power up. No picture or sound. Has been reset/unplugged. When powering up makes a sound like a bug zapper for about 1/2 second. Power light stays on and I can hear the tv...
The Zapping sound you are referring to is most likely due to arcing of the flyback(high voltage transformer). It is strongly recommended that you do not turn on the tv and have a tech test the flyback and replace it. The FBT generates voltages of about 30000V and should not be handled by someone who has not worked on high voltage electronics before.
Feb 09, 2011 | Philips Magnavox 51MP392H Rear Projection...
Makes a zapping noise when you turn on the electronic air cleaner
If the the "zapping" noise you hear is intermitant (like a Bug Zapper) it's probably dust that the air cleaner is picking up from the household air. .If that's the case, there's nothing to worry about, it's doing it's job.
If the "zapping" sound is continuous, then the unit may need cleaning, as it may be clogged with dust & lint.
Feb 08, 2011 | Air Purifiers
Microwave doesn't heat
check your door safety interlock switches ...
switch burned = no circuit
no circuit = door open (as far as the oven is concerned)
door open = no magnatron action
no magnatron action = no heat
Of course it could be something else ... but if it is the switch, you can easy fix that.
Oct 09, 2009 | Hotpoint RVM1435 Microwave Oven
Zenith D52WLCD 52" Rear Projection HDTV-Ready Television Logo
109 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
