Epson Perfection 4490 Office Flatbed Scanner Logo
Posted on Aug 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Scanning 35mm negs on my Epson Stylus PHOTO RX620
When scanning negs on my RX620, one side of the neg is scanned ok but half of the picture is blank. Any Ideas, anyone, please?
Anonymous
Level 2:
Novelist:
  • Expert 136 Answers
  • Posted on Sep 03, 2009
Anonymous
Expert
Level 2:
Novelist:
Answers
136
Questions
0
Helped
53868
Points
330
Try using a slightly off-white background sheet behind the negative (glass-negative-sheet-scanner lid) first, or a "frame" around the negative that is anything but white... some scanners have an auto-detect feature that may be skewed for one reason or another.
Another trick, from a photographer friend, is to take saran wrap or another transparent but non-reflective material and place as a filter between the negative and glass, thus reducing glare. The sharpness may be lessened, but the glare is also lessened...
Hope this helps!
-- RT
2answers
2answers
Epson V300 Photo Scanner Streak When Scanning Negative
I also own a v300, and I have noticed that I occasionally get rainbow streaks if I bump the scanner at all while it is scanning negatives, so this might have something to do with vibrations in the machine. Is it sitting on a stable surface?
My allin one printer wouldnt scan
our epson stylus photo 700 has new cartridges.have cleaned the heads,but it is not printing-blank pages.Why?
I have a 3490 scanner but have lost the neg holder to scan negs.
You really cannot scan a neg without a special holder. I recommend paying $90 to Costco and buying their special USB Scanner which scans one neg at atime! They are great!
Thanks,
Mark
Cd-rom installtion lost
You can download the printer driver from this link. There are a list of downloads on that page. Scroll down to Printer Driver 5.5aa and download the file. This is the printer driver. Also, download the Twain Driver and Scan Utility v2.65 for the scanning drivers.
Hope this helps,
Thanks for using Fixya
Lolita
Scanning slides -
Do try reinstalling the fotware this is where the trouble lies.
Or
Save the scans and in a suitable photo Editor revers the image Neg to Pos
3helpful
Epson perfection 4990 photo scanner
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
For scanning transparencies in HOME mode - for EPSON SCAN models, not Epson Twain/Manual mode models.
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan. For example, the DOCUMENT TYPE for transparencies must be either "Color negative film", "B&W Negative Film" or "Positive film"*.
* FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes.)
If the DOCUMENT SOURCE is set for a flatbed related option, ie PHOTO, the scanner is looking for reflective items and will not activate the backlight in the transparency unit. If the DOCUMENT TYPES for "FILM" are greyed out or cannot be selected, close the Epson Scan, reseat the power/communication cable connecting the base of the scanner to the transparency unit, then reopen Epson Scan and try again.
NOTE for PROFESSIONAL MODE users: DOCUMENT TYPE should read TRANSPARENCY for film scans.
4) Ensure the other scanner settings are correct for the type of scan you are doing. For example:
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no means to calculate what your exact needs will be in this situation; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing a THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
