Question about Motorola Mobility RAZR V3xx Cellular Phone
Motorolal razr phone AT&T
The front panel display screen is very pale . Adjusting brightness does not help.
Any idea as to what would fix this. This is a new phone.
  • 1 more comment
  • sta5 Dec 18, 2007
    front display is not bright enough.
  • Nunu12343 Apr 12, 2008
    Help fix my screen
  • Anonymous May 03, 2008
    The front and inside screan are black and wont work and battery is fine
The both the inside and outside screens
are blank?
what do i do cause i NEED my phone!
Posted on Jan 06, 2008
My phone always freezing and cutting off by itself and its charged up
Posted on Mar 16, 2008
My Samsung S7 Edge has a green bar, for lack of a better description comma that goes across the screen and it gets bigger and I can't see my screen at all
Settings > Display > Screen Mode > Adaptive Display or AMOLED Cinema
Also try adjusting your phones brightness to 100% and turn off the auto brightness adjustment to test it out
May 24, 2017 | Samsung Cell Phones
What is the OPC light?
OPC_ Optical Picture Control
Automatically adjust the brightness of the screen.
You can change the settings in the menu option.
It's in Menu, then picture, then OPC.
OFF- The brightness is fixed at the value set in "Backlight"
ON- Automatically adjusts
ON: DISPLAY- Displays the OPC effect on the screen while adjusting the brightness of the screen.
If you don't want the silly display from popping up all the time, go into to menu and change the setting to ON; instead of ON: DISPLAY
Feb 04, 2016 | Sharp Aquos Televison & Video
C2525e touch panel not working
Run a business card between the touch screen and the outside surround. Dirt or dust can make the screen believe that you are constantly touching the screen which will lock up the touchscreen. Try adjusting the screen brightness by adjusting the thumbwheel located at the far top of the display panel.
If this does not rectify the fault then the touchscreen will need to be replaced.
Mar 08, 2014 | Kyocera Color Copier, Km-c2525e
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
Brightness and contrast symbols
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 | HP...
My screen is pale and when i press parts of the phone it turns back to the right resolution but it wont do that anymore.
It seems the phone fell from you or you hit the phone surface with a hard surface for your screen to be malfunctioning because it is possible that the screen is not firmed to the panel any longer and you will need to affirm it.
Get a torx6 screw driver.
First thing you need to do is to power off your, remove the baattery, and sim card, Turn the phone over and gently remove the front cover.
After you have pull off the front cover, you can go on with the torx6 screw driver to tighten all the screws that hold the screen of your phone to its panel very well and recouple the front cover back.
Put your sim card and battery to power on, with this it should stop the pale screen.
Take care.
Apr 30, 2010 | Cell Phones
What is "OPC"? It comes up and goes away.
Apr 20, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Front screen not displaying anything
I would go back to where you replaced the front screen and let them know that they did not fix the problem. Let me know what happens. No easy way to fix.
Cynthia
Nov 05, 2007 | Motorola Mobility RAZR V3
Motorola razr display
I can understand this trouble, So You pliz visit service centre of motorola, ur handset is in warranty period, they will repaire it for u.
Oct 23, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3xx Cellular Phone Logo
77 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
