Fax machine brother 885mc
Copys and faxs have vertical line in them
  • Anonymous Feb 05, 2009
    Yes, I have the same problem. I took everything apart and clean the scanner tube also but still getting the thick line on left side of the paper. I only get when sending fax or make copies. !! When I try to print report from the fax machine I dont get this thick line.??
  • 64 Answers
What type of line is it?
White Line: clean the glass above the scanner unit. a common problem with this is that tip-ex dries on it when not letting the tipex dry fully before sending/copying
Black Line: This could be a number of thisg: Cartridge, Fuser, Dirt on the laser unit. If you have a spare cartridge lying around even if its near empty try that and see if you get the same problem. If its still showing a line then i suggest using a can of compressed air to clean the inside. If a toner has leaked then sometimes it finds its way onto the lens of the laser unit.
Hope this helps
Pete
Pete@wedotoners.com
Posted on Dec 12, 2007
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
1- did you check the glass?
2- There is also a white metal plate opposite of the glass, if it has a black dot or is dirty it will give you black lines.
Posted on Dec 10, 2007
Vertical black lines wen sending brother fax -885mc
Pull open the front cover and clean the scanner glass.
Sep 09, 2009 | Brother EPPF-885MC Fax
Cannot receive faxes
the brother I/F 885MC ( MC stands for message center ) it has a built in answering machine.
to use the built in massage center you need to press the receive mode key till the display reeds
( MSG CTR) next to the time & date
the way the fax need's to be hooked up is from the wall jake to the line jake on your fax machine.
anything you need after that you go from the ext. jake to your ansering machine or extra phone.
if you don't have owners manual go to www.brother.com you can down load manual
hope this help
Feb 11, 2009 | Brother IntelliFAX 885MC Plain Paper...
Cannot receive fax on a Brother Intellifax 885MC
make sure your receive mode is set to "auto" or "fax only". if thats not it, you may have a phone line problem. i have seen that before.
hth,
razors
Jan 12, 2009 | Brother IntelliFAX 2800 Laser Fax
Black line through sent faxes
Open up the document feeder and clean the scanner glass.
Jan 05, 2009 | Brother IntelliFAX 885MC Plain Paper...
Can you use thermal transfer paper
The paper will probably come out black after being heated by the fuser. 350 degrees.
Jun 07, 2008 | Brother IntelliFAX 885MC Plain Paper...
How to use a brother fax- 645 plain paper fax
You may have been given a heap of junk. Happens all the time. Just place the document face down in the ADF and dial the number then press the green button to send.
Feb 27, 2008 | Brother IntelliFAX 885MC Plain Paper...
Number of rings
It should be under Menu, 2. Set up recieve, 1. Ring Delay.
You will have upto 10 rings.
Feb 19, 2008 | Brother IntelliFAX 885MC Plain Paper...
174 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
