Question about Ovens
Need part number for a kenmore range clock/timer replacement
Clock/timer replacement # for kenmore range model number 79075721990
  • Anonymous Mar 16, 2014
    I have a kenmore slide in range model # 911-46565, when I try to put on the clean cycle it just beeps and the door does not lock and then it reverts back to the clock display
    Problem Solver:
  • 11 Answers
Part #496225
need part number for a kenmore range clock/timer r - 94d88bc.jpg
Posted on Dec 05, 2007
  • Joy Campbell Apr 14, 2012
    I searched for that part (496225) but turned up a totally different product.
I have a Frigidaire Range model PLES389DCC, it's top cooking function well, but display panel PF show, the clock start from 12:00 (after off/on circuit breaker) and kicking. I have order the control panel...
The clock may be set for 12 or 24 hour time of day operation.
The clock has been preset at the factory for 12
hour operation. When the range is first plugged in or when
the power supply to the range has been interrupted, the
timer in the display will flash and PF (power failure) will
appear in the display.
To set the clock:
1. Press Clock . "CLO" will appear in the display.
2. Example for 1:30. Press the numbers 1 3 0 to
set the time of day to 1:30. "CLO" will disappear
after 4 seconds and the clock will start. Or you may
press Start. "CLO" will disappear and the clock will
start.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 29, 2010 | Frigidaire Ovens
Oven wont heat up, F-1 on timer
This indicates the ERC Electronic Range Control has failed. First check the key pad. Press each button one at a time. You should feel or hear a click and feel the retraction. If any button is not working the problem is likely in the key pad. If you locate the tech sheet ( somewhere on the stove, usually in the control panel) it may have a ohm check that can be done on the key pad to rule out the key pad. Here is a simple test that you can do to determine whether the clock or the touchpad are defective when the display reads F1:
- Disconnect power to the range.
- Gain access to the back of the ERC (electronic range control, or "clock").
- Unplug the touch pad ribbon connector from the ERC. This will be a flat wire about 1 ½" to 2" wide.
- Make sure everything is clear and will not short out when power is turned back on. Replace any covers removed to gain access to the ERC.
- Turn the power back on to the range.
- Watch for the F-1 and listen for the beep.
- If you get the F-1 and beep, replace the ERC.
- If after approximately 60 Minutes you do not get the F-1 fault, replace the touch pad.
NOTE: Some models incorporate the touch pad and the clock control as one part so F1 = bad clock control(ERC). If all seems good the control is at fault. Check to see if you have power going into the control. If you do and nothing is working the control board or ERC needs to be replaced. Here is a link for checking and replacing an oven control. If you need diagrams and illustrations of your specific model enter your model their. All parts come with installation instructions.
Oct 22, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Hi I have a Tappan oven model TGF357CCSF. The clock display andtemperature display is working but it is very dim. I have been told the I need a control panel 316028350 which is no longer available is this...
Hey - That part is available thru AppliancePartsPros online listing is clock/timer.  Part # AP2125110     $203.75   These timers are old-timers anymore. Can be hard to find, and at 200 bucks, make ya think twice. Gas model is probably worth it though.  Either way- it's an electronic clock that has had 120v running through it for 20 yrs or so. Time to replace for sure. Let me know if this info helps-  have more if needed-  Thanks--Ed
Mar 16, 2010 | Ovens
ELECTRIC OVEN THE RANGE WORKS BUT THE OVEN AND BROILER WILL NOT WORK
Without a proper model number I would say you need to replace the electronic clock/timer control. It could also be a relay power board in the back of the range if it has one. beast to call a reliable repair company such as sears.
Jan 31, 2010 | Magic Chef 9815 Electric Single Oven
My stove works but my oven wont, and the light of the oven wont turn off
Without a model number, my guess would be a stuck relay in the electronic clock/timer. Replace the Electronic clock/timer.
Jan 29, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
I have kenmore range model 790.78572407. Sometimes the timer goes off without being set and the 'clock' says F10. How can I fix this?
F10 means there is internal fault with the circuit control panel they will due that if theres a intermittent short!! in the system or a bad solder joint on the circuit board
Jan 19, 2010 | Ovens
Oven doesn't work, stove does
If it's a Whirlpool or Kenmore oven (or one of several other brands that are made by Whirlpool) then this error code means:
F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC)
The system believes that the control board has failed and needs to be replaced.
This page has a list of diagnostic codes by brand and model number. You should check there to look up your particular brand to confirm what I just said.
Aug 04, 2009 | Ovens
My kenmore electronic stove is having a beep with code F1 on the
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Manual needed for Range operation: Specifically timer reset
I found the work-around to be to decrement the timer to 0 as a means of canceling it, "unset it" if you will.
Dec 10, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore glass top
Your range was actually built by Whirlpool. the first 3 digits of the serial number determine who it was manufactured by.
It's possible that a battery somewhere is running low. This battery would be for the clock and timer.
See if you can find the service sticker and find the model nnumber - it would most likely be a couple of letters and some numbers. If you're from the US, you may be able to find a manual here: http://shared.whirlpoolcorp.com/product_literature/search.jsp
If you're from the UK, it'll be here:
http://www.whirlpool.co.uk/app.cnt/whr/en_GB/pageid/pgsrvifuhome001
Please let me know how you get on.
Jun 18, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
756 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
