1999 Ford Taurus Logo
Posted on Aug 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Replace a coolant reservior on a 1999 ford taurus
Ronnie Wilson
Level 3:
  • Master 1,596 Answers
  • Posted on Aug 28, 2009
Ronnie Wilson
Master
Level 3:
Answers
1596
Questions
Helped
881706
Points
5626
If you need Illistration I Can Email it to you Im at
rejakwilson @ aol.com
Removal
CAUTION: Do not mix Standard (green) Coolant with Extended Life Coolant (orange). If mixing occurs, drain engine cooling system and refill with originally equipped coolant type. If this contamination occurs, the service change interval on Extended Life Coolant will be reduced from 6 years/150,000 miles to 3 years/30,000 miles.
  1. Drain radiator until engine coolant is out of degas bottle. Disconnect radiator overflow hose and engine coolant vent hose at degas bottle.
  2. Remove power steering oil reservoir retaining screws and position power steering oil reservoir out of the way.
  3. Remove degas bottle return hose and clamp. Remove degas bottle retainers and remove degas bottle.
Installation
  1. Position degas bottle in vehicle and install retaining screw and nut. Tighten retaining bolt and nut to 9-12 Nm (80-106 inch lbs.)
  2. Connect degas bottle hose and clamp to degas bottle.
  3. Position power steering oil reservoir onto degas bottle and install retaining screws securely.
  4. Connect radiator overflow hose and engine coolant vent hose to degas bottle.
Leaking coolant on a 1999 Ford Taurus 3.0 DOHC
No Idea what is leaking until you tell us
2answers
1999 ford taurus is leaking coolant told heater hose manifold needs replacing for about $500.00
It's very possible it could be leaking and need replacing.
$500 is too much to pay for this repair.
I would get a second opinion and another cost estimate.
1helpful
4answers
My 2001 Ford Taurus keeps running too hot to safely drive. Whenever the car is started fluid immediately gushes out of the plastic resevior that you put the water/antifreeze leading to the radiator. I...
You have an air bubble at the top of the engine.
The antifreeze spewing out of the overflow happens due to your perfectly functional radiator cap
passing the overheated coolant/air mixture out of the system into the reservior (in an attempt
to relieve overpressurization of the cooling system)
The sudden nature of your overheating comes from the boiling of the inadequate amount of
coolant/antifreeze in your engine, since it cant properly cool the engine, so it boils (overheats quickly), and pressure rises immediately within the cooling system.
The Fix is free: locate and open the (air) bleeder port at the top of the engine, and add the usual
50% coolant/50% water mixture to the radiator until the radiator is full to the level indicated in
your owner's manual (or the "Full" line). Then close the bleeder port and replace the rad (radiator)
cap.
The air bleeder port is normally located near the thermostat, and should be opened each time
that coolant is added to the radiator. The air bleeder port need not be opened when adding
50/50 coolant to the reservior, since the rad cap is going to be closed while adding coolant
to this part of the cooling system.
Warning: driving beyond the point where your engine temperature gauge indicates overheating will
destroy the car's engine - it'll seize up due to overheating, and the only fix for a seized/burned-up
engine is replacement (of the engine). Seizing an engine is really easy with an air bubble in the
top of the engine - you could easily burn up/warp the head, necessitating replacement of the head
and head gask
et.
Had a coolant blowout on 1999 Ford taurus station wagon 3.0v aluminum head damage - what year engine range can i replace it with from another taurus with minimal effort?
if you talk to a machine shop they can tell you what year and model range you can interchange with or the wrecking yard can do this to as this motor is used in more than one model of car.
What type of coolant do I put in my 1999 Ford Taurus?
I see smoke coming from my car hood. My car is not losing coolant and overheating. Not real smell. any ideas.
1helpful
Can't find location of low radiator fluid warning sensor on 1999 Ford Taurus V-6 DOHC engine
Hello:
Usually on Ford automobiles, the low coolant sensor is built into the coolant overflow tank cap. If yours is this way, you can spot the wiring and electrical connector attached to the cap. The sensor looks like a dipstick in the coolant tank.
Hope this helps!
1999 Ford Taurus Coolant Light
Jackie, Hi, yes this would be the problem if the temperature sensor is not working it will not tell the fan too start, so best advice would be too change this sensor, or have someone do it for you and that should cure your problem, Colin.
I have a 1999 ford taurus with the 3.0 sohc we have replaced the thermostat and the pressure cap and it still keeps blowing out coolant what else could be wrong?
I assume its overheating.
Ensure motor doesn't have tuning or mechanical problems (such as blown head gasket).
Check radiator core is not blocked,
Check operation of cooling fans.
Check the coolant system is correctly filled - any airlocks cleared (by bleeding as may be required).
Check radiator hose on suction side of waterpump not (soft) collapsing when engine speed above idle,
2helpful
Cooling System Problems 1999 Ford Taurus
My friend had a 1999 taurus and had the same problem, his coolant would leak from around the overflow bottle because the system was backing up. His problem was a partially plugged radiator. I know this probably isnt the news you wanted to hear, but I'm pretty sure thats going to be your problem. sounds like you've replaced everthing else short of the radiator and water pump. Good thing is i remember him saying it was reasonalbly priced, so good luck.
3answers
Ford Taurus 1996, coolant comes out throughout the cap every time when car stops
You will overheat the engine if losing coolant.Firstly replace the cap with a new one,Is the engine temperature normal when you stop ? If its over temperature it will still blow out coolant. Check the radiator for blockage of the tubes & ensure the fan belts and water pump are in good order. Worst case is a blown head gasket can test for combustion gases in the coolant
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
