Question about HP DeskJet 5150 InkJet Printer
Printing problems When I print a document that contains a table the print output comes out with distorted lines onn the table
  • Anonymous Mar 24, 2009
    Had a paper jam. Removed paper, now whenever i print it seams that every centimetre, the print drops then raises on the next then drops again
    If i print a table, the table lines are up and down eavery centimeter
    tried all sorts to rectify this but cant
    any help appreciated
    Champion:
  • 238 Answers
Hi, whenever u replace any of the cartrgs in the printer ,u first need to run the alingment procodure from the maintenence option, even if u have not replaced the cartg, run the alingment from the printer properties first, and then u can get a proper output. let me know
Posted on Dec 16, 2007
WILL ONLY PRINT EVERY ALTERNATE LINE OF TEXT & TEXT BOX BORDERS
Doesn't sound like your printer hardware. Try printing something other than your text document. If the page comes out clean/perfect then it means your printer is having a problem understanding your text document via print program translation. Otherwise try converting your text to pdf and print a sample page, if it works then again problem with software/printer translation.
Nov 24, 2013 | Epson Stylus CX3810 All-In-One InkJet...
Erratic print with canon ip 4300 printer
The document should be formatted as a table with text inserted rather that a group of text boxes.
Nov 24, 2013 | Canon Office Equipment & Supplies
Distorted printing on i560 printer
Double-click print centre icon.
when it opens up, select I560, then click configure.
click I560 then click select
click the down arrow to select test print.
nozzle, alignment etc...
run the tests try resolve the problem.
Hope this helps
Regards
Apr 16, 2009 | Canon BubbleJet i560 InkJet Printer
Printer creating white lines that distort output
Hello loyasq,
You should do :
1st; Try to fix that by the device's Appliaction
smthing like that
2nd; Uninstall every application for this device and re-install it again.
3rd; If your printer have 1 Cartridge for all colors, Cleanse the part of ink output (the nozzle of ink cartridge) with wet tissue.
Thx for using FixYa.
Apr 15, 2009 | Dell Photo 964 All-In-One InkJet Printer
Kyocera fs-1030d wont print frames on MSWORD2000
wrong... the kyocera only prints what you send to it... you need to go into your print settings and make the adjustments so it can print frames borders/ shadings... this has been my experience with explorer and photoshop... not very much fun but necessary...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Mar 06, 2009 | Kyocera Mita FS-1030D Laser Printer
Unusual character where special character or underline is given
If you have a spare USB cable around the house, try that first and see if the cable was bad.
Aug 21, 2008 | HP DeskJet 640c InkJet Printer
Problem with printing document footer text on RICOH SP C811DN
Check the paper size settings and orientation of the driver from the Control Panel, and that match to the paper size in the printer's trays.
Good luck and please rate me, thanks.
May 28, 2008 | Ricoh Aficio SP C811DN-DL Printer
HP LaserJet 2430n occasionally prints goblety-gook
ISSUE: When printing from the computer, you receive a line of garbage or all of the printed output comes out on one line. SOLUTION: See the following:
  1. Perform a self-test to be sure that the HP LaserJet printer is functioning properly. If the self-test is not correct, remove all cables and accessories (if any) and print a self-test again. If the self-test is still not correct, service the printer. If the self-test is correct, go to the next step.
  2. Reseat or replace the cable. Check the cable for bends or pressure applied by objects resting on the cable. A faulty cable or cables that do not meet the IEEE-1284 Standard can cause print defects by distorting signals.
Jan 09, 2008 | HP LaserJet 2430n Printer
Won's print pdf files
Trouble with the HP Laserjet printed output may be solved by using the following settings (or similarly named ones): "Use raster Graphics" (instead of "Use vector graphics"). This may fix the problem of "reversed" text (white on black background) not printing, as well as other problems. "Download TrueType Fonts as bitmap soft fonts" (select "bitmap" instead of "outline" or "graphics"). This may remove the overlapping of text on the printed document. "Graphics dithering" select "coarse" or "fine" (instead of "none"). This selection may improve the quality of images contained in the document. You can find all these settings in your printer properties. Go to File, Print, click Preferences, in Printing Preferences, click one by one all the top options, and change one of the top solutions, one at the time, checking your printing output. Always check if you have the latest version of Adobe Reader Program. If not download the latest version from Adobe, it's free. Is this the first time that you have the problem? or with the same printer (HP 4si), did you were able to print PDF files in the past?
Sep 10, 2007 | HP LaserJet 4si Printer
Aligning problem
You could try opening the HP toolbox should be under Start--> Control Panel--> Printers and Faxes. under properties os options. It will be something like that. Then print an alignment page put it in the scan section of the All In One as prompted and that should align it also under the setting there will be clean print nozzles. If this fails I would seriously consider just replacing the printer. There also explanations of this at www.hp.com
Aug 05, 2006 | HP PSC 1350v All-In-One InkJet Printer
HP DeskJet 5150 InkJet Printer Logo
114 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
