Question about JVC AV-48WP30 48" Rear Projection Television
Kinda dead no power on from power button but when I unplugged the ckt bd that had the switches on front of tv, the set came on then while on it started changing channels and volume went up all by itself and plugging the board back in [button board] none of the buttons worked and when I unplugged the board again the set shut off all the buttons check ok also I get no voltage reading on switches from front panel or the data line going to front board
  • Jeff Wolf Dec 10, 2007
    Then why did the set start changing channels and volume movement with board unplugged ? IR remote sensors have been known to go bad and spit out bad data. Ok I have to get back to the set and try new switches Thanks but while on the jobsite I thoroughly checked the switches but not to the point of removing them
  • 232 Answers
Techwolf, you nailed it, control board is bad, I have personally checked the tact switches and they checked good with Ohm meter but the meter lies, problem is module/board is kinda pricey and individual tact switches are not listed individually on parts list, you also have to be carefull that you get the correct one, there are 3 versions of your posted model #, AV48WP30, AV48WP30A, AV48WP30ME, be sure to check which one you have, should be able to order module here; I have tried cleaning tact switches with "blue shower" but fix doesn`t last, have to change module out, good luck, BMW Rider
Posted on Dec 05, 2007
My player wont load rented blu rays. I have cleaned the lens, done all the unplugging and replugging, and i have loaded older blu ray disks successfully. going to try a hard reset now.
hi donald.
this is all i could find at the mo,so not sure if this will help you out.if not go to the link and the bottom of this page might help you as well.
Blu-ray disc won't play on Blu-ray player [ Edited ]
Options ‎03-01-2013 09:34 AM - edited ‎04-08-2013 05:42 AM
If you are having problems playing a blu-ray disc is your blu-ray player, try the following.
1) Check the firmware-make sure you have the latest version. If your BD player uses the Xross media bar, following these steps:
Press the Home button.
Select setup
Select System Settings
Press the Enter button on the remote.
Scroll down and select System Information and press enter.
The Firmware version will appear on the screen. Write this number down and go to to see if you have the latest version. Just follow the instruction to perform the update. Check out this will walk you thru the steps I just described.
2) If your BD player doesn't have internet connection, you can check the firmware version by:
Press the System Menu button.
Highlight Setup and press the ENTER button.
Highlight Video Setup press the ENTER button
Highlight TV Type and press the ENTER button
On the remote, press the Blue button
The current firmware version of the player will display. Write this number down and go to to see if you have the latest version. Just follow the instruction to perform the update. Check out this will walk you thru the steps I just described.
3) Some BD players requre that a USB memory device is inserted in the EXT slot of the player prior to playing the movie. It's recommended to use at least 1GB. If you already are using one and run into a disc not playing, try removing the USB device and plugging it back in.
Here's a few more things you can try.
1. Reset the BD Player:
  • Remove the disc from the BD player.
  • Turn off the BD player.
  • Unplug the power cord of the BD player from the electrical outlet.
  • Let the player remain without power for one minute.
  • Plug the power cord back into the electrical outlet.
  • Turn on the BD player.
  • Insert the disc into the BD player
2. Make sure that the Parental Control settings are not set to "On".
3. If the BD player supports the BD-Live feature, set the BD Internet Connection setting to "Do Not Allow" and delete any conflicting BD-Live date from the BD/DVD Viewing Settings menu.
won load rented blu rays Google Search
Nov 03, 2017 | Televison & Video
I have a 2000 chevy s10 2wd. Where is the relay switch to my drivers side window. The window switch is and the motor is good. But cant find the relay switch to check it and see if it's bad.
Sorry but there is no relay switch ! Go to free wiring diagrams .Check it out ! Your regulator is probably bad ! Is there B+ voltage at the switch , at the motor ?
Left Front Window Switch Operation
Place the ignition switch in the RUN position in order to supply battery voltage to the left front door lock and side window switch through the POWER WINDOW circuit breaker and the CKT 1001 (DK GRN). Press the left front window UP switch in order to supply battery voltage to the left front side window regulator motor through CKT 164 (DK BLU). The window motor is grounded through CKT 165 (BRN) and the window switch DOWN contact.
The regulator motor runs to drive the window to the UP position. Press the DOWN window switch in order to provide battery voltage to the window regulator motor in the opposite direction through CKT 165 (BRN). The window regulator motor is grounded through the CKT 164 (DK BLU) and the window switch UP contact. The motor runs in order to drive the window down.
Aug 22, 2016 | Cars & Trucks
Refrigerator has a clicking sound and does not run
Replace the motherboard (part # WR55X10942) but be careful to check that the evaporator fan (inside the freezer) turns on when you power up the refrig again. A bad evaporator fan motor can take out the motherboard. If compressor starts with new board but not evap fan, unplug immeadiatelly and replace the evap fan motor to save new board.
Sep 11, 2009 | Refrigerators
Samsung tv model no LE40R74BDXIXEU TV IS USUALLY
First the main bd controls the "Turn on" sequences". When you press the Power on button the Main bd sends a "Turn on" signal to the Power supply. The clicking you hear is the Power on relay ativating. If the tv does not turn on and the relay keeps clicking then you might have a bad Main bd or there is s shorted board somewhere else in the set. The Power supply can also be bad. Have a trained Samsung tech troubleshoot the set.
Jul 12, 2009 | Samsung Televison & Video
Multiple causes here. The Main bd controls the Power supply. The Main bd receives the "Power on " signal from the IR sensor and the Power Button the tv. Seems that the Main bd is not sending the Power on signal to the Power supply. So the first place to start is with the Main bd. Second being the Power supply. have a trained Samsung tech troubleshoot the set.
Jul 11, 2009 | Televison & Video
Panasonic CT36SC13 remote or front power button will not turn off
a)Inside the tv there are microswitch CH+- Vol +- power, menu: when the ones are faulty," tv tends to behave at its own", change them, of course before to buy'em, unsolder th'em and try with the remote, tv has to work with out'em.
Apr 08, 2009 | Televison & Video
Dead set
sub power comes from microp to front panel touch boards if absolutely nothing hapen you may not have this voltage.also there is a fuse were the power cord connects to power bd.clay
Mar 03, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Blinking green light on front of ws55909 projection tv. have reset it by both unplugging and pushing reset button. light continues to flash. has for 2 days. can't operate tv
do this press and hold device and menu button on the front of set.. this is to retrieve a to digit error code flashed by the leds. also this set neds to "boot" let the led flash for at least 70 seconds. if it continues to blink the tv failed to boot. There is service bulliteens that states capacitors in power supply can be bad. this capacitors are kinda hard to get to and rather invovled to replace
Jan 15, 2009 | Mitsubishi WS-55909 55" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
