Question about Toshiba Satellite A105 Notebook
Hard drive upgrade?
Toshiba Satellite A105-S2712:
Want to upgrade hard drive from 60gb to max. What is the largest drive available that the A105-S2712 will support? What specs does it need to be (SATA/150, 2.5", ???)? Thanx
  • JAGCO Dec 05, 2007
    It has the Intel 915GM Express system chipset, Pentium M 740 processor (1.7, 2GB PC4200 DDR2 memory (Upgraded from 512MB), running Windows XP Home.
I had the same problem with my 2712 while it was under warranty. After about 10 minutes it would display the problem you described. Found out it was heat related. The cooling fan in the bottom of the laptop was not functioning properly.
Posted on Aug 07, 2008
Symptoms of my Toshiba Satellite A105-S2712 Laptop:
- No display on the screen (Black Screen). But when I press Fn+F5 keys it displays the menu that appears when you press F8 during start up. After this display it restarts continously,
- I repalced the memory and the hard disk but no change,
- I am unable to boot from the CD drive and floppy disk drive.
Please give me the solution for the stated problem
I thank you in advance
Tewelgn, Awassa,Ethiopia
Posted on Jun 06, 2008
  • 38 Answers
Look it depends on your pc configuration.
If you use dual core then you can upgrade maximum to 340gb sata hard drive.Also you need a higher ram,More capacity more Ram and Speed
Please rate me if i helped you.My name is Karatela
Posted on Dec 05, 2007
  • 4,889 Answers
Which mother board do u have?Intel 915GM Express or ATI RADEON XPRESS 200M IGP or Intel 945GM Express
  • eagle338
    eagle338 Dec 05, 2007
    You can upgrade up to 400Gigs!Type is SATA. You dont need to change anything else as u already have 2GIGS of RAM!
What's the largest capacity HDD my Toshiba 4300 can support? Also what's the max RAM it can support?
This can support up to 160 GB of hard drive and for the max RAM support it can handle up to 320 MB.
Aug 16, 2010 | Toshiba Axiom 60GB HDD Satellite Pro 4300,...
I have a laptop Toshiba Satellite A75-S206 Intel Pentium 4 2.8GHz / 802.11b-g Wireless / 15.4-inch WXGA / 512MB DDR / 60GB HDD / DVD-ROM/CD-RW Combo / and I want to change the hard disk.I want a list with...
That takes an IDE HDD. They are universal so any notebook IDE HDD will replace that 1. I like Weatern Digital because they really are good about standing behind their hard drives. Now it only came with a 4200 RPM so when u upgrade purchase the 5400 RPM. If the bios firmware only supports the 60GB then u will need to format a larger drive with a second partition using admin tools as a mass storage device.
Aug 14, 2010 | Toshiba Satellite A75-S206 Notebook
Need a drive - best place?
Lots available on EBay
http://shop.ebay.com/i.html?_nkw=Satellite+A105+hard+drive&_sacat=0&_dmpt=PCA_Mice_Trackballs&_odkw=inspiron+6000+keyboard&_osacat=0&bkBtn=&_trksid=p3286.m270.l1313
Another place I like is Newegg.com
http://www.newegg.com/Store/SubCategory.aspx?SubCategory=380&name=Laptop-Hard-Drives
Jun 08, 2010 | Toshiba Satellite A105-S4004 Notebook
Upgrading hardisk
yes but you will have reinstall windows and save any files you need on another external medium like a external hard drive
May 08, 2010 | Toshiba Satellite A100-S8111TD Notebook
Toshiba A105-S2712 Won't Recognize The Wireless Connection
Have you installed the driver for the router that you are using or using the inbuilt windows program to search for your wireless network?
If windows, are you searching all channels or is it set to only find unsecure networks whilst i assume yours is secure?
Jan 24, 2010 | Toshiba Satellite A105 Notebook
Which processor can I upgrade to?
Honestly, it is normally not worth it to upgrade the cpu on a laptop. Laptops are build to deal with a certain amount of heat and adding a faster cpu can cause the current cpu cooling fans to not get the job done anymore. You will seem instability in your system and could possibly damage it due to over heating.
With that said you would only be able to upgrade to a very slightly higher speed cpu and your money would be better spent else where. Some good ways to speed up a laptop are max out your memory or install a faster hard drive. For example if your current drive is a stock 5400rpm unit a 7200rpm drive would give you a nice boost. You could also look into a solid state option.
Both these upgrades will give your laptop a better boost without the hassle and risk of a cpu upgrade.
Aug 24, 2009 | Toshiba Satellite A105-S4334 Notebook
Hard drive and memory
the laptop should pick up a 20gb or 60gb ide hard drive with no problem
Memory Upgrade for Toshiba Satellite 2775XDVD Laptop, the Toshiba Satellite 2775XDVD Laptop takes the PC100 SDRAM SODIMMs Memory Type, and comes installed with 64 MB (non-removable) of Memory. You can upgrade your Toshiba Satellite 2775XDVD Laptop to up to a maximum of 192 MB Memory, the system has 1 socket to install Memory, already with 64 MB (non-removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Choose the following Memory Upgrade for Toshiba Satellite 2775XDVD Laptop
Dec 01, 2008 | Toshiba Satellite 2775XDVD Notebook
The tool could not get HDD physical information.
Laptop hard drives are usually the 1st to go when it comes to issues with laptops.
I would recommend replacing it. Roughly 50 bucks for a 40 or 60Gb laptop Hard drive. Install it and try your recovery cd again.
My wifes laptop is from 2001 and it has gone through 2 hard drives. Its just the way they are. Backup data, always!
G'luck
Oct 23, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite A105 Notebook Logo
159 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
