Question about Philips 42PF9956 42 in. HD-Ready Plasma Television
Poor Picture Quality on Philips 42PFL7962D
We bought a Philips LCD 42PFL7962D TV afew days ago. The quality of the picture when we're watching DVDs is great, but when we watch tv there are vertical lines going down the whole of the screen. Can anybody help?
  • Anonymous Mar 24, 2014
    IT CAUSES HEADACHE FOR ALL PIOPLES
    Novelist:
  • 173 Answers
Get the professional, although this won't be an expensive fix... You likely have one or more caps in the vertical circuit that are going bad... A cap acts like a battery in a circuit taking on voltage and releasing it at an even rate. When they go bad their ESR (equivilent series resistance) rises and the cap takes longer to reach it's op temp and work properly...
A tech with an ESR meter will easily find and repair this one...
no other issues only a minor problem..
Posted on Dec 05, 2007
  • mohana sundaram Dec 05, 2007
    Also try this options ..
  • Press the ‘menu’ button on the Remote Control
  • Select ‘INSTALLATION’
  • Select ‘CONNECTIONS’
  • Select HDMI 1, 2 or 3 depending on the input you have connected the PC
  • Select ‘PC’
  • But if your product is still under warranty, better contact your dealer and get the issue fixed
I have a Bush 24 Inch Full HD 1080p Digital LED Backlit LCD TV which i bought 2days ago. I set it up according to instructions and it seemed fine, watched a couple of dvds on it (via a Phillips dvd...
This trouble is commonly cause by a weak signal, try to check all the jacks that is connected to your lcd and dvd there might be a loosed connection.
Jun 07, 2011 | Televison & Video
G'day, I have an LG HDD/DVD recorder (model RH298H) connected to an LG plasma screen digital TV via an HDMI cable. On the TV I have crystal clear digital television (and able to tune all the digital TV...
You have probably found out now that you would need to get your digital reception by connecting a set top box to the LG, say to AV1, then select AV1 when making a recording.
Apr 17, 2011 | LG RH1999H DVD Recorder/HDD Recorder
I have an LG 42lh30 I bought less than a month ago from frys. When I opened the box it did seem slightly used maybe it was returned and refurbished or something. I have an xbox and I use a philips 1080p...
Is it a Duplicate Question....Wonder why?
Same reply :0
This is an internal Fault. Diagnosis is required to make sure whether it is Failed T Con Board or Light Engine. I do not think that it would really help by changing the TV settings. This was a Common Problem with Old LCD's where you got Blurry Spots specially while Playing Real Fast Movies or Games. On Few Occasions, it as Corrupted Firmware.
As i cannot see the Video or Screen from here, more likely what i could guess it is an Internal Fault as you have tried using HDMI, Use different Setting Combination's and you got the same Picture Quality with DVD as well.
So, what i could suggest, get back to the Seller and Lodge an Official Complain and get it Replaced. There is no point in Opening and TV and Inspecting it and Replacing Components when it was less than a month ago.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 30, 2010 | Televison & Video
Picture quality poor on certain channels,get all of bbc channels ok rest loss of sound and hick ups in picture
if all channels poor quality TV problem
if just one or tow channels bad quality not tv problem....
Oct 28, 2009 | LG 42LC2D 42 in. LCD HDTV
BRAND NEW 42in. vizio 1080 LCD HD 120HZ picture not clear
the tv models in store are usually have samples from blueray dvds. standard dvd players will look fuzzy because it only submits standard dvd picture quality. you can try an upvert dvd player. tho i cant promise picture quality. i have an xbox 360 that upverts the quality. if you get a bluray player i recommend hdmi wires. if you get upvert dvd player and it has an hd outlet red, blue, green wires it might work. i havent tried one myself. if you dont want to spend money on bluray dvds. i recommend an xbox console. it upverts dvds through hdmi or hd red, blue, green wires
Aug 26, 2009 | Vizio VW32L 32 in. LCD HDTV
Samsung le40a lcd - picture quality
Hi - I have some suggestions. The following factors effect picture quality:
1. Source (because LCD TVs have much higher picture quality than traditional CRT "Tube" TVs, the worse your source material, the worse it looks on a LCD TV).
DVD and Sky/Digital TV should look excellent on this TV when connected with a good quality Scart lead (nothing too expensive, but a Oxygen Free Copper Gold lead may help) directly into one of the TV's Scart inputs (avoid using "switching" boxes for multiple equipment).
Also, bear in mind that this is a HUGE screen (40 inches I think) and will REALLY show up bad source material.
The best advice I can give is, if you have HD-ready equipment use HDMI connections for everything (ideally with an HD-uplscaling DVD player which will "improve" the quality of standard DVDs on the TV - I recommend models by Philips) and check that you are in "Movie" or "Cinema" mode on the TV.
Make sure that all of your equipment, like your Sky digibox, is set to 16:9 mode (not 4:3) aswell to preserve the true widescreen aspect ratio.
Hope that helps!
Dec 31, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Poor picture quality on Toshiba Regza 32AV555DB LCD TV
i had the same problem! i just changed my scart leads to some quality gold ones, this made the picture a lot crisper . hope this helps :0)
Dec 14, 2008 | Toshiba REGZA 32WLG66 32 in. Television
Magnavox 15" LCD TV
If the LCD only has coax, it will never display a HD picture quality. However, the Comcast HD Box will still display a picture using the coax connection. So, you could watch any HD channel, but the picture quality will not be high definition.
Jan 22, 2008 | Philips Magnavox 27MS343S 27" TV
Picture quality
i have a similar problem, when watching football the picture is terrible,but when im watchin ordinary tv its great
Dec 28, 2007 | Samsung LN-R409D 40 in. LCD Television
Philips 42PF9956 42 in. HD-Ready Plasma Television Logo
313 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
