Question about Epson Stylus Photo R200 InkJet Printer
Internal error I was doing a head clean when the message internal error came up and my printer stopped and hasn't worked since
  • 490 Answers
Dear sir
kindly change the printer catrage , this suitation is due to print head as when it gets back.
thanks
Posted on Dec 05, 2007
Unable to print 48
Clean the plastic encoder strip thoroughly
In order to access both ends please follow these steps
1. After the error message is displayed on the LCD or display, open the scanner cover, so the print head is visible.
2. Press and hold the Stop/Exit key for 5 seconds. The print head will move to the middle.
3. Unplug the power cord from the power outlet.
4. Use a clean lint free cloth dampend with a bit of alchohol and clean both sides of the encoder strip thoroughly. Move the print head from side to side to allow access for cleaning of the entire encoder strip.
Feb 25, 2014 | Brother MFC 6490CW InkJet Printer
I'm getting an error message "Service required. Contact Epson."
Same story...Yes i use brand name cardrige... But i use it one a month since 29 months ! HELP !
Jun 04, 2012 | Epson Stylus R380 InkJet Photo Printer
"My cannon IP100 portable printer
Hi
You can check the small contacts on the carts, that they are clean and contacting the sensors on the carriage in the printer when you snap them in. Also, double-check your printer cable, that it hasn't jiggled loose where it connects to the printer or the other end, on the computer.Make sure that you have removed the tap from the head of ink cartridge. Then take out the cartridges and after some time ,snap it back.Then align the cartridge and then run the cleaning cycle.You can also Try to disconnect the power and computer for 10 minutes, then reconnect just the power and turn on.
Also try to upgrade the latest driver of this printer and see if it works
http://www.usa.canon.com/cusa/consumer/products/printers_multifunction/photo_inkjet_printers/pixma_ip100
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 13, 2011 | Office Equipment & Supplies
Hello I have a Lexmark X4650 printer. I was printing earlier this morning and then suddenly, the printer stopped working and gave the error message that left cartridge is incorrect (I haven't...
Good job in re-seating the cartridges into the printer. Try to insert a different known working cartridge to determine if your other cartridge has gone bad.
Jul 24, 2011 | Lexmark X4650 InkJet Printer
Errore 4F? che vule dire? come posso risolvere?
4F message indicates that the print-head is RIP, you will need to replace it to make it work again. Before you replace it, you may want to try this, see if it will remove the clean unable error message: Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3. This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Feb 05, 2011 | Brother MFC 240C All-In-One InkJet Printer
My printer says unable 4F clean
4F message indicates that the print-head is gone, you will need to replace it to make it work again. Before you replace it, you may want to try this, see if it will remove the clean unable error message: Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3. This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Jan 30, 2011 | Brother DCP-130C InkJet Printer
Epson rx650 printer service shutdown repair. Can anyone help to get this printer going again? For 6 days it gave message service required and then an error message with only shut down option. Regards...
Main features.
SSC Service Utility allow you to do many amazing things with Your Epson printer :
1) Work directly with CSIC in Epson printers cartridges.
2) Reset or rewrite any chip using special addon device.
3) Freeze internal ink counters.
4) Reset internal ink counters even with empty cartridges.
5) Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode.
6) Hot swapping of cartridges supported.
7) Resetting of protection counter (even then it is already full).
8) More then 100 different Epson printers supported
This allow many people with high printing demands to save some money (program works with both black and color cartridges).
Up to day this software works under Windows 95/98/ME/2K2/XP with both the LPT and USB printers.
NOTE ! You can lost Epson lifetime guarantee on print head by refilling ink cartridges!
Latest versions changes:
Apr 26, 2010 | Office Equipment & Supplies
"incompatible cartridges"
Usually if you leave the printer off for sometime the ink get dry on the heads or some ink may leake to the sensores so take the cartrage out clean it and clean the heads with cotton swaps...see if the help and let me know
Sep 13, 2009 | Office Equipment & Supplies
Epson Stylus Photo R200 InkJet Printer Logo
46 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
