Question about Toshiba Satellite A135-S2276 Notebook
Toshiba A-200 10W webcam locked by another application
The webcam is locked by another application while there's no other progam ruuning.What can i do?
  • 19 more comments
  • dafni Dec 06, 2007
    no i havent it gets on my nerves!if somebody does please tell me so!and how,,!
  • pesante Dec 07, 2007
    it is the same for me on the toshiba U300-137 satellite !!!!
    help please....
  • nafis Dec 08, 2007
    i have the same problem ,everytime i try to turn on the web cam, it says locked by another application.I am using the A200 Satellite.
  • alobua Dec 11, 2007
    My laptop is a Toshiba M200, its so frustrating and there doesn't seems to have any solutions.
  • Anonymous Dec 12, 2007
    I Have a toshiba satellite A215 I have the same problem.THewebcam works fine sometimes which is very rare but most of the time i receive the message not connected or used by some other programme even though no other programme is running.AS suggested i have tried all the methods but it is of no use. Please help
  • Anonymous Dec 20, 2007
    my webcam was installed but the msn was deleted and now that msn was downloaded now the webcam is not working
  • LadyGL Mar 13, 2008
    My webcam was locked by another application.
    All effort has been made to activate it but to no avail. I can't identify the origin, where it was locked. I can't remember selecting any option that will lead to the lock. Please I really need help & support to activate it as soon as possible. Above all, there is no direction or option to activate it. Help Please.
  • stava Mar 15, 2008
    web cam saying it locked by another application
  • Anonymous Apr 05, 2008
    you dont have to select anything for it to lock... just does...
  • Sarmistha May 22, 2008
    I have bought a Toshiba Satellite M200/N00 Laptop just a week back.While trying to chat using web cam,it gives an error "Locked by another application".
  • Anonymous Jun 27, 2008
    i have the same problem. some one tell me how? there are some comments that window vista is creating that problem. the other window doesnot have that such problem.
  • gidget65 Jul 14, 2008
    Webcam locked by another application
  • bobgndr Nov 07, 2008
    i bought a toshiba laptop like 2 weeks back ,whenever i try to use webcam it gives me locked by another application....why ??? please we need help.
  • allam3000 Jan 06, 2009
    toshiba A-200 10W webcam locked by another application problem, and notify you when a new solution is offered.
  • mikey333 Jan 08, 2009
    i have a webcam built in my labtop but i want to record something but when i press the record botton it says "locked by another application
  • thomasjn15 Jan 17, 2009
    My computer says that the web camera software cannot start because it is locked by another application. It will not allow me to use the web assistant software.
  • blehblehh Jan 21, 2009
    my webcam is telling me that it's locked by another application are there are no other applications open on my computer!
    WHAT!?
  • Anonymous Feb 01, 2009
    same Problem
  • Anonymous Feb 09, 2009
    • toshiba satellite u405 s2833 locked by another application
  • acare2004 Apr 06, 2009
    camra not workinf
  • miky_gs
    miky_gs Dec 11, 2009
    i use an emachine pc...pls can anyone help me find and connect my webcam
I don't know what exactly fixed the problem but I managed to fix it. I'm using a Toshiba Satellite A215 by the way.
Here's what I did
Control Panel >> System Maintenance >> Device Manager
Go to Imaging Devices and right-click "Chicony USB 2.0 Camera" and choose "Update Driver Software"
First I clicked on "Search automatically for updated driver software" but everything was already up to date. So then I went to "Browse my Computer for Driver Software" and then to "Let Me Pick from a List". I updated the USB Video Device and rebooted but that only made it worse I think. Then I tried updating one of the "Chicony USB 2.0 Camera"'s and that did the trick. Yey. So now my webcam works.
Posted on Jan 05, 2008
Try Pesante80's solution.He/She is absolutely correct...it is the webcam software. I un-installed the software that came with the laptop...and voila! My webcam now works...no more irritating messages! I went into add/remove ...removed the offending program, and restarted the laptop...cam works great.
Posted on Mar 06, 2008
I had this problem on satellite U300 with Vista. I fixed it unistalling all the native webcam programs and drivers. then restart and Vista will automatically install the latest driver release. It should work. If not, try also to install the ffdshow codec. In any case, the problem is definitely the chicony webcam programs which aren't compatible with vista. The latest drivers instead are. Try also to complete the unistalling by using a reg cleaner as ccleaner. Hope I'd be useful.
Posted on Dec 11, 2007
Issue: Other programs already using the device? Unable to see the Video using Messenger?
Solution(Verified): There might be some programs that is already attached with the device. To deactivate them, run msconfig by going to accessories and then run. Then under the tab labeled "Services" check the box that says "Hide all Microsoft services" and then click on disable all press ok. You should then be asked to restart so press ok and once the computer is back up try with your messenger software and it should work.
Posted on Jan 30, 2008
Same thing happened to me on my Gateway presumably with the same camera.
Others noted that when they installed Messenger it locked. I took this tack and uninstalled everything I could think of until I came to VirtualDub.
Now, amongst movie makers VirtualDub is considered great although a GUI that takes some getting used to.
So I dumped my built webcam software and am sticking with VirtualDub. It works great.
Posted on Apr 04, 2010
Franki1118 is right. uninstalling the camera assistant software fixes the problem. I can now use the webcam for msn! :)
Posted on Oct 18, 2008
Frankie1118 is right. uninstalling the camera assistant software fixed this problem for my a215-s4807 laptop. I can now use the webcam for msn etc.
I dont really know if this will solve cuz mine is A215-s4747
1st- go to computer
2nd- (click it) go to uninstall program or change ( its at the top)
3rd- find camera assistant right click (click change)
4th - there will be 3 choices click the MIDDLE ONE
and after that it will load and restart your computer
then there it works
Posted on Sep 05, 2008
Just re-start it. it will work as charm....
Posted on Jun 12, 2008
There can only be one application running at a time that uses the webcam so if it's toshiba it would be Camera assistant just right click on it and exit. Or turn it off using solution 2
Posted on May 23, 2008
I had the same problem, restarting the computer fixs it usually
Posted on Jan 03, 2008
    Scholar:
  • 181 Answers
Are you running an instant messenger program that uses webcam chat? Many times, the processes that run these programs will hang, even when the program has been closed.
I assume rebooting fixes your problem, at least for one use. If you want to get around restarting, unplugging the webcam and then plugging it back in will usually free up the resources.
My webcam keeps telling me that it's locked by another application...nothing else is on!!! what is the problem,it's been doing his a lot lately...ennoying...
Kindly go to the task manager and check in the application window to see the possible applications running. As certain applications run on start up.
Jan 26, 2012 | Toshiba Satellite A135-S2276 Notebook
How do I switch on my Webcam on my laptop?
To switch on Webcam, you must install the Webcam drivers and applications. Drivers and applications, adapted to type of laptop. Example: Toshiba Satellite L510-ST3405 to Win XP operating system.
Drivers and applications, you can download here
Toshiba Support Homepage
1. Open link
2. Choose category = Laptop
3. Choose family = Satellite
4. Choose model =
L510-ST3405 - click GO
5. Select operating system = Example Win XP
6. Download driver and application
7. Install driver and application
8. Open application to switch on Webcam.
Nov 10, 2011 | Toshiba Computers & Internet
I have a toshiba satellitr L655D-S5050 and when I try to use my web cam it says locked out by another app. ??
Goto Run-> MSCONFIG-> in startup tab -> Diable all applicaitons except antivirus. then restart the system and check the fucntionality of webcam.
Even the problem not solved please right click on the task bar, Goto TASK MANAGER. please close the application related to webcam or any application related to webcam .
I hope it might help you.
Jun 16, 2011 | Toshiba Computers & Internet
How do i yurn my webcam on for g56-129wm hp notebook pc?
check for a progam named as youcam from cyberlink.this is the application that automatically switches on our webcam
Dec 26, 2010 | HEWLETT-PACKARD G56-129WM Laptop PC
How do i unlock my webcam from another application please
how do i take an app off my web cam its loked i dnt even kno wat progam it is?
Sep 10, 2010 | Toshiba Satellite P105-S6197 Laptop
Rebooting plug-in webcams is easy - just unplug the lead from the USB port for a couple of seconds
Built-in are not so easy. Apart from rebooting the whole computer you can access and expand the Imaging folder in the Device Manager and disable and enable the webcam from there.
Dec 12, 2009 | Computers & Internet
Web cam wont turn on says locked by another application
Please try to see your laptop webcam setting if it is assign by other application or not then you can edit the current setting of your webcam so that it can be used according to your desire and purpose.
thanks
Aug 07, 2009 | Toshiba Satellite U305-S5097 Notebook
Toshiba satellite a205 webcam says locked by another application
You have an application that is grabbing the webcam on bootup, so the best way is to disable this program from runnning. To do this, click Start - Run and type "msconfig" and press enter.
Click on the Startup tab and this will bring up a list of all the things you have booting. Look for webcam manager, and remove the checkmark beside it. Click Ok and then reboot. Problem should be solverd
May 01, 2009 | Toshiba Satellite A200-0ET00X Notebook
Check if you download any new application that makes a conflict with your webcam? just remeber if you did download any program and this makes the problems, if you donot want to do this , just go to start, programms, accessories, system tools, and restore yout pc to the day before this problem happened and you will be fine.
Best Regards
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Mar 02, 2009 | Toshiba Satellite A215-S4747 Notebook
Close any applications that could be using your Webcam other than the one you want to use it.
Good luck.
Feb 23, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite A135-S2276 Notebook Logo
23,701 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
