Question about RCA HD61LPW42 61" Rear Projection HDTV
RCA HD50LPW175YX1 Panel lights blink 5 times, not power on
I just replaced the lamp for this TV - as the symptoms indicate as stated in the user manual - but, when I plug it in, all the lights on the front panel flash five times then remain on for a while, then repeats the 5 flashes and remain on again, and repeats the cycle. I don't hear any whines (light engine) or "whoomps" (ballast), as I read about in other blogs. ( I have checked the lamp panel door switch, and it's working OK)
Do you have any suggestions? Any and all help is greatly appreciated.
  • jumpking Dec 05, 2007
    I have installed the lamp completely.....screws are tight and the tip is in inserted in the hole. Any other suggestions?
    Thanks
    President:
  • 4,402 Answers
Make sure the lamp is pluged in all the way
Posted on Dec 05, 2007
  • Cary Farah
    Cary Farah Dec 05, 2007
    take it out and put it back in. still nothing time for service call.
When i turn on my tv it tries to boot, blue mitsubishi home screen come up, i hear fan then it all shuts off while green light blinks.
Try a reset. Start by unplugging for 1 minute, then plug back in & if still won't restart try the following. If none of the following work, you will need a technician.
Initializing the TV in many cases can remedy a problem.
In the 2006 product line Initialization is now a user function.
Pressing the front panel "INPUT' and "FORMAT"
buttons at the same time activates Initialization. When
complete all user settings will have to be set again. The
table in Figure 4-3 list the User Initialization procedures.
Note: Pressing INPUT and FORMAT is the same as
the Initialization in the Option Menu (MENU-2-4-7-0)
Order Name Procedure Results Notes
1 System Reset Press <System Reset>
on Front Panel
Hardware & TV operating
software reset.
POWER/Timer LED flashes for 60
seconds. No customer settings
are changed.
2 User Initialization
Press <INPUT> &
<FORMAT> on Front
Panel at the same time.
All customer Audio &
Video settings are reset to
factory default.
All customer settings will need to
re-configured.
3 Reset System
Defaults
From the remote, press
<MENU> <1-2-3>
<ENTER>
except V-Chip are reset to
factory default.
Netcommand, Channel Memory,
etc., will need to be re-configured.
SERVICER
PROCEDURE 4 Initialization
<MENU> <2-4-7-0>*
select "INITIAL" press
<ENTER>
All customer settings are
reset to factory default.
re-configured.
MITSUBISHI RESET / INITIALIZATION CHART
CUSTOMER
PROCEDURES
Figure 4-3
Figure 4-4
LED Indications
The front panel LEDs, refer to Figure 4-4, also assist in
determining the cause of a symptom. Figure 4-5 illustrates
normal LED operation. Figure 4-6 shows the
LEDs response when a problem is detected and indicates
the possible cause.
Power/Timer
Indicator
Status
Indicator
Lamp
Indicator Condition
Off Off Off Off (standby)
Blinking green
fast Off Off Initialization (10 - 65 seconds)
Off Off Blinking
green fast Lamp runs for 1 min after PTV off
Green Off Off Power On
Blinking green Off Off Power On Timer is set
NORMAL LED INDICATIONS
Power LED Status LED Lamp LED Condition
High Temperature - check ventilation air flow.
(Temperature sensor is disconnected.)
Off Off Blinking yellow Lamp cover is open.
Lamp failure (Lamp fails to turn on)
Off Off Red (Lamp turns off after lighting)
Lamp is broken
Off Blinking Red Off Fan Stop
Off Red. Off Circuit failure. (Run Error Code Check)
Apr 08, 2015 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
Yellow blinking light . what does it mean
A blinking yellow for this model indicates the TV is too hot, unplug & allow 30-45 min to cool before re-plugging .
OR: lamp not installed or lamp door not closed. there is a lamp door switch that may not be closing, simulating door not closed
LED Indications
The front panel Status LED provides an indication of
the set's operation and the possible cause of a malfunction.
If an abnormal condition is indicated, perform the
Self Diagnostics procedure.
Self Diagnostics
To activate, press the front panel <ACTIVITY> &<CH
??> buttons at the same time and hold for 5 seconds.
The STATUS LED will then flash denoting a two digit
code.
• The number of flashes indicates the value of the
MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2
second.
• The LED then flashes indicating the value of the
(ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED
will flash two times, pause, and then flash three
times.
Table 2-2: LED Indications
Error Codes, descriiptions and the most likely cause of
the error are listed in Table 2-3.
Note: The TV must be in "Shut Down." The LED
will probably be indicating an abnormal
condition. If the TV is switched Off, AC is
removed, or a System Reset is performed, the
code automatically resets to "12" No Error.
See the Error Code Log to retrieve a history of
errors.
Note: Use the front panel buttons, not the remote
control.
Note: If there is no response, the front panel may be
locked by a V-Chip setting. To unlock, press
and hold <ACTIVITY> on the front panel for
8 seconds.
LED Indication Condition
Off Off (standby)
Green Power On
Slow Blink Green Power Off with Timer Set
Fast Blink Green (80 seconds) > Off Power Off (Cooling fan still working, 80 sec)
Red Lamp Failure
Yellow TV Too Hot
Slow Blink Red TV May Require Service
Slow Blink Yellow Lamp Door Open or No Lamp Installed
NORMAL INDICATIONS
ABNORMAL INDICATIONS (For details perform Self Diagnostics Procedure.)
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
Rca tv L46WD22 and green light followed by 5 red flashing lights
These blinks (Flashes) are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check these link s
http://electro-medical.blogspot.com/
Dec 13, 2013 | RCA L46WD22 Television
My RCA 52" HDTV Rear Projection TV Model #MM52110JX1 will not turn on. Neither the remote, nor the front panel switch will turn on the TV. When you press the power button on the remote, the red indicator...
you must check the light indicator if how many times does it blink which tell the main problem or the error code of the tv. either the power supply doesn't work normally or the lamp need replacement.
Sep 23, 2013 | RCA D52W19 52" Rear Projection Television
STANDBY INDICATOR LIGHT BLINKS 15 TIMES WHEN TV IS TURN ON NO PICTURE OR SOUND
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator.But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs,It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator, it could be time to replace the lamp.
Dec 05, 2010 | Sony KDS-60A2000 60" HDTV
Hello our sony grand wega KDF e55a20 has the green standy light blinking over 50 times then turns 5 red blinking lights. please help. thanks
Symptom shows Lamp is not working and either lamp or its drive board is bad that will be replaced.
Did you replaced lamp in tv recently?
If not, replace it. Lamp replacement procedure would be written in user manual.
Thanks.
Jan 20, 2010 | Sony KDF-E55A20 55 in. LCD Television
Picture goes out after 3 seconds then may come back on then off again
If green light in front of TV blinks while picture goes off and comes back then its symptom of weak lamp that need to be replaced.
And if green light does not blink in above process then let me know.
Thanks.
Nov 23, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
I have RCA HD50LPW167 DLP TV with NO Sound and NO Audio. The LED blinks when I turn the TV on but that's all it does. Took it to the local RCA authorized repair shop and they told me that the digiital...
Still sounds like a lamp:
TV won’t turn on
• Press the TV button or ON/OFF button while remote is in TV mode and there’s a source of power to the outlet or outlet strip.
• Make sure the TV is plugged in.
• You might have tried to turn on the TV during the lamp cool-down. Wait a few moments and the picture will appear.
• Has the power light on the front of the TV been blinking for one minute? If so, the lamp may be dead. Refer to the Power indicator
is blinking or fl ashing
section below for more information.
• When you fi rst plug your TV into an outlet, the Power indicator on the front panel will light and blink for approximately 30 seconds
and then go off during the initialization of the TV. This happens only when power is reapplied to the TV. The TV can only be turned
on after the Power indicator goes off.
• Check the wall receptacle (or extension cord) to make sure it is “live” by plugging in something else, such as a lamp.
• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the
remote control solutions on page 84.
Remote Setup might be set to the wrong option. Press MENU/OK on the front panel. Select Connections, then Special Features, then
Remote Setup. Choose TV (default).
Power indicator is blinking or fl ashing
If the light blinks 5 times, pauses, and blinks again 5 times, the lamp is trying to turn on. If the TV doesn’t turn on after 5 minutes and
then the light blinks steadily for one minute, one of the following options is possible:
• Lamp door may be open.Face the back of the TV. Locate the door at the bottom of the TV and close it. Turn off the TV and turn
back on. The lamp should turn on.
You can easily replace the lamp yourself by following the lamp replacement instructions. If your TV is still covered by
the warranty, call 1-866-723-6486 to receive troubleshooting assistance and a lamp replacement.
• If your TV’s warranty has expired, call 1-800-338-0376 to purchase a lamp replacement.
To order the correct lamp, you’ll need to know your TV’s model number, serial number, and lamp type—this
information is listed on the Service Model Number sticker (example of the sticker is shown above). Face the back of
the TV. The sticker is located on the right side of the TV.
Hope this helps :)
Mar 07, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
Blinking lights and pwer down
Good Day;
Try this:
Symptom: All Front LED indicators are flashing in sequence: Power-->Temp-->Lamp-->Power......continuously
Cause: Replace Lamp . This symptom may happen all the time or it may be intermittent. It is normal if it occurrs from time to time, See OG under TV Front Indicators explanation notes.
Good Luck, big IRISH.
Jul 03, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
RCA HD61LPW42 61" Rear Projection HDTV Logo
348 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
