Question about Toshiba TP55G60 55" Rear Projection Television
TOSHIBA TP4688 Rear Proj. TV
When power cord is connected to outlet I can hear relay (or something like it) clicking and then when I press the power button nothing happens. I hear 2 distinct clicks when I plug it into the wall. If I leave it out of the wall for 5 seconds and then plug it in, there is only 1 click from the relay but then I press the power button and it clicks and the television does not turn on. Would this most likely be a bad relay or just some diode/resistor/circuit board problem?
  • TP4688_help Dec 06, 2007
    Thank you so much guys! I did not expect that quick of a response :) Consider me pleasantly surprised. Anyway, I am down at college and will be going home in a week and a half, which is where the television is. As soon as I get home, I will do exactly what you suggested and hopefully it works. We've put way too much money into this television so far and we don't want to waste anymore. Anyway, thanks again and talk to you soon. Take care.
  • Cadillacs May 31, 2008
    Same problem: I found the relay that's suppose to turn on televisions picture and sound. Relay does not click by itself but contact is made manually Tv picture and sound turns on. I don't have a problem for days. Then it clicks off again...Blow dryer fix works temporarly. What do I look for? Is there somewhere I can see a picture of component that might have gone bad?
    Genius:
  • 1,694 Answers
Look for F850,F851 black soldered in micro fuses near board edge...usually, convergence circuit is the issue......
Be sure to solder wire jumpers 008,010,017,048,600....any bad
connect can cause fuse to blow again.........T.
Posted on Dec 06, 2007
  • Vista Electronics Dec 06, 2007
    tp4688help,
    Please direct your further needs to BMWRider......
    I am only trying to give additional support help............T.
    Novelist:
    Champion:
  • 232 Answers
Hi, the relay is getting a command to shut down because there is a short somewhere in the set, if you have a volt meter you can check the "chemical fuses" to see which one(s) are open and that will tell me which circuit has the short in it. be advised these are not glass fuses so if your unfamiliar with what a chemical fuse looks like you will have to look on the power supply board for a small rectangular body device with a designation printed on the board "Fxxx". check these and let me know which ones you have failed and we can go from there, BMW Rider
Posted on Dec 05, 2007
Troybuilt snowblow electric starter won't start or turn over. Nothing happens. What could be wrong
if it does nothing, check to be sure you have 120v power out of cord
push starter button do you hear a click/ if not micro swtch is bad
if you do than starter motor is bad
Jan 28, 2014 | Troy-Bilt Storm 2840 277cc 28-in Two-Stage...
Power light comes on but nothing happens
What type of laptop? What operating system?
Laptops don't boot for the following reasons: 1) Bad Power Cord. 2) Bad DC Power Jack where the power cord plugs into the laptop. 3) Static Charge Buildup. 4) Bad Motherboard.
The above 4 reasons are when you press the power button and absolutely nothing happens. You hear no fans running, no disk drive running, no one time clicking sound on the CD Drive and No light for a second or two when the CD drives click. In the case of a motherboard issue sometimes you will hear beep sounds or see blinking lights. Those beep sounds and blinking lights tells the technician what is going on with your motherboard and why it will not boot. If you see the blinking lights or hear beeps count them.
So you have a power light which means your power cord and dc power jack is good. So lets see if you have a static charge buildup.
Remove the Power Cord and the Battery from the laptop, then Press and Hold the Power Button for 30 seconds. After 30 seconds put the power cord back into the laptop, but leave the battery out. Press the power button to see if it boots. If it does you had a Static Charge Buildup and it's ok to put your battery back in. If it does not you more than likely have an issue with your motherboard.
Mar 22, 2012 | Computers & Internet
Toshiba satellitep205d-s7438 won't boot up
You need to be more specific and tell what happens when you plug in the power cord and press the power button. There are a number of reason why a computer will not boot, but if you tell what's going on someone can help you.
Computers don't boot for basically the following reasons, 1) the power supply is bad. That means when you plug it in you don't see any lights, and when you press the power button nothing happens, you hear no fans, no beeps, no blinking lights, no hard drive spinning, no cd drive clicking and nothing appears on the lcd screen.
2) A motherboard issue, usually when this happens you will either see blinking lights or hear beeps. Those blinking lights and beeps are codes that tell the technician what is really going on.
3) Static Buildup - try removing the battery and the power cord then Press and Hold the Power Button for 30 seconds. After 30 seconds put the power cord back in (leave the battery out) and Press the Power Button. If it boots up you had static buildup and can replace the battery, count your blessings and Thank The Lord cuz a dishonest repairman would have told you he had to replace the motherboard for $300
Mar 20, 2012 | Toshiba Satellite P205D-S7438 Notebook
I press the power button but the machine does nothing. It's pluged in and the lcd lights up
  1. Unplug the power cord from the electrical outlet.
  2. Plug another appliance into the electrical outlet to make sure the outlet works.
    • If the electrical outlet does not work , plug the product into another outlet that does work.
    • If the electrical outlet works, but the product still does not turn on , continue to the next step.
    • The power module has a safety feature inside that protects the product during a power surge. If you experienced a recent power surge, the power module might need to be reset. Use the following steps to reset the power module.
      1. Unplug the power supply from the rear of the product.
      2. Unplug the power cord from the electrical outlet, power strip, or surge protector.
      3. If the product uses a power module with a detachable power cord, disconnect the cord from the power module.
      4. Wait 15 seconds.
      5. Reconnect the power cord to the power module.
      6. Plug the power cord back into the electrical outlet. Do not use a power strip or surge protector.
      7. Check to see if the power module has an LED.
        • If the power module does not have an LED, continue to the next step.
        • If the power module has an LED, check to see if the LED lights up.
          • If the LED does not light up, contact HP to replace the power module. To buy a compatible power module, right-click the following link, How to Buy HP , and then click Open in New Window .
          • If the LED lights up, continue to the next step.
      Step two: Test the power on the All-in-One Follow these steps to test the power on the product.
      1. Reconnect the power supply to the rear of the product.
      2. Press and quickly release the Power button (c01602202.gif ) to start a Power On/Off cycle. Do not hold the button down. Figure 1: Press and quickly release the Power buttonc01896071.gif c01733891.gif If you press and hold the Power button too long, the product might turn on and then off without restarting. If this happens, press and quickly release the Power button (c01602202.gif ) again.
      • If these steps resolved the issue , there is no need to continue troubleshooting.
      • If the issue persists , see the next step.
      Solution four: Test the power with a compatible power cord from a different product If you have another available power cord that is compatible with your product, use the alternate cord to repeat the steps in Solution three: Reset the power module and test the power .
      • If the product turns on with the alternate power cord, the original power cord caused the issue. Contact HP to replace the power cord. Right-click the following link, How to Buy HP , to buy a compatible power cord.
      • If the product does not turn on with the alternate power cord, continue to the next step.
      Solution five: Service the HP product If you have completed all the steps listed above and are still experiencing a problem, service the product.
Jan 17, 2011 | HP PSC 2355 All-In-One InkJet Printer
Power could not start by pressing power button but power is coming as the blinking is done for once when connected to power
Solution one: Make sure the electrical outlet works
Solution two: Make sure the power supply is compatible with the HP product
Dec 30, 2010 | HP DeskJet F380 All-In-One Printer
No power seem to be going though
Try unplugging the power cord from the backside of the unit - press the power button for 30 seconds - release - plug in the cord and press power, if nothing comes on and you hear no sound it must be the Power Supply Unit (PSU) which should be replaced. Assuming that the outlet you are connected is powered ON and there is no other external electrical problem.
May 25, 2010 | Packard Bell (ATXMH28AP) Full Tower Case
No power for the wii
Does the outlet you have your console plugged into receiving power? You could check this by plugging in a lamp or something to check for power. If it is getting power, it could be your power cord. If a power cord for the Wii is rolled up too tightly, too many times, the wires inside the cord will come loose and come apart. That may be what happened. Before sending it in or getting a new Wii, you should try borrowing someone's Wii power cord to see if it just the power cord. If it still does not work, you can try calling the Nintendo Help & Support. You can find the number by going to www.nintendo.com and clicking on the Help (or Support) link and finding a phone number.
Apr 29, 2009 | Nintendo Wii Console
System turns on however hard drive will not cycle nor will mouse or key board activate
Turn power off and unplug power from computer.
Unplug printers,backup drives and speakers.
Open case and unplug power supply from the board.
plug power cord back in press the power button.
Of course nothing will happen.
unplug power cord again.
plug power supply back into the board.
plug power cord backup and press power switch.
If nothing happens unplug power cord again.
pull out your memory sticks and plug cord back in and press power button.
Of course not much will happen.
But really something is happening to your computer so continue.
Pull power cord and replace memory sticks.
replace power cord and press power switch.
Continue this pulling out pci cards one at a time until you find out what the problem might be.
Try different keyboards and mice too.
Good Luck
Oct 27, 2008 | Intel Computers & Internet
Televison & Video Logo
147 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
