Question about Electronics - Others
Memory stick problem
My customer is using Transcend Memory Sticker (Transcend 1GB). The problem is, it does open when he is trying to open it. It gives this meassage "The disk E is not formated, do you want to format Yes or No" He has a lot of information stored in it, he just doesn't want to format it. What must he do?
  • 1,006 Answers
Format it and recover data 100% from this program i posted here
And let me know if u got help!!!
Posted on Dec 05, 2007
Hi everybody, I have a problem installing a dimm SDRAM Module on a MoBo Syntax SVX 400. User Manual says that till 4GB modules are supported. I bought a Transcend 1GB PC266 SDRAM module to increase the...
One long beep signals a memory failure - the stick you just bought is faulty. BTW there is no PC266 in SDRAM the maximum is PC133. PC266 is the first standard that appeared for DDRAM. so you most likely have bought something not right from the start.
Feb 07, 2011 | Syntax SVX400 (SYSVX400) Motherboard
How do I use Transcend microSD, 1GB in an Acer Aspire Lap top? I have found where to place the Adapter in the lap top but not sure how to place it in (which side up) and how to place the memory card into...
Turn the computer off.
Insert the card one way, until you feel resistance, and measure how much of the card sticks out.
Then, remove it, turn it over, and insert the card again, and measure again.
Remove the card.
The smaller measurement is the instance where you correctly inserted the card.
Turn the computer on.
Open "My Computer".
Correctly insert the card.
The "My Computer" window will update, in less than 30 seconds, to reflect that the card has been detected, and Windows has been configured to access the card.
Double-click the changed icon, to "open" the files/folders that exist on the card's memory.
Nov 23, 2010 | PNY 1GB microSD Memory Card
Conflicts of RAM and motherboard
well unfortunetly it seems as though your RAM may be bad or not compatible. My suggestion is to go to and use their easy memory finder to see what is best for your system. Then look for it else where like or tiger direct, etc. There isn't a whole lot that you can do to fix RAM like that to make it work with a system predefined by the maker.
May 06, 2010 | ASUS P5V800-MX Motherboard
Problems with memory sticks and motherboard
see my website theit is solution
Apr 13, 2010 | ASUS P5V800-MX Motherboard
Can't open files in sony memory stick pro duo 1gb.
did you reformat the memory disk before you put all the files in there? if you didn't, then that could be the problem.
Sep 05, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
The memory module you installed may not be the correct type. Try removing it and if the computer starts fine after that, the memory is either wrong for your computer, or it is a bad module.
Go to and run their memory scan tool. It will tell you the exact type of memory your computer uses. Compare that information to the sticker on your memory module.
Mar 22, 2009 | Dell Dimension 2400 PC Desktop
1gb memory stick
the obvious are that it's bad or not seated right. The first thing I would try is moving the new stick to a different slot.
Mar 25, 2008 | Computers & Internet
Samsung D600 memory card format
When i insert memory card it says not allowed
Mar 03, 2008 | Samsung SGH-D600 Cellular Phone
Transcend JFV30 1GB
did you run the drivers for it?
Nov 30, 2007 | Transcend TS ABD4 Motherboard
Electronics - Others Logo
101 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
