Where is the water filter located we bought this a few years ago and have been getting an outside water filter because we could never find it we have a side by side GE profile with ice maker Thank you for your time
The water filter is usually located in the rear of the fridge behind the plastic panel. Looks like a oval cylinder. Sometimes when you buy a new one it will have a diagram on it to assist in chanigng
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
Thank you I tried calling the parts department and said they didn't have a clue...
" - cherswitz3
Need to know how to take off the broken piece of tubing and connect the new. Blue Valve assembly. ...
(More)
Need to know how to take off the broken piece of tubing and connect the new. Blue Valve assembly. Should be simple but I just can't see it.
need the hose that runs under and internally for my profile. Appears to be 1/4 ID and 3/8 OD. It's...
(More)
need the hose that runs under and internally for my profile. Appears to be 1/4 ID and 3/8 OD. It's brittle and leaking
temperature controls are out. Changed main control board but problem persists. fridge is still...
(More)
temperature controls are out. Changed main control board but problem persists. fridge is still chilling, ice works etc
I have a whirlpool side by side and the ice maker doesn't work the arm goes up and down but no water...
(More)
I have a whirlpool side by side and the ice maker doesn't work the arm goes up and down but no water seem to be running
