Question about Freezers
Traulsen 2 door freezer
I have a 2 door traulsen freezer, it runs fine but the motor is so LOUD, I can't hear myself think! I have had people tell me that this the way they sound, is this true? Thank you, Julie
  • Anonymous Apr 10, 2009
    Same here. Our freezer is crazy obnoxious!
    Please help!!
    Director Badge:
    Uploaded 100 video answers.
  • Freezers Master
  • 488 Answers
Traulsen Freezer Compressor Change Out Video
Posted on Jan 13, 2017
  • 40 Answers
No...this is not true.You may find that you will have to replace the compressor soon.If that's where the noise is coming from.
Posted on Dec 05, 2007
Traulsen G sereis 2 door freezer keeps running past set temp of "0" degrees keeps freezing all the way to -35 degrees and I have to shut it off to keep it from running? any advice??
It basically sounds like the temp sensor is not sensing the box temp that the control functions on. Other wise, the control may be stuck. Traulsen seems to have a fairly descent tech support line. Call them for steps on how to read the controller.
Feb 04, 2014 | Traulsen G-Series G22000 Solid Door...
Model g22012
If its the digital display with I think 2 or 3 buttons, then you cannot re-program the control.
It is factory set and I have never been able to get any clear answers from Traulsen on the steps to re-programming it for a different setting.
Best advice I can give you is to contact Traulsen directly and ask for tech support. Once you get them on the phone, explain that you just purchased this cooler/freezer and you need a control that suites your needs. They should have one that is pre-programmed to your needs.
Jan 07, 2010 | Traulsen 46 cu. ft. Upright Freezer G22011
How can I get the wiring schematic diagram for a two door stand up traulsen freezer model # GLT 2-32 NUT, Thanks Erick.
call traulsen at 1-800-825-8220. Get tech support and give them the model and serial numbers. They will send you a diagram. Nothing on their web site.
Oct 02, 2009 | Traulsen 46 cu. ft. / 1303 liter...
Our Traulsen Freezer will not hold the cooling agent.
Have someone out to do a nitrogen leak check on it. Sounds like a leak needs to be found and fixed. Hard to find leaks can be spotted by adding UV dye to the system.
Aug 31, 2009 | Traulsen Freezer G31010 Solid Door...
Very loud compressor in traulsen freezer
It's probably a hermetic compressor. Nothing can be done. It's got an internal rattle, possibly defective valves, or freon was avercharged.
Aug 02, 2009 | Traulsen 7 cu. ft. / 198 liter Commercial...
Freezer wont cool
This problem could be cause by a few things. Can you tell me if your condenser is clean? If it is dirty, the heat cannot be rejected. Will you feel the large copper line going to the compressor and tell me if it is cold to the touch? If it is not col and your compressor is running you may be low on refrigerant. Also, is the evaporator frozen over? If your evaporator is frozen over you might be low on refrigerant, or you evap fans may be out.
Feb 15, 2009 | Traulsen Freezer G22013 Freezer, Reach-in,...
Traulsen Commercial Freezer needs charging?
The refrigerant level is low. The only thing is that the unit may not have a low charge. There can be several things that cause the unit not to refrigerate properly. It could have weak valves in the compressor or even a bad TXV(thermostatic expansion valve). Have you had this box repaired yet.? I see that this is an old post.
Dec 09, 2008 | Traulsen 24.2 cu. ft. / 685 liter...
Freezers Logo
278 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
