Question about Canon FAX-L800 Plain Paper Laser
Canon L800 FAX
Hi Folks,
Can someone tell me where to change the Caller ID info and phone no that gets sent with each fax.
    New Friend:
  • 116 Answers
Posted on Apr 02, 2008
Caller ID not working on Norstar terminal using line dedicated to fax and phone
You must have latest software to have Caller ID
You must have a Caller ID line card
Caller ID must be programmed on the phone to allow it
Caller ID signal from carrier is sent between 1st and 2nd call
FYI on the fax: Analog ports (ATA's) on the Norstar system do not show Caller ID, instead you would need to use a line share device that supports caller id such as the STICK.
Oct 25, 2012 | NorStar M7310 Corded Phone
We have a Canon Faxphone L170. Someone sent a fax
On the controll panel there is a diamond shape picture with a eye in that bottom and clear the fax that you received.There is no other way.You will have to phone the sender and ask them to change the papersize settings on the fax machine.
Dec 08, 2009 | Canon FAXPHONE L170 Plain Paper Laser
I need to verify a received fax, but the connection tel column is blank (there is no number shown). How do I see who sent the fax at that time. There is a transaction number.. but how do I match this with...
It's possible that the originator has their number blocked (caller ID blocking). If that line is only used for the fax, I would try to learn the number using that same line and then using a phone, dialing *69 (in our area, yours may be different). If your service operates the same, you should get a voice message with the number and an offer to dial it for you.
Jul 15, 2009 | Canon LaserClass 2060P Plain Paper Fax
L800 manual
You can download the user manual for this, just go to this link
Dec 02, 2008 | Canon FAX-L800 Plain Paper Laser
Erased files
the problem is the fax that are stored in memory you will lose anyway.
you will need to do the following to get rid of your error:
and # button, on the operation panel
go down to number 8
then scroll round to ALL
and then restart the machine and the fault should go.
Hope this helps
Oct 23, 2008 | Canon FAX-L800 Plain Paper Laser
Canon Fax L800 dead?
there are fuses on the power supply board
Sep 02, 2008 | Canon FAX-L800 Plain Paper Laser
Is there a fuse inside the L800
You probably have a dead low voltage power supply.
There might be a fuse on it, but a blown fuse usually indicates a bad power supply.
When I send faxes the reciever gets a different fax caller ID
Ring 13 2600. Tell them you bought it (NOT SECOND HAND) and you lost the manual, Explain the problem and they should give you an answer for free!
Jan 28, 2008 | Panasonic KX-FHD351 Plain Paper Thermal...
How to set ringtone when receiving fax Canon Fax L800
Sep 19, 2007 | Canon FAX-L800 Plain Paper Laser
Changing the text on my fax.
Lift up the cover under the display and press the data registration key, push "set" then scroll down using the arrow keys and look for "user setting" push set, and I think you scroll to the option that says terminal id push set enter your new name and push set again then you can enter your fax number. at any time push the stop key to exit out
Jun 14, 2007 | Canon FAX-L800 Plain Paper Laser
Canon FAX-L800 Plain Paper Laser Logo
59 people viewed this question
old marine
old marine
