Question about Epson Stylus CX6600 All-In-One InkJet Printer
CX6600 error message
I took a part the printer to clean out some gum that found its way on the internal rollers. I cleaned it out and put it back together. But after a successful start up, when I go to print it pops up error message and orginally stated to check that something was stuck in the printer. Not it just say Error Check documentation of call for assitance.
I am pretty sure I put everything back correctly. Is there some kind of reset mechanism becuase it is remebering the problem when the gum was in there?
Thx for your assitance
  • Turt62 Dec 05, 2007
    Turt62 again. some additional info: It does take a long time to get to its ready state and I noticed that it sucked up a bunch of Black Ink. I had to put in a new cartridge
    Thx
  • 36 Answers
I suspect that a bit of gum may have traveled elsewhere into the printers internals. I'm sorry I can't be more helpful.
Just turning the printer off, pausing for 30 seconds, then turning it back on should reset it, but I'm sure you have already tried that.
Posted on Dec 06, 2007
I have a HP LaserJet 1312nfi that is giving me a FALSE paper jam message. I repeat - FALSE PAPER JAM IN BACK DOOR. False false false. I have uninstalled it on my computer and nothing. I have opened it...
Hello Chris! Welcome to FixYa!
If you are facing False Paper Jam error in your HP Laser Jet 1312nfi but If you cant see any obvious paper jams, try to look closely into the rollers or the inside. There could be some tiny paper shreds stuck within those rollers. Or there could be a tiny piece of paper blocking the printer's sensor and thus giving you a false paper jam error.
The rollers should be cleaned if the paper fails to feed smoothly into the unit. All document and media rollers should be cleaned using a lint-free cloth lightly moistened with water.
1. Turn Off the printer and unplugged power before cleaning the rollers. This will allow the rollers to be turned by hand in most cases.
2. Remove the rear access door to access the rollers. Clean any dust and debris from the rollers.
3. Open the back of the printer and check metal paper rollers (not the rubber rollers) in the interior of the printer. They should be clean and move freely. If these are not bright and shinny or have buildup on them, they should be cleaned. Also clean any dust and debris off of the rubber rollers.
4. Close the back cover and reattach the rear access door.
5. Plug the power cord back in and power the unit up. It should reinitialize for about 20 seconds.
6. Print another extended self-test page.
After following these steps carefully, False Error message will be disappeared.
I hope this solution helps you
Let me know if you have any confusion in your mind.
Sir, Your Rating as FIVE Stars for this solution and words of appreciation will be esteemed
Thank You for taking my service
Concerned: Muhammad Uzair
Jan 10, 2012 | HP Officejet Pro L7680 All-In-One Printer
I had a cannon LBP2900 printer. IT has a problem of paper jam. It prints very well in A5 paper but hen i try to print in A4 paper, the paper gets jam. It also makes some cracking sound and i found some...
Without doing a complete disassemble, remove all covers, remove paper tray(s), remove ink cartridges (or laser cartridges...everything that is EASY to remove. Clean your rollers (may be gummed up a bit), remove all dust, dirt, grime, everything. My Canon printers are extremely sensitive to jams. As long as you keep it clean internally, you should have no problems. Take a look at this video about paper jams.
Nov 30, 2017 | Canon LASER SHOT LBP-2900 Printer
HP C4280 draws a sheet of paper into the printer, paus;es, and then gives me a paper jam message. I have followed some of the suggested remedies from web sight but no success. Found light dust on rollers...
If this has not been done yet. open up the top cover and remove the print cartridge and trays. You should then gain access to the internal parts and roller. Inspect for debris. Clean out the internal parts using isoprophyl alcohol. Let me know if this works.
May 09, 2011 | HP PhotoSmart C4280 Laser Printer
6c10 errror message on canon mp640, tried suggested moving of printcartridge holder, no go. Any suggestions?
Hi, I solved this by doing a "cleaning roller" (dont know the right word in english) from the settings -> maintenance menu of the MP640. Good luck!
Oct 24, 2010 | Canon MP640 All-In-One InkJet Printer
Drum error
Yes, you should replace the drum unit if you have not done so. You may have a broken corona wire or drum. However, keep in mind that you will need to reset your machine after changing the drum unit. If after replacing, you still get the same error, you may have a problem with your machine properly sensing your drum unit.
Jan 03, 2009 | Brother IntelliFax-2820 Laser Fax
I am reciving error code e000064
error code e000064 indicates machine having problem with transfer roller , black roller found underneath drum unit. it may require replacing or needs cleaned being soiled . this area require technical experts as transfer roller operates on high voltage . hope this helps
Oct 01, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Epsom C62
Try putting your question in the correct section: Epson C62. This section is for the CX6600 and is not appropriate for your machine.
Jul 02, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Service required error
plz go to printer setting & clean durme
Mar 03, 2008 | Epson Stylus CX6600 All-In-One InkJet...
'paper jam' error on canon pixma ip4300
Hi guys, I eventually found a solution to the problem for my printer. With the top cover open, I pushed a sheet of 120 micron thickness A4 clear plastic binding cover through the exit tray as far as it would go to rest against the bottom row of rollers. I switched the printer off then back on again and as the rollers lifted momentarily, I pushed the sheet of plastic as far up through the machine as I could before the rollers went down again - it went in a fair distance. The printer then ejected the plastic sheet. I then put the plastic sheet into the paper tray and tried to print a blank document page. The plastic fed through cleanly and my printer has been working since without any error messages. I hope this works for you.
Aug 22, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Epson Stylus CX6600 All-In-One InkJet Printer Logo
143 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
