I have installed the 4 cameras and I ran the camera cable to the monitor but cannot get a picture from the cameras. The screen is flashing "L" in all four sections of the quad. What am I missing?
Thanks.
1. Connect LAN cable of Cable/ADSL modem or Direct Fixed/Static IP LAN Line to WAN port of IP Router.or hub/sw with cable/lan terminal
2. Connect LAN ports of IP Router/switch/hub(1~4 or 1~8) to Ethernet port SMO-211QN/SMO-150QN to be set up and to
Ethernet port of Local PC to use during setup.
3. Connect Video cable of Camera to MONITOR.
4. Turn on the MONITOR power.
This a basic setup local no internet static ip you will have to
follow directions for setup in the software program you install
on the computer the uset the computer. The computer connected to the lan terminal
I am just giving you the basics you are goilng to have to read
and understand the rest as far as the rest of the setup on the
computer This is from page 107 of your manual
Link to manual if you dont have it
http://www.retrevo.com/s/SAMSUNG+SMO-211QN+users+manual+?sub.x=75&sub.y=14
oops I see you are attempting to test the cameras you
need to change from quad mode to single mode and
test each camera separately, re check you settings
on each one,and after all your settings & connections
are correct for each camera/channel the switch to
quad mode I hope we are are on the same page here
page 49 shows the control buttons
if you dont have a mode switch or
chan switches on the monitor itself
then you will have do the setup
on the computer
You may have the corrsponding buttons on
your monitor or at least the mide and channel
buttons
When you say the 4 sections of the quad are flashing "L" are you looking at the monitor or looking at it over the network?
When I said that the 4 sections of the quad are flashing "L", I was talking about the monitor that came with the system.
