In Dash Receivers
Problem for In Dash Receivers
Generic problem for all In Dash Receivers
Multi media car stereo install
By valco on Dec 05, 2007
I would like to know how to install the tv ant. and the braking line for a xovision xod1730
Comments:
Dec 08, 2007
- the instruction booklet from xovision no help
Dec 09, 2007
- ok the braking line gos to the brake if that is so that answers one ? on the tv antena there is two leads one apeares to be a ground the other has a clip is it even needed? is it better to mount the ant inside or out ?
Best Solution
posted on Dec 05, 2007
Very Helpful)
tech8
Rank: Wiz
Rating: 83%, 121 votes
I would not recommend doing this yourself unless
you have installed systmes before.the link below
has the wiring code for the tv the techician will
have a wirilng diagram of your vehicle (both are needed)
Link to manual http://www.xovision.com/pdf/Microsoft%20PowerPoint%20-%20XOD1730manual.pdf
Comments:
Dec 08, 2007
- Did you not see the wiring diagram with color code as I told
you need the wiriing diagrams for you vehicle also unless you
know the color and location of the brake wire you need
Dec 08, 2007
On page 3 left hand side
Get it done right and
guaranteed
Dec 09, 2007
- Ok if you know you can make it from here
then go for it (although everbody warned you not to)
any changes to cables or opening of case may void
your warranty wires need to be properly terminated
needs to look professional.If you have an antenna
lead that you can match up then try it
I need to get this rated they keep sending me back
Rating Locked! (?) valco has rated this solution as Very Helpful
Solution #2
posted on Dec 08, 2007
Not Rated)
eagle338
Rank: Wiz
Rating: 84%, 1646 votes
IT is on the 3rd page of this manual... IT is shown in a clean wiring diagram and is titled instructions..
Comments:
Dec 09, 2007
- The clip you are speaking about is not included in the connection procedure so dont worry about it.. As for the antenna, you should install the radio antenna outside and tv antenna will do just fine even if you have it inside..
Solution #3
Not Rated)
CLUEPATEL
Rank: Guru
Rating: 86%, 125 votes
I think you should go to the CAR Audio/Video system expert and get it! thats it!
Solution #4
Somewhat Helpful)
shivam4529
Rank: Wiz
Rating: 77%, 113 votes
i think your prob is not simple if anybody tell u do this or tat don't do it because i have a same prob but my fault is try myself and it becomes more disable and father beaten me
so acc to my opinion go to the expert and where u buy this he normaled your problem don't worry i do the same thing
and u again enjoy
WARNING:
DO NOT OPEN YOURSELF
IF U HAVE TRUST ON ME MY ID IS
mango4529@radiffmail.com
Popular Solutions for In Dash Receivers
Questions and Unsolved Problems for In Dash Receivers
Answer
i hooked everything up just like the manual said and it worked fine before i mounted it in the dash... (More)
Answer
My unit Sony CDX-M800 unit (discontinued) is nearly eight years old so I am not surprised it is... (More)
Answer
My headunit is powering up but i get no display....jus lights....... The unit is an insignia NS -... (More)
Answer
Is it ok to run 2 remote turn on wires from 2 amps to one head unit?
Answer
IS 2 HAND AND DO NOT KNOW COLOR GUIDE TO SPEAKERS , POWER AND GROUNDS SONY XPLOD CDX-GT100
Describe your In Dash Receivers problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top In Dash Receiver Experts
Top Audio & Video Equipment Repairmen
in , MD
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
