Question about Mitsubishi WS-55813 55" Rear Projection HDTV
Mitsubishi Model 65713 - Timer Button Light Blinking-TV Won't Power On
Possible power surge.
Timer Button Light Now Blinking
TV Won't Turn On
- Have tried System Reset Button - And TV Still Won't Turn ON
- I have unhooked TV completely and tried reset several times
Questions:
- Is there anything more I can do?
- My source of purchase says this TV must be returned to shop
(Transportation costs $100/Minimum Labor-$395/Plus Parts)
- Shouldn't a field visit in home be the first step by a reputable sales dealer.
Thanks - Bill Bowman - W1942B@yahoo.com
    President:
  • 4,402 Answers
Open the back with the unit unplugged and see if any of the fuses are blown. if not the home service and let the tech decide if it should go into the shop
Posted on Dec 05, 2007
I have a Mitsubishi WS-55909 projection TV. There was a power outage and when the power came back on, the TV won.t turn back on again. There is this light (Timer) that keeps on blinking on the front panel...
Unplug,replug the tv back like 24 hrs later.That the whole tv is resetting itself everythings.Tv now should be working again.If still have the same problems,than ur tv DM power supply board is have dying parts,must repair the tv DM power supply board to fix the tv.
Mar 21, 2011 | Mitsubishi Televison & Video
Mitsubishi WS-65713 Blinking green light. TV will not turn on!
These Mits TV's tend to have power supply problems that are well documented on the web, when the symptom is as you describe. And this assumes no other unusual noises were heard before the TV went into shutdown.
The repairs are fairly straight forward if you are comfortable with electro-mechanical dis-assembly, soldering repair, and re-assembly.
Just do a search on Mitsubishi (your model number) and capacitors.
Dec 21, 2009 | Mitsubishi WS-65713 65" Rear Projection...
Possible power surge earlier today. TV will not
If your TV was plugged into a power strip with a surge arrestor, the power strip may need a reset (if there is a reset button) or replacement (those surge arrestors are only good for so many "hits". Try plugging the TV in elsewhere.
If it was not plugged into a surge suppressor, it is time to call a repairman.
Oct 07, 2009 | JVC AV-20220 TV
Blinking timer light will not turn off.
Pull out the power cord from the outlet for about one minute and then replug it. The blinking will restart for about a minute or less and then the set will turn itself off. You will then be able to turn it back on in the usual way with the remote or power switch.
I believe this is caused by a power surge or a momentary power outage.
SG
Dec 28, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Green blinking light
The DM module in the TV is bad. Some can be fixed easily some cannot. What is the model #?
Sep 11, 2008 | Mitsubishi WS-65713 65" Rear Projection...
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source)
Sep 23, 2007 | Mitsubishi WS-65713 65" Rear Projection...
Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Sep 22, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Mitsubishi WD-52525 Status Light --- blinking red constantly.
possible that over night your set took a power surge ,possible power supply fault.
Sep 12, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WS-55813 55" Rear Projection HDTV Logo
110 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
