Question about X-10 (RTM75) Transceiver
Tm751 My TM751s activate with every command from my remote but do not send a reliable X10 signal to appliance or lamp modules even on the same circuit even though the TM751 relay kicks in every time. Whats wrong. (FWIW I have an MSEE degree)
  • 1 more comment
  • oneoldurn Dec 05, 2007
    appliance or lamp module--no difference
    TM751 and the other modules are plug-in ---no batteries. Other channels,same result.
  • oneoldurn Dec 06, 2007
    Marginally better but never consistent.
    President:
  • 4,402 Answers
Is it an appliance module x10 otherwise it's not strong enough
Posted on Dec 05, 2007
  • 1 more comment
  • Cary Farah
    Cary Farah Dec 05, 2007
    do you have new battery's ? and have you tried a different channel?
  • Cary Farah
    Does it matter if you move it to a different location?
  • Cary Farah
    Cary Farah Dec 06, 2007
    I think you have a bad unit
I have a 2013 GMC Sierra 1500. Where is the signal light control module LM487 located? I have the knee bolster off but still can't locate it.
signal light control module LM487 ???? How did you come up with this ??? Your vehicles BCM - body control module controls the hazard an turn signals . Turn Signal/Hazard Lamps
When the turn signal switch is placed in either the left or right position, a ground signal is completed from the turn signal switch to the BCM. When the hazard flasher switch is activated, a ground signal is completed from the turn signal/hazard switch to the BCM. The BCM then sends an ON-OFF voltage signal through the fuses to the appropriate turn signal and side repeater (export only) lamps or to all of the turn signal fuses for hazard operation. The driver door switch and passenger door switch also receive voltage from the BCM turn signal supply voltage circuits for the mirror turn signals. The door switches have no function or control of the mirror turn signals other than a pass through connection for the circuits. The audio chime is also activated when the turn signals are ON. The instrument panel cluster (IPC) receives the signals to activate the turn signal indicators over the GMLAN serial data system. When the hazard switch is pressed, all turn signal lamps will flash including both IPC turn indicators.
Your best bet , take it to a qualified repair shop .
Nov 29, 2017 | GMC Sierra 1500 Cars & Trucks
2008 CTS trunk won't unlock
Hi Jeff,
I was going to say, check fuse/ jump the load side of relay Good post.
Mar 19, 2017 | Cars & Trucks
Head lights turns on 2hours after ignition is off 2005 Gmc envoy 4.2 l6
The headlamp driver module (HDM) is an electronic module that provides electrical power to the vehicle low beam headlamps. The HDM is controlled by a pulse width modulated (PWM) ground signal from the body control module (BCM). The BCM determines the desired lamp intensity using the ambient light sensor, multifunction switch and the park brake switch as inputs. In general, the HDM will operate in 1 of 3 modes:
Your best bet have it checked by a qualified repair shop ! May have DTC'S diagnostic trouble codes .
DTC B2575
DTC B2575 Headlamp Control Circuit
When the body control module (BCM) senses a request for headlamp or daytime running lamp (DRL) illumination, the BCM sends a pulse width modulated (PWM) ground signal to the low beam headlamp driver module through the low beam headlamp driver module control circuit. The low beam headlamp driver module will illuminate the headlamps, adjusting the intensity based on the PWM signal received.
DTC B2580 Headlamp High Beam Control Circuit
DTC B2645 Ambient Light Sensor Circuit
The body control module (BCM) monitors the ambient light sensor signal circuit in order to determine if the daytime running lights (DRL) or the auto headlights (ALC) should be turned ON in the AUTO mode. When the BCM senses the ambient light sensor signal voltage is between 1.75-4.9 volts, either the DRL will be commanded ON or the ALC will be commanded ON depending upon the amount of light received by the sensor.
Feb 04, 2017 | 2005 GMC Envoy
Just got my 2003 explorer sport trac dome light dont come on when you open the doors but they come on when you push the button to turn them on how do I get them to come on when I open the doors?????
The instrument cluster illuminates the interior lamps when an unlock signal is received from the vehicle security module. The illuminated entry feature will be canceled when any of the following conditions are met:
  • 25 seconds have elapsed since the illuminated entry feature was activated and the interior lamp control is not activated (door ajar or courtesy lamp switch on).
  • The instrument cluster receives a request from the vehicle security module (remote transmitter lock button pressed) and the interior lamp control is not activated.
  • The ignition is in the RUN or START position and the interior lamp control is not activated.
The instrument cluster illuminates the courtesy lamps when any door is open or ajar. The courtesy lamps shuts off when the doors are closed and the illuminated entry feature is not active or when the vehicle speed is greater than 5 mph (8 km/h). The interior lamps are not reactivated until the vehicle speed is less than 3 mph (5 km/h) and a new door open warning lamp signal is received.
The instrument cluster controls the courtesy lamps illuminated entry function by activating the battery saver relay.
The panel dimmer switch is integrated into the headlamp switch and controls the interior lamps by activating the instrument cluster through circuit 1034 (BK/WH).
The vehicle security module sends a signal to the instrument cluster on the UBP network circuit to indicate a request to turn the illuminated entry feature on or off.
The on-demand lamps, glove compartment assembly, homelink module, puddle lamps and illuminated vanity mirrors are controlled by the battery saver relay. The battery saver relay becomes active (relay coil is energized) when the instrument is in the awake mode, or in the sleep mode (relay coil is de-energized).
Nov 28, 2016 | 2003 Ford Explorer Sport Trac
The fuse for a right turn signal on a 2001 Buick Park Avenue
The left an right turn signals get there power from same fuse ,HZDT/SG fuse 15amp in the left under hood fuse box. through the turn signal hazard flasher module. Here is how they work .
Turn Signal/Cornering Lamps
The HZDT/SIG fuse in the fuse block - underhood - left supplies battery positive voltage to the turn signal/hazard flasher module and have ground at G202. The turn signal lamps may only be activated with the ignition switch in the ON or ACCY position. The T/SIG fuse in the fuse block - underhood - left supplies battery positive voltage to the turn signal switch. When the turn signal switch is placed in either the left or right position, current flow is from the turn signal switch assembly to the turn signal/hazard flasher module. The turn signal/hazard flasher module then sends an on-off voltage signal to either the left or right turn signals and their instrument cluster (IPC) indicator. When the hazard switch is pressed, all the turn signal lamps will flash including both IPC turn signal indicators. The left turn signals have ground at G106, G400 and at G402. The right turn signals have ground at G105 and G400. The turn signal switch supplies battery positive voltage to the cornering lamps, the left cornering lamp has ground at G105 and the right cornering lamp has ground at G106.The turn signal switch or the turn / hazard flasher module is bad or there is a wiring problem. Go to you tube an check out a few videos on basic electrical testing ,then get a DVOM - digital volt ohm meter , an wiring diagram an trouble shoot the circuit . There may even be a video on test turn signal circuit .
Dec 04, 2015 | Buick Cars & Trucks
I have a 2004 Silverado and when I open the passage door none of the inside lights come on but the drivers side does please help
The left and right front door courtesy lamps are controlled, and receive voltage and ground from the drivers door module (DDM) and the passenger door module (PDM) respectively. The body control module (BCM), DDM, and the PDM communicate through class II serial data for the lamp illumination commands and the door ajar switches.
The remaining courtesy lamps are controlled and receive voltage from the BCM. Voltage for the courtesy lamp supply voltage circuit and the backup lamp supply voltage circuit is from the TBC B fuse in the instrument panel fuse block directly through the BCM to these circuits. A short to ground on either of these circuits will open the fuse. Ground is provided to the footwell lamps and all courtesy/reading lamps at G203. Ground is provided to the right middle and right rear door at G306. Ground is provided to the left middle and left rear door at G302.
There could be a DTC - diagnostic trouble code stored in the BCM
DTC B2615
The body control module (BCM) receives a ground signal from the door jamb, liftglass/liftgate if equipped, or courtesy lamp switches requesting courtesy/dome lamp illumination. When this occurs, the BCM directly sends a voltage through the courtesy lamp supply voltage circuit illuminating the courtesy/dome lamps.
Voltage for the courtesy lamp supply voltage circuit as well as the backup lamp supply voltage circuit is from the left instrument panel fuse block TBC 2B 15-amp fuse directly through the BCM to these circuits
DTC B3801
The body control module (BCM) monitors the courtesy lamp switch signal circuit in order to determine when the courtesy/dome lamps should be illuminated. When the BCM senses that the courtesy lamp switch signal circuit is grounded when the switch is activated, the BCM will illuminate the courtesy/dome lamps.
Inspect the following related body control module (BCM), driver door module (DDM), and passenger door module (PDM) data parameters. Refer to Scan Tool Data List or Scan Tool Data Definitions for typical values and definitions:
The courtesy lamp switch
The interior lamp defeat switch
The door ajar switches
Was a problem found?
Go to Step 7
Go to Step 10
Oct 20, 2015 | Cars & Trucks
Where's is the fuse located for my brake lights on my 2007 Pontiac g6 and rear defrost fuse
Stop Lamps
your br
The brake pedal position sensor is used to sense the action of the driver application of the brake pedal. The brake pedal position sensor provides an analog voltage signal that will increase as the brake pedal is applied. The body control module (BCM) provides a low reference signal and a 5-volt reference voltage to the brake pedal position sensor. When the variable signal reaches a voltage threshold indicating the brakes have been applied, the BCM will apply battery positive voltage to the stop lamps, transmission control module (TCM), engine control module (ECM), and stop lamp relay coil side. When the stop lamp relay receives battery voltage from the BCM, the relay coil is energized and the stop lamp relay switch contacts close applying battery voltage through the STOP LP fuse to illuminate the center high mounted stop lamp (CHMSL).
I'd say you have more then a bad fuse ,just reading how the brake lights function .You should have it hooked up to a professional grade scan tool ,one that can check for DTC'S - diagnostic trouble codes in the BCM - body control module !
  1. Install a scan tool.
  2. Turn ON the ignition, with the engine OFF.
  3. With a scan tool, observe the Brake Pedal Position Sensor parameter in the data list for the body control module (BCM).
  4. Apply and release the brake pedal.
Does the scan tool display a change in the voltage?
DTC B3903 Stop Lamp Relay Circuit DTC C0277 Brake Pedal Position Sensor Circuit
DTC C0278
Did you perform the Diagnostic System Check - Vehicle?
Go to Step 2
Go to Diagnostic System Check - Vehicle
Does the scan tool display DTC C0278 00?
Go to Step 3
Go to Testing for Intermittent Conditions and Poor Connections
Recalibrate the brake position sensor.
Circuit Description
DTC C0870
The body control module (BCM) applies a ground through the brake sensor reference low circuit to the brake pedal position (BPP) sensor. The BCM supplies a 5-volt reference through the brake sensor reference voltage circuit to the brake position sensor. When the brake pedal is being applied, the BPP sensor then sends a variable voltage signal through the brake sensor signal circuit to the BCM.
Circuit/System Verification
  1. Ignition ON, observe the scan tool Brake Lamp Cmd. parameter as you apply and unapply the brake pedal. The parameter should change between OFF and ON as the brake pedal is applied and released.
  2. ?‡'
    If the parameter does not change as the brake pedal is applied and released, refer to Brake Pedal Position Sensor (BPPS) Malfunction.
  3. With a scan tool, command the LR Stop/Turn Signal Lamp ON and OFF. The LR turn signal should turn ON and OFF when changing between the commanded states.
  4. ?‡'
    If the LR stop lamp does not illuminate when commanded, refer to Stop Lamps Malfunction.
  5. With a scan tool, command the RR Stop/Turn Signal Lamp ON and OFF. The RR turn signal should turn ON and OFF when changing between the commanded states.
If the RR stop lamp does not illuminate when commanded, refer to Stop Lamps Malfunction.
I
I'd
Sep 26, 2015 | Pontiac Cars & Trucks
Bought a ouse that has an X10 PAM02 3 Pin Appliance Module connected to the recirculating pump for gas water heater. It's set on a code/letter but need to reprogram and can't find a manual etc. Can anyone...
Why would anyone feel the need for remotely controlling a circulation pump? The appliance module can control a motor rated up to 1/3 hp. The letter is the "house code" and the number identifies the unit, in this case the pump.
Nov 01, 2013 | X-10 Pro 100 Pam02 3pin Agc Appliance...
Left turn signal lights are not working
In my case the left front turn indicator lamp worked, but not the left rear indicator, although all the lamps would turn on with running lights activated, as well as the backup light and 'night-light' mode. The left rear turn indicator would not work with the hazard lights activated. I tested the combination switch (this is the left/right turn indicator switch you use when driving to indicate which direction you are going and is mounted/located on the steering column) and it tested O.K.. I had good continuity from the combination switch black wire, and resistance on the blue-white wire from there to the left rear turn indicator lamp, as well as good continuity on all wires going out from the left parking light fuse. Since the Haynes manual indicated that the flasher module was probably good if it made the tell-tale clicking sound, I was feeling perplexed. So I took it into a local shop that specialized in auto electrics and it turned out to be the flasher module. I was under the impression that it operated in a straight-forward left-right manner, but apparently it has a different circuit for each turn indicator lamp. So even if it is making the appropriate clicking sound when the combo switch is flipped, it could still be the flasher module. Obviously the manual leaves a bit to be desired in the troubleshooting of malfunctioning turn indicators.
Sep 07, 2012 | 1998 Dodge Caravan
2003 Yukon XL Denali Trailer Light Problems
Lighting control module ? ?????? Hazard / flasher module ! Now ( there''s not even an electrical signal where the fuse plugs into the interior fuse panel.) What FUSE ??????
Stop Lamps
The STOP LP 25 A fuse in the underhood fuse block supplies battery positive voltage to the normally open stop lamp switch. When the driver presses the brake pedal, the switch contacts close and battery positive voltage is supplied to both the STOP 15 A fuse and the CHMSL 10 A fuse in the I/P fuse block, and to the turn signal/hazard module. The turn signal/hazard module then supplies voltage to both of the trailer rear turn/stop lamp supply voltage circuits. The voltage from the CHMSL 10 A fuse is to the center high mounted stop lamp (CHMSL) and the trailer jumper harness. The voltage from the STOP 15 A fuse is to the stop lamps, throttle actuator control (TAC) module, and the cruise control.
Backup Lamps
The backup lamp request signal is sent from the powertrain control module (PCM) to the body control module (BCM) on the Class 2 message system. This signal is based on the park neutral position (PNP) switch signal. The BCM supplies voltage on the backup lamp supply voltage circuit to the backup lamps and to the automatic day/night mirror. Voltage for the courtesy lamp supply voltage circuit and backup lamp supply voltage circuit is from the TBC B fuse in the instrument panel fuse block directly through the BCM to these circuits. A short to ground on either of these circuits will open the fuse. The backup lamps are grounded at G401.
For trailer wiring, a separate backup lamp circuit is connected through the underhood fuse block from the TRLR B/U 10 A fuse to the trailer wiring harness.
The IGN E 10 A fuse in the underhood fuse block supplies battery positive voltage to the turn signal/hazard switch assembly. The FLASH 25 A fuse in the I/P fuse block supplies battery positive voltage to the turn signal/flasher module and ground is supplied at G200. When the turn signal switch is placed in either the left or right position, a voltage signal is completed from the turn signal switch to the turn sign/flasher module. When the hazard flasher switch is activated, a ground signal is completed from the turn signal/hazard switch to the turn sign/flasher module. The turn sign/flasher module then sends an on-off voltage signal through the LT TRLR, RT TRLR, LT TURN or RT TURN 10 A fuses in the I/P fuse block to the appropriate turn signal or to all 4 fuses for hazard operation. The instrument panel cluster (IPC) indicators receive voltage from the LT TURN and RT TURN fuses as well as the DDM/PDM for the mirror turn signals. The DDM/PDM has no function or control of the mirror turn signals other that a pass through connection for the circuits. The audio chime is also activated when the turn signals are on. When the hazard switch is pressed, all turn signal lamps will flash including both IPC turn indicators. The front turn signals are grounded at G100. The rear turn signals are grounded at G401. The Mirror turn signals are grounded by the DDM/PDM.
Do you know how to do automotive electrical circuit testing with a test light or volt meter ? How to read an use a wiring diagram to pin point testing points . ( connectors , fuse locations etc... ) How to use a power flow chart ? Here is a site for just such info .
http://www.bbbind.com/free_tsb.html Enter vehicle info . year , make , model an engine size . System click lighting , subsystem exterior lighting . Second diagram shows trailer wiring .
Electric Testing Techniques You Need to Know
Mastering Voltage Drop Testing with Pete Meier and Jerry Truglia
CHEVROLET 2007 SILVERADO TRAILER LIGHT TROUBLESHOOTING
Apr 07, 2017 | 2003 GMC Yukon Denali
X-10 (RTM75) Transceiver Logo
333 people viewed this question
Top X-10 Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a X-10 Computer and Internet Expert? Answer questions, earn points and help others
