Question about Casio Office Equipment & Supplies
Calculating percentages I have a Casio MJ 100. It seems incapable of accurately calculating percentages. If I type in 100 minus 20% it answers 400! Is it time to throw it away?
  • DIDYPRADO Aug 08, 2008
    CHANGE PERCENTAGE TAX RATE
  • Anonymous Sep 04, 2008
    tax change
How can i change or fix an exchange rate in Xasio JF - 100TE calculator
Posted on Jul 10, 2008
Type 100 x 20%, and then hit the minus button
Posted on Jun 20, 2008
WHAT IS THE FUNCTION OF MU BOTTON IN CALCULATOR CASIO MJ-120D?
It is used for calculating markup. For example, if you have an item at $100 and have a 20% markup, you get $120.
http://support.casio.com/storage/en/manual/pdf/EN/004/MJ-100D_MJ-120D_EN.pdf
Sep 20, 2015 | Casio Office Equipment & Supplies
When I try to make 100 + 10% answer is 111.11111... and not 110, How do i correct it?
best way to calculate percentages quickly is to multiply base number (100) by 1.xx (where xx is the percentage desired - here it would be 10 or just 1)
100*1.1=110
Works on every calculator every time.
Mar 03, 2015 | Casio MS-10VC 10-Digit Display Calculator,...
Minus 20% of 175.00 using the percentage key
On most Casio calculators you must type: '175 x 20 % -' (and '+' is for adding a percentage)
Feb 18, 2015 | Casio MS-80S Calculator
Casio fx-82ms calculator does not give me an answer when i use the percentage button . example if i type 0.25/ 100% i get 0.25 instead of the right answer 25
Here is a sample of the percentage calculations that the calculator can perform. You will not see among them the conversion from decimals to percentages.
To convert from decimals to percents move the decimal mark 2 places to the right and append the % sign.
To convert from percents to decimals, move the decimal mark 2 places to the left.
Sep 28, 2013 | Casio FX-82MS Scientific Calculator
I have a Casio FX83ES Scientific Calculator and I am trying to work out 1 out of 1700 as a percentage using it. When I type in 1/1700 I get 1 over 1700. I press S<>D and then I get...
1÷1700 expressed as a decimal is 0.000588235, which is 5.882...×10^-4. [NB not 10^4]
To convert this to a percent, remember that "per cent" means "per 100" which also means "divide by 100". To keep the answer correct, if you are dividing by 100 you must also multiply by 100.
The get the answer in percent, you must therefore multiply the previous answer by 100 to get 0.00588235 percent. (or 5.882...×10^-2 percent).
Mar 30, 2011 | Casio FX83ES Scientific Calculator
How change percentage (tax) rate on Casio-1100TV?
FINALLY figured out how to change the tax rate! Press AC. Press and hold the Rate Set (%) button UNTIL THE CURRENT TAX RATE IS DISPLAYED. Enter the new rate you want (such as 7.5). Press the Rate Set (%) button again.
Mar 05, 2010 | Casio Office Equipment & Supplies
How do I get this calculator to substract
Big calculators work a little different than handheld calculators. Like the above commentor explained, if you have a basic "whats 100 minus 20?" You have to entered as 100 + 20 -- And when you hit the minus button at the end, it will give you the total. 100 is the positive number, and the 20 is the negative number that your subtracting. Also you can hit 20 -- 100 + and get the same total because you entering 20 as the negative and 100 as the positive, just in reverse.
Jul 27, 2009 | Casio HR-100TEPlus Calculator
My calculator will not let me add or subtract percentages.
I have a Casino MS-80S and yea, the percentage works different. As example to take 100 and subtract 10%, this is what I do: 100 X 10% - and then I get the answer 90 after I press the minus key. To add the percentage instead, 100 X 10% + will give me an answer of 110, after I press the plus key.
Apr 04, 2009 | Casio HR8TM Calculator
Percenteg Function problem in my Casio MJ - 120 Model Calculator
I found it by myself, I can help you.
1. Press (AC)
2. Hold (Rate) for about 2-3 second
3. Press (Set / TAX+)
4. Input the tax rate
5. Press (Set / TAX+)
6. Hold (Rate) for about 2-3 second again
7. Press (Set / TAX+) again
And Then you can test the rate .
From Thailand
Mar 12, 2009 | Casio Office Equipment & Supplies
How to use %
From the manual:
Function: Keys
Answer
Percentage: 100 x 5% 100 x 5 % 5
Add On: 100 + (100 x 5%) 100 x 5 % + 105
Discount:10 - (10 x 20%) 10 x 20 % - 8
Ratio: 30 = 60 x ?% 30 (division key) 60 % 50
% change: 12 = 10 + (10 x ?%) 12 - 10 % 20
Mark-up: 25% mark-up of 120 120 = 25% 160
- 40 (profit)
Mar 03, 2009 | Casio MS-80TV Scientific Calculator
1,060 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
