Powers off after an hour or 2
TV powers off after an hour or 2. Took advice yesterday and took off the back, check all wired connections and all seem OK. Tapped in the circuit board but could not get the TV to shut off to isolate the problem area. HOWEVER< the second i moved the circuit board, the TV powered off...cannot find any dark areas anywhere on the board. with the back off, I can unhook it for about 5 minutes, plug it back up and it comes right back on for an hour or so....any suggestions?
    President:
  • 4,402 Answers
If the second you moved the board it powered off would really make it sound like a cold solder joint or loose solder connection
they are hard to find, take the board and tip it so you can see it and
move a plastic handle of screw driver over the solder joints while the set is UNPLUGGED and look for and old discolored solder joints and any hair line cracks you can even flex the board to see if you can find it... look very close it will be hard to spot.
Posted on Dec 05, 2007
My Vizio 42 M420SV Powers on the back off.
Suspect number one is of course the power supply board in the set, if look there look at the filter caps for ones like these:
Dec 04, 2012 | Vizio M420sv 42 Inch Class Edge Lit Razor...
I have a 61 inch rear projection TV. When moving we took the back off of the TV so that we could navigate it up the stairway to my new apartment. Once in the apartment we plugged it in and it wouldn't go...
Check ur power source?Yes,wait like about an hour later for the tv resetting back to it factory setting.Recheck all connections inside of the tv for loses or untighten connections?Make sure all connections are tighten and no damage to all the PCB boards tries again tv should work now.
Jan 14, 2011 | Hitachi 61SWX10B 61" Rear Projection...
I started having problems turning my pc on, seemed like the switch was going bad. It finally wouldn't come on at all. I took it to a pc repair shop, they told me the power supply, and motherboard were both...
Remove the 2 wires from the motherboard which connect the switch and start the PC by shorting the 2 pins with a screwdriver for 2 secs and see if it starts without failing. Cheers from Scott and plz vote
Jan 14, 2011 | Gateway 831GM PC Desktop
I have just bought an LG LED LCD 3D TV (model 42lx6500). I bought it yesterday and today I lost the picture, but still had sound. Turned it off and turned it back on and now I have no picture or sound! I...
WOW we bought 2 of those tv,s..... 1 from sears and and had lines through the centre.. took it back and went to future shop and bought the same. within hours of turning it then off and back on the tv would not work. woud act like the remote was being used and it was on the table. took it back and bought a sanyo... no more problems...
Nov 21, 2010 | LG 32LC7D Television
Dryer wont start. I have went through the wiring but....
If it won't do 'anything' you need to check the whole start circuit. You need a multimeter and some knowledge of electrical troubleshooting to do this. I can help you if you meet the above description...let me know
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 19, 2009 | Kenmore 63942 Dryer
Ps3
first adjust the wires that connect the h.d tv and the play station once those are connected to one tv and connecting to other tv may not fit to the same tv so by ad justing wires if your problem is not solve then change the wires it will come normally and dont put that wires to other tv
May 23, 2008 | Sony Playstation 3 (PS3) Console
Onkyo TX -601 Zone two stopped working
any luck with sorting out the amp?
Feb 24, 2008 | Onkyo TX-SR601 Receiver
TV powers off after an hour or so
Hi Chuck, intermittents will definitely try your patience, It`s obvious the problem is with a poor solder connection or loose plug/connection. It would help immensely if you would tell us make and model number of the set. From your description I would unplu AC cord flip the main board over, get a bright light and a magnifying glass and start checking your solder connections, I`ll bet you have several, check closely low voltage power supply area (where your AC cord attatches to the set) and the high voltage area where the flyback is (large plastic part with large red or black wire coming out of the top), your looking for connections that are cracked or dull grey (overheated) solder, if you need more help keep asking thats what were here for, good luck, BMW Rider
Dec 05, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
