Question about Vacuums
Cleaning the bissell powersteam cleaner
There is a clear plastic cover on the steam cleaner that attracts the carpet fuzz and when I finished cleaning the carpet I want to clean it out but can't figure out how to get to it.
    President:
  • 1,673 Answers
If you are talking about the cover over the nozzle asm, where the water is sucked uo, the are 2 screws, one on each side, take those off, you may have to pry some, but it will come off. When you put back on, at the top end, it should snap into place, then lower it and put the 2 screws back in.
Posted on Jan 30, 2008
How to unclog a bissell proheat clearview carpet cleaner?
Check your User's Guide for filter locations. Bissell Consumer Care 1-800-237-7691
Jun 23, 2014 | Bissell 1699 ProHeat Clear View Upright...
Looking for a bissell powersteamer pro heat carpet cleaner
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
zvnb
Jan 04, 2010 | Bissell 1699 ProHeat Clear View Upright...
How to operate bissell carpet cleaner.
Look at the Bissell web site. You can enter the model number and get the operator's manual for Bissell products.
http://www.bissell.com/
May 27, 2009 | Bissell 1699 ProHeat Clear View Upright...
How to clean clear plastic thing in front of Bissell ProHeat?
you may have to run it to soften the hair, then you should be able to go under it with a rag to clean it.
Apr 29, 2009 | Bissell 1699 ProHeat Clear View Upright...
Steam cleaner will not **** up water
Try checking the lint filter. It is located in the top clear plastic section (the section with the dial to switch from floor to tool use) and is on the underside. It is a small (1 inch section) red plastic filter with a door on it. Flip open the door and you will probably find that it is clogged with hair, carpet fibre, etc.. Clean it out and you should have suction once again.
Apr 08, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Which is the best caprpet steam cleaner mid priced?
I would recommend the Hoover brand. The Bissell's are very problematic, they have belts that break and issues with the heating elements. Hoover Steam Cleaners can be repaired and are simple to use. The price range is generally $180 - $300
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Jan 24, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell steam carpet cleaner
http://www.howtomendit.com/answers.php?id=76173
Jul 15, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissle will not let water out if Bladder
Check the vale at the bottom of the tank. Push it in and see if water comes out ok, also check to make sure the seal is on the valve asm. Check the pump belt to see if it broke. Could have a bad pump. Is the top cover seated against the base in the back, if it is raised up, then it also raises the tank so it can't work.
Apr 12, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell ClearView powersteamer carpet cleaner does not seem to be dispensing water in the pre-treat mode
Pretreating (optional)
Note: Pretreating is recommended to improve
cleaning effectiveness for heavily soiled carpet in
high traffic areas such as entryways and hallways.
A.
Spray the BISSELL Tough Stain Pre-treat formula
onto heavy traffic areas, soiled areas, or stains.
B. Allow to penetrate for at least 3 minutes.
Maybe isn't su[pposed to dispense water, just the Pre-Treat solution. Then after a few minutes, shampoo normally.
Mar 29, 2008 | Bissell 1699 ProHeat Clear View Upright...
Vacuums Logo
134 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
