Question about Creative Labs Zen Micro MP3 Player
Zen 6Gig Micro gone completely dead
The Zen Micro 6Gig was working perfectly then suddenly it wouldnt power up at all either when plugged in via usb to laptop or under its own battery power. The battery is ok as its been checked with another identical machine. We have tried taking out battery then replacing it and trying to power up again but no success. We have also tried powering it via usb with and without battery in. It is no longer under guarantee and Zen say they cant help as its out of porduction. Can antone Help?
  • Graham Brown Dec 06, 2007
    This zen micro can only be charged by usb from computer. It has no AC charger or a socket for one, unless there is an AC charger with a similar plug at the end that goes into the Zen as the lead that comes from the computer (which is like a "mini" usb plug?socket). Zen hasnt come on so far by taking battery out and plugging into laptop and pulling plug in and out several times at the Zen end.
    President:
  • 4,402 Answers
Take battery out, this works best if you have an ac charger,
but turn the on/off switch to on and plug the unit in keep plugging it in and out till it turns on this may only work for ac chargers.
Posted on Dec 06, 2007
  • Cary Farah
    Cary Farah Dec 07, 2007
    I purchaed a ac adaptor for mine and i think creative has one for 10 bucks. do you know of anyone that might let you use one?
Won't turn on at all
did you try charging it?
or maybe you could try a diffrent USB plug inn.
Sep 13, 2008 | Creative Labs Zen Digital Media Player
Creative zen v problems-frozen
If a reset does not work using the reset hole, then try this: First, back up all of your music and do this: Turn off the player and disconnect it from the computer. Then press and hold the play/puse button and turn it on simultaneously. The player should be in recovery mode. Scroll down and select format (all) and let it format. Then reload all of music back onto your player and it should work like new. Hope this helps!
Aug 25, 2008 | Creative Labs ZEN V Plus MP3 Player
Zen V Plus not charging and not recognized by windows
Turn off CPU, Unplug Power cable, And all usb devices, let it sit for about 20mins. Plug it all back in. Turn on the CPU! Also make sure if your device requires "DRIVERS" or if you have a CD download and install that before anything.
Aug 18, 2008 | Creative Labs Zen Micro MP3 Player
there is a restart button on the bottom but it is a very small hole so maybe use a toothpick to push the button
Apr 12, 2008 | Creative Labs ZEN Vision:M Digital Media...
Zen Touch
Plug the Zen into a self powered USB hub that is not connected to a PC and leave overnight. You may also use other devices such as a printer USB port etc.
It recharges very slowly over USB but it will recharge.
Apr 11, 2008 | Creative Labs Zen Touch MP3 Player
Creative Zen Micro not working at all
Try disconnecting it and then reconnect it back to your pc, it happened to me once and then it was completely dead, nothing happened after it failed to install.
Then I waited the next day and I was about to return it, and I thought that maybe it would work if I connect it and reconnect it back and yeah it worked. it installed successfully.
Let's hope that it will work everytime I connect it from now on, if not I'll probably return it. 'cause I just bought yesterday.
Apr 04, 2008 | Creative Labs Zen Micro MP3 Player
Dead Creative Zen M
Usually this problem is due to the firmware. When the firmware is updated to version 1.62.02, this problem usually will be corrected. The older firmwares have problems in recognizing the battery and allowing the battery to power the unit.
You will need a wall/AC charger for the operation. Plug in the wall charger and USB cable at the same time. Your Zen should power on when connected to direct AC power via the wall charger. Once it is powered on, connect the USB cable to your computer. Then begin the firmware download.
If your Zen does not power on when connected to the wall charger, your unit is dead and its time to replace it or get the motherboard replaced via one of the Repair services offered on this website.
If the upgrade button on the firmware window is not available, it is also time to replace your motherboard due to corruption of a chip on the board.
Mar 13, 2008 | Creative Labs ZEN Vision:M Digital Media...
Cant turn it on and PC cant read it...
Zen V is dead
"If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Dec 31, 2007 | Creative Labs ZEN V Plus MP3 Player
I Recently bought a Zen, and it works great. The only problem I found was that it freezes itself from time to time, and the best solution to this problem is on the bottom of your Zen, there is a very small Reset hole. With a needle or a toothpick, gently stick it in, and push lightly. This will allow the Zen to unfreeze, and return back into it's regular mode. All your files will be saved, and kept on to the Zen, so you don't need to worry about losing any of your files.
Any additional help, I'll be glad to answer!
-bananaboy101
Dec 04, 2007 | Creative Labs Zen V MP3 Player
Not getting turned on
Zen V is dead
Aug 21, 2007 | Creative Labs ZEN V Plus MP3 Player
Creative Labs Zen Micro MP3 Player Logo
61 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
