Question about Harman Kardon AVR 2550 Receiver
Harman kardon avr2550
Hi..please can you help
how do i hook up my hk2550 to a Bose (2 double cubes front and 2 singles to the rear) run through a Bose Acoustimass 5 Series III Speaker system
e mail
  • 77 Answers
SOURCE: harman kardon avr 7200.1 no volume left front speater
could be a few different things. if you have tried another speaker that you know is in working condition then it might be a connection on the amp itself or the terminal could be bad. does it look coroded or is there anything obstructing its connectivity?
Posted on Feb 18, 2009
  • 508 Answers
SOURCE: drivers for harman kardon en toshiba satellite P100
driver for Satellite P100-ST1071 here:
or try other model for P100-? from >downloads>model
Posted on Jun 05, 2009
SOURCE: my center speaker does not work with harman kardon avr 40
perform a test from the menu for speaker output.Your op manual will gude you thru this
Posted on Oct 07, 2009
SOURCE: taking apart harman/kardon subwoofer
turn the sub upsidedown, carefully remove the clear rubber feet (these are a dome fitted over a mushroom top), using the toothed gripper cutout of a pair of pliers (when closed it is the eye shaped opening visible on one side), grip the mushroom firmly but not so hard as to crush the mushroom and gently ease clockwise and anticlockwise (the mushroom is at one end of a clear plug blocking access to the four screws that hold the two parts together.
Be carefull to use the correct size screwdriver so as not to damage the screw heads as they are tight.
On reassembly, you may need to use glue to replace the rubber feet if the mushroom becames damages during removal.
Posted on Dec 11, 2009
  • 382 Answers
SOURCE: can I conect harman Kardon avr 230 to apple tv
Yes, although it (AVR) does not support HDMI only component video.
Connect the audio to the receiver and the video directly to the TV if you have inadequate video inputs, or want to take advantage of the HDMI.
Posted on Jan 01, 2010
Testimonial: "cheers, have a good year."
Best way to hook up Bose 901 series VI to a Harman Kardon HK3490
According to the HK site, "Stereo pre-amp outputs let you connect the receiver to an external power amplifier." So it's easy. Connect the Bose equalizer in the pre-out / amp in loop.
Nov 07, 2015 | Bose Audio Players & Recorders
Bose acoustimas double cube speaker
what the exact model # of the unit..?
Jun 17, 2008 | Bose Acoustimass 16 Speaker
I need to hook my dvd player to my harman kardon avr 210
Follow the DVD manual. What model?
Register and download the AVR210 manual for free at
This unit supports just about any option.
Mar 07, 2011 | Harman Kardon AVR 210 Receiver
I have a harman/kardon class 2 transformer model# 661520oo3ct. It was with my computer equipment but not hooked up. I don't remember what it was for. what uses does it have?
it comes with ur desktop speaker harman kardon hk 206. it is a 12v 1A dc power supply. u can use it in any equipment which needs that power rating. only thing to remember is, check the polarity of both before connecting.
Dec 17, 2010 | Harman Kardon HK206 Computer Speakers
My Harman Kardon AVR 254 is not responding. None
I am having the same problems with my AVR 254, did you find a solution?
Mar 15, 2009 | Harman Kardon AVR 325 Receiver
Front bose speakers and bass module stopped puttimg put sound
If you're saying you hooked the Bose speakers directly to the Yamaha's amp instead of the prescribed way through their own bass module - they're cooked.
Dec 23, 2008 | Bose Lifestyle 12 System
AVR 120 5.1 -dolby surround sound & logic 7.
The problem is fixed...
and every thing sounds great !!
Thanks for the premium assistance to help solve my problem...
Dec 07, 2008 | Harman Kardon AVR 120 Receiver
AVR 7000 audio/video receiver
Harman kardon amplifire are known for that.specially AVR 7000
but sometimes this comes from poor wiring and using a wire that will not conduct better sound. Remember your wiring is very may think your wiring is currect, better to double check. even if your connection is ok and the wire you are using are not better to produce quality sound you will not get sound from every speaker.
good luck
Feb 28, 2008 | Harman Kardon AVR 7000
Two amp
I don't know why you'd set the Peavey to 2 ohm to drive 8 ohm speakers??? My other thought is... I wonder if the phase is correct. try reversing one of the speaker wires Left or right side.
Feb 27, 2008 | Harman Kardon AVR 630 Receiver
Harman Kardon AVR 2550 Receiver Logo
208 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
