Question about IBM Corded Phone IBM412CID
No ringer Had to unplug phone to move it and now dnd feature will not shut off and as a result, I have no ringer.
  • 300 Answers
I would suggest unplugging the phone from power and the phone jack for about 5 minutes and see if that will clear the DND LED.
Here is a link to the manual.
http://www.wedophones.com/Manuals/Aastra/IBM-412CID%20Four%20Line%20Phone%20User%20Guide.pdf
Please refer to Pg 38 specifically for disabling DND.
Thanks
Posted on Jul 28, 2008
How do I turn the ringer on
It depends on the model and why the ringer is off. All of these solutions require the phone to be in standby mode. If your phone has the Uniden Do Not Disturb feature enabled, you need to press the DND button on the base. If your Uniden phone has a Silent Mode, press and hold the # key (below 9) on one of the handsets. You'll need to hold the key for ~5 seconds. These options will toggle on the feature when it is off.
If the ringer is merely muted, press the volume up key.
I hope this helps. If you post a comment with the model of your phone, I can tell which feature is offered for that phone.
Jun 07, 2015 | Uniden DECT 6.0 Cordless Phone
Toshiba DKT2020SD - How do I turn the ringer on?
Here is a link to the manual. I looked through it and did not see anything specific that turned off the ringer except for the "DO NOT DISTURB" feature on page 43. You could try the deactivate DND procedure and see if your ringer comes back.
http://toshibamemphis.com/images/CTX_DKT_Telephone_User_Guide.pdf
Dec 25, 2014 | Toshiba Lands Phones
How to turn off ringer at particular extension?
Do Not Disturb (DND)
When DND is enabled, the telephone will not ring when someone calls, but the line
indicator still flashes. In Personal Call Manager, the
You Have a New Call dialog box
still appears and the icon for the call appears in the Calls box.
You can turn the Do Not Disturb (DND) feature on or off from the
Calls menu or the Personal Call Manager icon in the task tray.
Turning DND on or off
To turn DND on or off:
1. Click the Personal Call Manager task tray icon or the
Calls menu.
2. Click the DND menu item.
When DND is on:
• the Personal Call Manager task tray icon changes to
• the symbol check
appears beside the DND menu item on the Calls menu and the
Personal Call Manager task tray menu
• DND appears in Status bar
Oct 23, 2013 | NorStar Meridian M7310 Phone
How do I turn ringer on, on Nortel T7316E
Hi Have you set your DND (Do Not Disturb)?... on.
Try pressing Feature #85....
That should take of DND... or if you have 'Call Forward' set
Press Feature #4.
Hope this helps
Nov 04, 2010 | Lands Phones
I want to disable the DND feeature on Norstar M7324 phones.
Leave the handset in the cradle and press:
Feature (star) 1
Press the DND button
Press Rls
This is the feature code to add a Speed Dial # to a button, but by not entering a number, it just blanks the button. Goos Luck!
Jan 21, 2010 | NorStar M7310 Corded Phone
My unidin is saying dont disturb
To cancel the DND feature, press do not disturb again. (this is either a key on the base unit, or can be found in the Menu on the base) You can also mute the ringer tone while the phone is ringing by pressing do not disturb on the base.
Activating the DND while the answering system is off will turn the answering system on automatically. The answering system setting will reset to the original setting when you cancel the DND.
Jul 02, 2009 | Uniden 5.8GHz Dual Cordless Phone
My uniden powermax 5.8 ghz set itself to Do Not Disturb.
The do not disturb feature (DND) allows you to mute the ringer, the base, and any registered handsets at the same time. The phone must be in standby mode. Press and hold do not disturb on the base. You will hear a confirmation tone, and the DND LED illuminates. To cancel the DND feature, press do not disturb again. You can also mute the ringer tone while the phone is ringing by pressing do not disturb on the base.
If you press answer on/off when the DND and the answering system is on, both of the DND and the answering system will turn off.
To mute the ringer tone temporarily for each handset or the base, when the phone is ringing, press the MUTE soft key on the handset or the base. The ringer tone will return to the previous setting starting with the next incoming call.
May 28, 2009 | Uniden 5.8GHz Dual Cordless Phone
Phone wont ring on incomming calls?
Could be two things, first is DND or do not disturb. Make sure that its turned off by either pressing the DND button or feature #85.The second is that the ringing wasn't turned on in programming.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should sat line 001: appear only press CHNG til it says appear &ring.
press next key (lower right arrow)
The display should say line 002: appear only
Repeat same procedure as line 001 til all available lines are done
press the release key when finished
Mar 26, 2009 | NorStar M7310 Corded Phone
I need to shut off the ringer on my phone
you can turn on DND key or it has to be programmed in programming 81-87
info@ameritelnj.com
Tony
Mar 04, 2009 | Toshiba DKT2010SD Phone
Do Not ring During Meeting
DND (do not disturb) is the only easy way I know of doing this for a short period.
If you do not have a button programmed for DND you can press [FEATURE] 85 to turn DND on or off.
Feb 25, 2008 | Nortel Meridian M7208 Corded Phone
IBM Corded Phone IBM412CID Logo
128 people viewed this question
Top IBM Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
Are you an IBM Lands Phone Expert? Answer questions, earn points and help others
