Question about Zanussi WJS1265W Front Load Washer/Dryer
Opening the door
In my new flat the old washing machine is a Zanussi jetstream turbo the only letters I can read are y l.
I have a wool wash in at the moment and I cannot open the door what do I do?
  • 121 Answers
Have you tried to disconnect it from power mains for a few minutes to see if that will reset the security timer?
Posted on Dec 05, 2007
Spin only on Zanussi Jetstream 1400
no agitation check timer and control board. but more likely culprit is the water pressure switch. Which determines water level and when machine goes into agitation mode?
Sep 26, 2014 | Zanussi Washing Machines
Zanussi jetstream zwf14179W lock will not release
it sounds like your pump might have somthing in side it try opening the flap on the bottom right you will see a plastic screw undo it and clean it out that should help ok
Oct 18, 2012 | Washing Machines
Zanussi jetstream 1000 turbodry door remained locked this morning. Emptied machine through filter port and cleaned filter. Door opened ok. Machine will now not start any program although the power light...
the drain pump is jammed .........remove the filter at the bottom left of the machine get down and look in the hole and you will likeley find something in there if not you need a new pump
Feb 26, 2010 | Zanussi FJS1225W Front Load Washer
We have a zanussi jetstream washing machine about 5yrs old and it has started to make an terrible winning noise on spin, is it repairable or wiser to get a new machine?
From the symptoms you describe, I would conclude that the main drum bearings have failed, and zanussi spares prices being what they are , I personally would recommend repacing the washer, it will probably be cheaper in the long term.
Hope this helps you with your problem
Dec 28, 2009 | Washing Machines
How to clean a Zanussi Jetsystem 1400
on my mums zanussi,, after opening door, machine had not drained and spined, closed door again could not get machine to go,, this time could not get door opened..there is power to machine.
May 19, 2009 | Zanussi Washing Machines
Zanussi wj1054 front load
Check the water level pressure chamber for a partial blockage, this can cause all sorts of problems.
Apr 07, 2008 | Zanussi F1045W Front Load Washer
Zanussi washing machine.
i am a recently retired engineer of 20 years, and i have found that generally the numbers and letters are the same throughout, so the number 2 on one machine is the same as the number 2 on another make, so this rule applies for letters also, just remember what you used on your old machine and you cant go far wrong hope this helps
Sep 19, 2007 | Washing Machines
Fitting a new door seal
unplug machine. Pull off retainer clip from the front , with both hands inside push up the seal untill its free. Then with the new seal apply washing up liquid to the gap on the seal. And fit this is fiddly. Then pull the spring you removed to loosen abit and with a screw driver to keep it in place throught the door lock thats why youve unpluged it. strech the spring around. the ease on the front part of the seal and replace the clip. put on a wool wash to check for leaks. appliance doctor
Feb 05, 2007 | Zanussi IZ161S Front Load Washer
Zanussi WJS1265W Front Load Washer/Dryer Logo
148 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
