FixYa.com
Tags:
Faber Cristal HC 598041 Kitchen Hood
Fan Not Working
posted by meg0425 on Dec 05, 2007
Our Faber Cristal HC rangehood fan has stopped working. When I pull out the hood the light and fan normally automatically come on. The light works but all of a sudden the fan no longer works. Any ideas on where to start to check out the problem?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Dec 09, 2007
Helpful (85)
Bob from LI
Rank:Wiz Wiz
Rating: 84%, 377 votes
Sounds like a motor problem...but not necessarily. Cut power to the unit. Expose the motor assembly. Turn the fan by hand...if it is jammed or hard to turn...replace that motor. Not that? There is likely a motor connector. Get a test light at the hardware store. Disconnect the motor and then probe the wires coming to the connector from the power side (with the power on again) to see if the tester glows. Yes...bad motor. No, find the bad connection. It is possible that this unit uses a multi switch...if that's the case, there will be three wires coming out of it...One is power in...the others go to the light and the fan. Then, the switch will be the culprit. Hope this helps.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Kitchen Hoods problems?
Kitchen Hoods
Need to replace main control...
I know the circuit board is bad... Answer This...
Kitchen Hoods
Light bulb socket replacement...
Hi, I'm really having a tough... Answer This...
Kitchen Hoods
STIHL BLOWER MODEL BG-85
do you have a link to a parts... Answer This...
Kitchen Hoods
attic roof vent fan- brand...
put a new motor 3.4 amp 1050... Answer This...
hood
where do you get a new hood... Answer This...
Repair Service
Find Kitchen Hood Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
