Question about Denon AVR-900 Receiver
Protect sign is on a avr 900
Every time i turn on the unit it goes through the start up thing then stops and says protect tried unplugging it no luck how do you reset tht help
  • Gene2 Dec 23, 2007
    The "Protect" error code is displayed and will not go off. I checked and then disconnected my speakers. I tried initializing the microprocessor as
    described in manual. I know heat was not an issue, since it was not being
    used. I have tried pushing every button on the unit. The Denon AVR 900
    has not been used for several years and I hooked everything back up this
    week and everything worked great for couple days.
I have simillar problem. Can you remember what was the last thing you did with it before the problem come
Posted on Jul 20, 2009
Candy washing machine gc4 2d washes for about 15" then stops for 30" (the screen goes black) then on again for about 10" and then stops again.
sounds like overload protection is disabling the machine. it could be caused by a lot of reasons, the only advice I have is to check for a jammed drum, empty machine and see if drum turns freely. best luck to you.
Dec 06, 2014 | Hoover Genuine Candy Zerowatt Washing...
When I turn my dvd player on, the volume will lower on its own to almost mute. It is hit or miss weather or not the unit will turn off on its own saying protect. All connections are good. Inside is clean....
When you've got good volume, try unplugging the speakers (only for a very short time) to see if that whining noise is still there or if it's stopped. We're trying to see if the whining is related to the low volume and "protect" or if it's only coincidental.
Try unplugging all the cables (except the power cord). Turn the player on & off several times & see if that whining noise acts the same. Also see if the player goes into "protect". What we're trying to do here is see if it NEVER goes into "protect" with the cables unplugged.
Last... try to get it to start & run without going into "protect", with all the cables unplugged (except power). Plug the cables in, one at a time, and see if plugging one of the cables in forces it into "protect". If so, there's something wrong with that cable or whatever's on the other end of that cable. Unplug it again & restart the player - no "protect"? Wait a little while, plug the cable in. "Protect"? Check the other end of that cable.
If it goes into "protect" with nothing plugged in except the power, then the player is probably a write-off, ready to be replaced (it's not very often that DVD players are worth repairing these days).
Nov 05, 2013 | Samsung HT-Z310T Theater System
My Harmon Kardon AVR 2600 goes to protect mode when powered up. After many tries it will fire up but at times it's up to twenty times. I did load the software upgrade 6 months and it has been fine
Check all speaker wiring for shorts, if okay! there is a problem in the audio output stage of the unit or the protection circuit is not working properly. I would suggest a pro to evaluate.
Apr 02, 2012 | Harman Kardon AVR 2600
How do i get the thing to not say protect
try factory reset by unplugging unit then hold down tuner button and video select buttons then plug in unit let display flash a couple times then release,if unit goes back to protect,you have a shorted power amp problems.
Apr 13, 2010 | Denon AVR-900 Receiver
While watching tv my speakers started cracking and went loud then just stop working. turn the unit off then back on it works for a few seconds then does the same thing.Denon AVR 1908
I had the same issue..I called Denon support and they fixed the problem. You need to reboot the micro-processor....turn off the unit...hold down A+B then turn on...the display blinks (all the display is illuminated) Let go of the buttons.....issue resolved!
Good luck....
Jan 08, 2010 | Denon AVR-1908
AVR amber light will not return to blue after
There is an internal reset switch mounted on the transformer board. Open the unit, look at the boards attached to the transformer, the pushbutton is facing up. Measure the voltage on the 2 pins of the switch. If it is a logic low, the switch is partially shorted. Replace the switch or just cut the jumper wire just below thw switch. When this switch fails, it constantly resets the receiver and stops it from powering up. It does not fix a protection mode problem.
Dec 01, 2009 | Harman Kardon AVR 130 Receiver
Protect is ON
Either there is a bad capacitor in the protection unit or you can find the wire that goes from volume control to protection unit and unplug it.
You can also try turning the volume all the way off before turning on, then slowly turn up from there
Jul 20, 2009 | Denon AVR-900 Receiver
Denon avr 2803
The unit is in protect mode. This effectively shuts off the output amplifier section. This happens because a problme is detected in the output section. This unit will require service. Most likely the output transistors have failed. Figure on $20-$40 for parts plus the local labor rate for repair cost.
Dan
May 12, 2008 | Audio Players & Recorders
Says protect
Probably some speaker wires got shorted or the output stages freaked out and the cpu went into protect mode. Normally plugging it out of and in to the wall socket should/could reset it.
First check all wiring at the speaker outputs and on the speakers
then if it still wont startup you could try the avr-1500 method with
some trial and error pressing of buttons.
avr-1500 reset method:
Unplug the unit from the wall, hold down both video select and audio select at the same time, plug it back in. Keep holding both buttons for 2 secs, unit will reboot. As you have no audio select button on your avr-1100 you might try pressing video select and another key to see if this will reboot it.
Jan 13, 2008 | Denon AVR-1100 Receiver
Trouble shooting a Denon Reciever
I just picked up a non working AVR 900, there are a total of 4 fuses inside the unit: 2 on the protect board, 6.3A and 8A, and 2 in the middle near the front. I was told by Denon the following might reset the microprocessor. 1) unplug unit 2) press and hold tuner and video select on front panel 3) plug in while holding buttons Unit display should flash until you let go of buttons. Unit stays on you should be ok/ goes back to red- service They also said: There are 3 types of protection that will commonly occur with our receivers. This is designed to protect the unit from permanent damage. 1) Thermal Protect = When the unit overheats this will occur, usually if there is not enough air space above and around the unit. There cannot be anything directly on top of the unit and there must be at least 4 inches of airspace above the unit. 2) Overload Protect = Most commonly occurs when a strand or more of copper speaker wire is not securely connected to the speaker terminal and is touching the chassis of the receiver. If the volume is turned higher than 85% this may also occur. If you need to turn the volume higher than this point to get the level you want, you need a more powerful amp. 3) DC Protect = When an amplifier fails this will occur. This will protect dc current from damaging the speakers. When this happens the unit will need to be serviced. I had a bad 6.3A fuse ? I replaced it and tried to reset. The microprocessor would not reset. I had the exact same results you had. The chip on the back side of the front IC board was smoking. Before I attempted the reset I asked Denon if it was worth sending in for repair. The answer was "NO" BC
Apr 20, 2007 | Denon AVR-900 Receiver
420 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
