Question about Denon AVR-900 Receiver
Denon AVR-810 going into PROTECTION mode
Hello: I have a Denon AVR-810 that was damaged about a week ago. I repaired the unit by replacing the fuses, resistors in the main amp section and a voltage regulator for the display section. I also replaced the main output power transistors. Now when I turn on the receiver everything is OK and I can listen to music at different volume levels through my headphones (no speaker connected). When I connect the main speakers the unit goes into PROTECTION mode when I turn up the volume. I isolated this problem to the main outputs only and it only comes on when speakers are connected. I checked the bias and it reads about 0.024 Volts (24mV). Is this bias setting correct? Why does this problem come out only when speaker loads are connected? cant turn on my avr 900 protect signs on how do i reset tht thx flea
  • 2 more comments
  • yura0 Jan 06, 2008
    I have is problem. Damaged power tranzistors left channel.
  • Anonymous Jul 05, 2008
    I recently got a Denon AVR-810. When first turned on the unit goes into "Protection" mode and does not play through headphones. I have not tried the speaker outputs yet. What is the problem? Is this an easy fix? Any assisitance available?
  • stabes710 Jul 06, 2008
    I just moved and now that I am trying to reconnect my speakers to my
    Denon AVR-810 receiver, which was working fine before the move, in my
    new apartment the unit repeatedly goes into "Protection!!" mode
    immediately the moment the volume is turned up - something which almost
    never happened previously.
    I am using monster cable speaker wire and just added Radio Shack's Gold
    Series Deluxe Pin connectors (model # 279-309) to connect the speaker
    wire to the speakers (since one of the them was being finicky about
    working continuously), but nothing seems to be helping. This is
    incredibly frustrating.
    If anyone has any solutions or insights into how to fix this problem, it would be greatly appreciated.
  • antonioatril Dec 20, 2008
    I have a Denon AVR-810. Everytime I plug it in it goes into Protection mode. How do I intialize the microprocessor or what should I do. I don't have my owners manual
2 Suggested Answers
  • 3130 Answers
SOURCE: Denon AVR-810 going into PROTECTION mode
It sounds like there is a problem with the differential circuit. The bias I am not sure about, as every unit is different. You should get the service manual to be sure or call Denon and see if they can give you an idea. Good Luck
Posted on Jun 05, 2007
Denon AVR-3801 lights up,makes rapid clicking noises when amp tries to turn on. Clicking stops but unit doesn't play & sometimes the unit turns off. Occurred after lightning storm. What to do to fix?
Probably damaged by power surge. If you do not have experience diagnosing and repairing electronic circuits as well as having access to schematic diagrams then this is not a repair for you. Failure to replace all damaged components may result in damaging new parts.
Aug 16, 2016 | Denon Avr-3801 7.1 Home Theater Surround 7...
Denon avr2312ci shuts off and blinks red
Yes that is why. The receiver is protecting itself from an un-stable load impedance which causes current/voltage spikes through the final amplifier components and proportionally through the input where the protection relay is (click),. Do not continue using the amp until you have repaired or replaced the blown speakers. A rule of thumb is to maintain 8 ohms on each speaker wire plugged into the amp. Keep that in mind or eventually you will damage it.
Jan 23, 2014 | Denon AVR-2312CI
Red power light blinking on my denon avr 1907, tried reset procedure, no speakers hooked up now and it still goes from green light to blinking red light and shuts off...Any clues?
This is a protection mode. The receiver protection circuit detects an internal problem like missing power supply voltage or blown channel and shuts down the receiver. You need to bring the unit to a repair facility.
Sep 26, 2011 | Denon AVR-1907 Receiver
AVR-1508 7.1 Channels Receiver: My Denon AVR-1508 won't stay on. Once I try to tak...
Not familiar with this model but seems like the protection circuit is kicking in, this could be caused by an imbalance of Ohms between channels or a short. remove & check all speakers and cables for continuity or shorts, does the unit power on without speakers or in a different mode (surround off).
always add speakers in pairs (L&R) before testing to prevent possible protection circuit, test main speaker pair first then add surrounds (all according to the allowable Ohms range for the amp of course)
Nov 18, 2017 | Denon AVR-1508 Receiver
My Denon AVR 2805,has a problem. In a few seconds after switching on, it automatically turns itself off. What is the cause of this problem? How can I fix it?
This unit is in what is termed :protect mode". This means that one or more of the amplifier channels has a rpoblem that was detected by the protection circuit inside and the unit has been shutdown to prevent further damage. This is often shorted output transistors or a defective amp pac for the surround channels. Expect a parts cost in the $50 range for this repair.
Oct 08, 2009 | Denon AVR-2805 Receiver
My Denon AVR 3806 keeps turning itself off, why?
Your receiver has short circuit somewhere. The protection circuit shut off the unit to prevent more damage. You can try to disconnect all speakers. If there is not improvement, you need to send your receiver to repair.
Jul 06, 2009 | Denon AVR-3806 Receiver
Protection mode
The protect mode with nothing connected indicates that the output transistors for one or more channels are shorted. These will need to be checked and replaced. This is a simple repair for an experienced audio shop, Figure about $10 for each output transistor and add in another $10-$15 for misc parts that may also be smoked.
Mar 18, 2009 | Denon AVR-3600
DENON AVR-1404 switch on problem
Maybe the audio amplifier IC´s are damaged that´s why go on the protection mode
Jul 21, 2008 | Yamaha RX-V461 AV Receiver
AVR 810 Denon Receiver Sub Woofer Hookup?
Denon AVR-810 was a quite out-dated model. I had owned since 1992. It shown 'Protection' on the screen for 2 months ago and not yet been fixed. Better to replace a modern one or repair it at a reasonable costs.
Dec 28, 2007 | Denon AVR-2106 Receiver
Jun 05, 2007 | Denon AVR-2106 Receiver
971 people viewed this question
Top Denon Audio Players & Recorders Experts
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
