Microsoft Windows XP Home Edition Logo
Posted on Aug 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I get some characters in place of space and enter when I press space I get a dot when I press enter I get some othr character when I press tab i get arrow
  • 4 more comments
  • vllr_trivedi Aug 28, 2009
    I am using word 2003 and nothing is wrong with my keyboard
    it only comes when I open a word document
    WHAT DO i DO.?
    Do I need to uninstall KB.
    I am using Microsoft word 2003
    This error comes only with word files.
    for example spacehellospace reads as .hello.
    I think now you know the issue!!
    It is showing paragraph character
    thanks but my problem is solved
    On the tools option
    i have unchecked the formatting characters.
Anonymous
Level 2:
  • Expert 154 Answers
  • Posted on Aug 28, 2009
Anonymous
Expert
Level 2:
Answers
154
Questions
0
Helped
52781
Points
405
Check if theres any key that are pressed. Or try changing your keyboard. Thanks
  • 1 more comment
  • Anonymous Aug 28, 2009
    Try this one,
    Go to Device Manager (Right Click My Computer select properties, then Hardware Tab, then Device Manager)
    Click on the Plus Sign on your Keyboard, Right Click on your keyboard then Restart the PC afterwards.
    Thanks
    Yes, Uninstall the Keyboard from the Device Manager then Restart your PC.
Casio EX-word EW-S300C Translator. Where is the space bar on my ex word ew-s300c please?
The is a Spanish Translator. Apparently the Ampersand '&' is the space (espacio)
Entering in Spanish• When entering multiple words (phrase search and example search),separate them with an ampersand (&), instead of spaces. Example: tener una de ? tener&una&de• Enter hyphenated terms as a single word, without the script. To search for "Castilla-La Mancha", for example, enter "castillalamancha".• You can enter up to 30 characters. Ampersand (&) characters used in place of spaces are also counted as entered characters.
https://translate.google.ca/?sl=auto&tl=en&op=translate
Here is the manual in Spanish. In Google Chrome, you can Right Click on a computer and choose 'Translate to English'.
manualslib.es https://www.manualslib.es > products ·Translate this page Manuales y gu?as de usuario para Casio EW-S3000. Tenemos 1 Casio EW-S3000 manual disponible para descarga gratuita en PDF: Guia Del Usuario ...
How do I use alphabet keys on remote
Generally, entering text is carried out the same way as with most cell phones.
  • 0, 1, 2, 3, 4, 5, 6, 7, 8, 9: Enter a character to the position pointed by the cursor.
    • First press: enter the first character from a set of characters related to this button. Each subsequent press: you may change the entered character to the next one from this set.
    • 0: enter the space.
    • 1: enter a special character (punctuation marks, etc).
      • Up, Down, Left, Right after pressing 1 (special character entering mode): select the required character.
  • ENTER: confirm selection; finish text entering.
  • SUBTITLE: enter the period (for numeric mode); functions like button 1 (character mode).
  • CLEAR (<-): delete a character to the left of cursor.
  • SELECT (cap'num): switch input mode:
    • abc: character mode, small latin letters.
    • ABC: character mode, capital latin letters.
    • 123: numeric mode, digits.
  • RETURN: cancel the text changes and finish text entering.
  • Left/Right: move the cursor one character left/right.
  • Up/Down: move the cursor to the start/end of a text line.
    • If the cursor is already in start/end position: select another user interface element which is under/over the current text entry area (only for dialogs with several elements of user interface; text changes are confirmed automatically).
  • POP UP MENU: show context menu with a list of available commands. They allow you to cut, copy and paste text using the clipboard, much like it is done on a PC.
  • http://electronicshelponline.blogspot.com/
I want to fax from new zealand to australia. how about i do it...........
In the setup you should enter your the fax number in the internationally standardised format, i.e.
in accordance with the following strict sequence:
??  The "+" (plus) character (by pressing
key)
??  Your Country Code( "64" for New Zealand)
??  Your local area code minus any leading "0"
??  A space
??  Your number on the local exchange, using spaces to aid readability as appropriate.
1 Press Menu/Set, 0, 3.
2 Enter your fax number (up to 20 characters).
Press Menu/Set.
3 Enter your telephone number (up to 20 characters).
Press Menu/Set. (If the telephone number and fax number are the same, enter the same number again.)
Note
??  You cannot enter a hyphen in the number.
To enter a space press once between numbers.
??  The telephone number you enter is only used for Cover Page features.
4 Use the dial pad to enter your name (up to 20 characters).
Press Menu/Set.
5 Press Stop/Exit.
Note
If the Station ID has already been
programmed, the LCD will ask you to press 1
to make a change or 2 to exit without
changing.
3.Station ID
??²
Now dial the fax number of australia 0061............ and send fax.
How do I make the @ sign on the Mexican keyboard
You can use Windows Character Map, located in your Windows start menu under Accessories > System Tools to enter characters that may not be supported by your keyboard. Just open the Character Map window and click on the character you wish to use.from the listed options. Press Select to to choose, then Copy to move the character to the clipboard. Return to your document, place your cursor where you wish the character to appear and press Ctrl -V to insert it into your document.
1helpful
Unwanted 'dots' on printout
There is a dot somewhere on the drum, remove the drum and toner cartridge from the machine, then remove toner from drum. Look at the shiny roll, you can turn it from the black gear on the side. Once you find the dot use a cue tip dipped into little bit of alcohol and clean it off.
1helpful
Acer one aspire netbook - green keyboard characters
go to control panel...
click clock,language and region...
then go to keyboard and language tab...
click change keyboards.....
on the general tab...
look for english(united states) US on the add/remove keyboard list..
then press apply then press ok...
now the last step is restart ur netbook...
gudluck!
i hope it helps u...
1helpful
Program numbers
Storing a Number in Memory
1. Press the STORE button. ENTER TEL. NO. is displayed.
2. Use the keypad to enter the phone number. You can put spaces in the number and it will still dial correctly. To enter a space, press NEXT button.
• To scroll forward or backward, use NEXT (when the cursor is not at the end of the number) or REVIEW.
• To erase the current digit, press DELETE.
3. When finished, press STORE. ENTER NAME is displayed.
4. Use the keypad to store a name (up to 16 characters). More than one letter or character is available in each of the number keys. For example, to enter the letter "A," press the 2 key once. For a "B," press the same key twice. For a "C," press it three times.
• To add a space, press NEXT.
• To scroll forward or backward, use NEXT or REVIEW.
• To erase the current character, press DELETE.
5. When finished, press STORE. MEMORY LOCATION is displayed.
6. Press the memory location number (0-9 or A, B, C) to store the number.
Here is a link for this telephone off the GE website:
http://www.home-electronics.net/ge/pc/IB/29897GE1_IB.pdf
I have a brother 4100 fax. how do I change the information on the fax transmission page? thank you
If your date and time are not set yet, press Menu, then 1, then 2 and enter the date and time, pressing Set after each entry. Enter time in 24-hour format so it will display AM or PM properly.
For other info at the top of your fax transmission page after date and time, such as your fax and phone numbers, and company name:
Press Menu, then 1, then 3 for Station ID info.
First put in your fax number and press Set.
Next put in your phone number and press Set.
Next press the buttons for your company name and press Set.
Press Stop/Exit to return to the date and time display.
Here is info on inputting text, from the manual:
Entering Text
When you are setting certain functions, such as the Station ID, you may need to type text into the machine. Most keys on the dial pad have three or four letters rinted above them. The keys for 0, # and don’t have printed letters because they are used for special characters.
By pressing the appropriate number key repeatedly you can access the character you want.
Inserting Spaces
If you want to enter a blank space, press once between numbers and twice between characters.
Making Corrections
If you entered a letter incorrectly and want to change it, press to move the cursor after the last correct letter. Then press Clear; all letters above and to the right of the cursor will be deleted. Re-enter the correct characters. Also, you can back up and type over incorrect letters.
Repeating Letters
If you need to enter a character that is assigned to the same key as the previous character, press to move the cursor to the right.
Special Characters and Symbols
Key - once - twice - three times - four times - five times
2 - A - B - C - 2 - A
3 - D - E - F- 3 - D
4 G H I 4 G
5 J K L 5 J
6 M N O 6 M
7 P Q R S 7
8 T U V 8 T
9 W X Y Z 9
Press for (space) ! “ # $ % & ’ ( ) + , - . /
Press # for : ; < = > ? @ [ ] ^ _
Press 0 for é à è ê î ç ë ö 0
2answers
Emachines Keyboard Model No. KB0511
Here you go:
Enter
The computer brings the cursor to the beginning of the next line. This key can also be pressed
to open a program after you have HILIGHTED* it. It will execute a command.
Shift ▲ Hold the shift key down and press the letter key you want to make a CAPITAL letter.
This key is also used to type the charters at the
top of some keys. Eg: Shift + 1 = ! or Shift + 2 = @
Caps Lock
Makes all letters CAPITAL letters. When the Caps Lock key is pushed, a light will
show up on the upper right corner of your keyboard
next to the capital “A”. When caps lock is turned on it remains on until you press the Caps Lock key
again. When you press the Shift key when
Caps Lock is on, a lower case letter will be produced.
Space This key places one space every time it is pressed. (The long, unlabeled key at the
bottom center of your keyboard).
←Backspace Deletes the character to the left of the cursor each time you press it. (If you hold it
down it will continue to delete so be careful).
Delete Deletes the character to the right of the cursor each time you press it.
Home Brings you to the beginning of the line the cursor is on.
End Brings you to the end of the line the cursor is on.
Esc Located in the upper right corner of your keyboard. Cancels an incomplete command;
it will also close an open menu.
Moves the cursor to the left one space each time it is pushed; does not delete the
character.
Moves the cursor up one line each time it is pushed; does not delete the character.
Moves the cursor to the right one space each time it is pushed; does not delete the
character.
Moves the cursor down one line each time it is pushed; does not delete the character.
Insert Deletes the character to the right of the cursor and replaces it with whatever is typed on
the keyboard.
↔Tab Moves the cursor to the tab marks and between columns.
Shift + print screen Prints what is on your computer screen.
Highlight (to select) To make the item stand out. To choose or select it.
? *When an icon is highlighted (left click the mouse button one time while the cursor is pointing at
the icon), the program has been chosen and the name of the icon will change color. When this has
happened, you may press the Enter key to open the program.
? *To highlight a character or characters, move the cursor, using your mouse or the arrow keys, to
the left of the item you wish to select. Press the left mouse button and hold it down while you
move the mouse to the right. Let go of the left mouse button and your item(s) should be
highlighted. Then you can choose what you want to do to the selected item(s) e.g. bold, underline,
delete, italicize, etc.
“Drag and drop” Move the cursor to the item, click the left mouse button and hold it down.
Move the mouse, while holding down the left
mouse button, to the location you want to move the item. Let go of the left
mouse button.
Cursor - The arrow on your screen. The mouse is used to move the cursor.
Let me know if this helped
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
