Question about Adobe Photoshop 7.0 for PC
Scale how will i make a bigger photo to a 2x2 only?
  • 233 Answers
You do not mention having any photo editing program now.
It depends upon which photo editing program you have, as how to do it.
If you download Adobe Reader 8
You also get Adobe Photoshop 3.2 Starter Edition. Both are FREE.
In Adobe Photoshop select the photo you wish to print. Then on the menu bar select File then Print. Then select the Custom Size radio button. Adjust the scale to the size print you are wanting, in this case 2.0 x 2.0
Be sure to come back here for my rating on this solution.
Posted on Dec 05, 2007
Where is the crank sensor on a 2001 gmc sonoma 4cyl. 2x2
it is located on the right side of the engine behind the oil filter. see photo.
May 12, 2015 | 2001 GMC Sonoma
How to resize a picture or image to create a smaller size for convenient...
With the advent of the Megapixel camera , our photo's that we take are getting bigger and bigger. This is all good to have a nice and big resolution picture , but the trouble comes in when you try to e-mail a 4Mb picture on a limited internet connection.
There is lots of software out there that can re-size a picture or photo , but I prefer and recommend Pixresizer because its free and really easy to use.
Download Pixresizer HERE
Once downloaded , unzip the program and install it to your computer. If you do not have software to unzip it , please download winrar HERE.
Now open the program.
You have a choice of converting multiple files or a single file at a time.I'll be demonstrating how to convert a few files at the same time. The concept is the same for converting a single file.
Click on the "work with multiple files" tab.
  1. Select the folder where the photo's which you want to resize are located .
  2. Select the folder where the resized files are saved.
  3. Move the size dragging scale to select desired size.
  4. Select the output format (Jpeg is fine)
  5. Finally Save Pictures.
And that's all. I now converted 7.8Mb of photo's to only 200Kb which is a much more appropriate size for sending in a e-mail.
Please remember to rate this tip if your find it helpful.
on Feb 25, 2010 | Cameras
Ti 89 titanium when multiply 2x2 matrix by 2x1 matrix get error diemensions
Matrix multiplication is defined only when the width of the first matrix is equal to the height of the second. You can multiply a 2x2 matrix by a 1x2 matrix or multiply a 2x1 matrix by a 2x2 matrix, but you cannot multiply a 2x2 matrix by a 2x1 matrix.
Jun 13, 2011 | Texas Instruments TI-89 Calculator
What dues requarmints for getting a new passport
2x2 Photo and $200, $250 for "Express Service" I lost mine in a truck fire had to get a new one, that's how I know.
Apr 07, 2011 | Computers & Internet
I did copied an image from a book so i want to make it bigger
You need photo editing software, like free Gimpshop.
Go to Gimpshop and download program:
This is a very good photo editor, and it's free.
1) After the download, You have to open gimpshop once so a shortcut appears on desktop.
So go to start, all programs, and look for GIMPshop, and put mouse on GIMPshop, and box appears, and then click on GIMPshop located in that box.
Gimp opens. The close Gimp and see there is a desktop icon.
2) Find the image you want to make bigger.
Hover mouse over your image without clicking mouse, and the size of image will show in small box. For example it will show Dimensions: 1000 x 700
Write down the size
3) Drag and drop your image on top of gimp icon and program will open.
4) Once photo is loaded.
Go to 'Image' at top of program and select 'image size'
You will see numbers for width and height appear in small boxes.
Use your mouse and keyboard to change the numbers and double the size.
For example make new dimensions 2000 x 1400.
Or make it 3 times bigger.
Then click 'scale'
5) You will see the image is bigger.
6) Time to save larger image.
Go to 'File' at top of program
Click 'save a copy'
Box comes up with name. Re-name the image so it does not replace original.
Click save.
7) another box comes up with a 'quality' slider
Move slider to 100%
Click OK
8) Bigger image is saved and ready
Mar 05, 2011 | Cycling
How to remove links from invicta venom steel bracelet
on the small links, pop out the pin, either way, doesn't matter, then remove the bar sections (outer ingot looking part of link) by pushing the link inward toward where your wrist would be. The center scale looking piece will remain.
Then remove the sleeve which is slightly bigger in diameter than the pin, which is still connecting the center scale piece. I'll upload pix if anyone needs.
to put back together just reverse it. match up the two connecting center scale pieces, then insert the sleeve into them to connect them, then pop the ingot piece in from the center (where your wrist would be) then carefully slide in the pin, it should go halfway before you feel resistance, then carefully drive it home.
I think it will work with the bigger pieces as well, but didn't try, didn't need to remove any.
May 10, 2010 | Watches
How mush cu. is it
cubic feet is the volume of the drum. Volume of a cylinder is diameter squared/2 x depth EG: 2' diameter x2' diameter =4 4/2=2... 2x2(depth)=4cubic feet
Feb 21, 2010 | Dryers
Need to change my print size on my C6280 Photosmart All-in-one printer, make it larger
It depends on what you are printing, but generally this needs to be adjusted in the software you are using.
If you print pictures or photos, you have to find an option to scale the printout up, either during printing, or beforehand.
If you print PDF documents, in the Print dialog box there is an option to "fit printer margins" or "auto-adjust to printer size" or something to that effect in every PDF reader application. If however the document is formatted for your paper size it will not be scaled, and if it's formatted for an even bigger sheet size, it will scale down the printout.
If you print documents from Word, there's no easy way to make the printout bigger - you can change the font size to a larger one in the whole text, but chances are, that this will ruin the text formatting.
In Excel there is an option to scale everything by a given percentage, which will automatically tile the table into as many sheets as necessary. and then the area will be printed on as many paper sheets as necessary to get
There's no one solution, unless your printer driver has an option to do a fixed scaling - but this will usually be sensible only for enlarging printouts that occupy a smaller area on paper, and you want them to use the maximum paper area. I'm sorry, but you have to experiment a bit to get the hang of it.
Nov 12, 2009 | HP Office Equipment & Supplies
Adobe Photoshop 7.0 for PC Logo
107 people viewed this question
Top Adobe Computers & Internet Experts
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
