Question about Akai PT4799HD Rear Projection Television
Pitcture is Wavy
The picture on my Akai Projection 1080i is wavy. When you change the channel, the picture comes in normal, for a second or two, and then gets dark. It then turms normal again and the picture is very wavy. Any advice on why this might be happenning?
  • KittyFemer Dec 05, 2007
    Is it worth fixing?
  • cheesemeplea Jan 24, 2009
    I also have an Akai 1080i hdtv projection, and the picture has started to become discolored, and there is an awful burning rubber smell coming from it. Is it too late to fix?
AKAI 1080I MONITOR 2002 54" HDTV PICTURE IS GREENISH LOOKING AND WHEN WE TRY TO ADJUST COLOR IT HAS A RED COLOR TO IT . HELP
Posted on Sep 03, 2010
TV TEARS AND GETS LINES AFTER 5 MIN,NEED PART # FOR PRO SCAN MODULE,ON SIGNAL BOARD
Posted on Mar 12, 2008
Akai pt5299hd color is very poor. yellowish green.Cant adjust to proper color. Please help.
Posted on Jan 14, 2008
    President:
  • 4,402 Answers
Sounds like the tuner is going.
Posted on Dec 05, 2007
  • Cary Farah
    Cary Farah Dec 05, 2007
    tuner is around 100 bucks labor about 100 i cant say if it worth it or not. depends on the picture you had before and weather you had any other problems.
Mitsubishi rearTV has intermittent wavy lines running throughout
Do you have anything to test it in 1080i? Does it do it on all connections or just one? I had a similar problem with my TV that turned out to be a bad input board. Mine would only display 1080i through the Component connections. All others would show pink and green wavy lines. It cost me around 500 to fix it. Unplug the TV. Remove the back cover for the TV. Using a NON-metal object, or gloves, wiggle the input board (that has all the video connections on it) slowly back and forth and see if the problem comes and goes. You will have to have someone watching for you. If something is loose on that board, the problem should show itself. Narrowing down the problem will probably save you money on repair bills.
May 13, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Wavy picture on top and bottom
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 29, 2010 | Sony KP-53HS30 53" Rear Projection...
Red green wavy color on top of picture with distorted faces and bottom of picture seems o.k.
Ur convergence is dead.The Convergence board must repair or replaced.Samsung/Akai use the same convergence board.Try website Tv repair world.com.Buy the whole board replaced it the best.
Jan 15, 2010 | Akai PT5598HD 55" Rear Projection...
Wavy picture with blue and purple color.
Projection TV sets have two very common problems listed below.
*Screen Looks 3-D
*Colors wont align
Jan 09, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Picture is wavy and double vision
*Screen Looks 3-D
*Colors wont align
Jan 06, 2010 | Hitachi 46F500 46" Rear Projection...
Red, Green convergence lines are wavy
*Screen Looks 3-D
*Colors wont align
Sep 16, 2009 | Akai PT4298HD Rear Projection Television
Wavy horizntal lines
*Screen Looks 3-D
*Colors wont align
Jun 24, 2009 | Akai PT4799HD Rear Projection Television
Wavy picture on a magnavox
sounds like syncronization is not occuring.your tuner may need replacing
Dec 31, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Toshiba 42H83 42 in unstable video
Probable PIP sister board.Moderate skill & some tools needed.Advise==get a senior tech near you.
Sep 10, 2007 | Toshiba 42H83 42" Rear Projection...
Wavy picture with a lot of red, perfect focus states no sensor data
Convergence ic's need to be replaced. If you pay over 300 bucks your getting ripped! Good Luck
Aug 26, 2006 | Akai PTH5498 54" Rear Projection...
Akai PT4799HD Rear Projection Television Logo
362 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
