If you are trying to connect the xbox to the internet and you have a router installed. you can connect to the internet by connecting the xbox to the router with an ethernet cable. If you are trying to connect it directly to a computer to share its internet connection, then you would have to enable internet connection sharing and may need a crossover ethernet cable instead. If you reply with which method you are wanting to use I can probably give you a little more instruction on it.
Yes, but if you want to connect the X-box and computer directly you may need to get a crossover cable. Sorry, I can't say for sure on this as it depends on the network card in the PC.
You should have a box in the configuration dialog for the Cricket saying something like "Allow other network users to connect through this computers internet connection". Be sure this box is checked.
How do I allow inbound and outbound UDP to ports 5198 and 5199, and outbound TCP to port 5200 on my...
(More)
How do I allow inbound and outbound UDP to ports 5198 and 5199, and outbound TCP to port 5200 on my Westell 6100?
I have a westell 6100 router on a verizon isp. i set it to bridge mode and have a linksys router...
(More)
I have a westell 6100 router on a verizon isp. i set it to bridge mode and have a linksys router hooked to it. now, i get a key exhange timeout error on my ps3, and my laptop disconnects at the same time. renew ip address', and everything is good to go. any ideas?? it only started doing this when set in bridge mode.
I have a westell router to,but i don't have a manual for it and i can't sign into xbox live unless i...
(More)
I have a westell router to,but i don't have a manual for it and i can't sign into xbox live unless i have 1346 MTU or more and i need to no how 2 change this setting
