Question about ViewSonic VE710b 17" Flat Panel LCD Monitor
My Viewsonic LCD monitor showing no siganl and blinking continuously. please provide solution
  • 1 more comment
  • gdspr Jan 04, 2008
    First symptom was the screen blinging from normal picture to black screen repeatidly.
    Then screen worked normally.
    Since then, the screen remains black with the power green led blinking.
    Tried to powed down and up, tried to restart computer in safe mode, tried connexcting to a laptop, without sucess.
  • hrejouan Mar 28, 2008
    All the cables are fine. I tried to open he LCD to check if there is any reset or fuse but I couldn't figure out how to open it. Any ides? Thanks
  • _Jayce89_ Jan 22, 2009
    got the very same problem .. it started a few weeks ago .
    for now .. turning it on or off at start doesn't change much .. after waiting a couple of minutes the flashing stops . Like if some components / chips needs to warm up .
    When the monitor is hot .. i can turn it off .. and on again without any problems .
    Scholar:
  • 121 Answers
Make sure cables are properly connected in both ends. If you have it hooked up to a laptop, make sure the external monitor is enabled. Usually you can toggle this with the "Fn" key + one of the F1-F8 keys pressed at the same time.
Also check that no pins in the cable are bent or damaged. Try to connect a different monitor to the PC to see if your monitor is at fault, and/or a different PC to your monitor.
Posted on Dec 05, 2007
My monitor dont come on, and green light flashng, viewsonic vp930b.
If your ViewSonic LCD monitor has stopped working with a blinking green power button, It typically means that there is one or more failed capacitors in the monitor. It would be best to send the monitor in to Viewsonic for service or to purchase a new monitor.
Mar 11, 2011 | ViewSonic VP930b 19" LCD Monitor
Blinking
change all control panel switch in frount
Mar 19, 2010 | ViewSonic VX924 19" LCD Monitor
Green light blinking , no display ,,
look inside for bad caps, see example of failed Viewsonic monitors here: http://s807.photobucket.com/home/budm/allalbums
You should have 5v and 12v in the power supply sections.
Jan 17, 2010 | ViewSonic : 19" Graphics Series Flatpanel...
Power light blinking on and off
You will need to replace the below failed caps.
2 - 1000uF @ 10V
3 - 470uF @ 25V
1 - 470uF @ 10V
May 18, 2009 | ViewSonic VX910 19" LCD Monitor
Viewsonic VA720 monitor has small blinking light, won't turn on
When turning on the computer we get analog auto save, and don't get as far as the desktop, how can I solve this problem
Debi
May 03, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Viewsoniv VA 902 LCD 19" monitor
If the signal cable is detachable from the monitor, you could try with another cable... Regarding the power, I' not an expert, but if you're familiar with electronics basics, like risks of high voltage, soldering, etc, and you'd like to experiment with the unit, then I can give you some hints.
Mar 19, 2009 | ViewSonic VX900 19" LCD Monitor
Viewsonic vp930b-3
MY VP930b has the same problem.
It takes a very long time (5-10 minutes) before it becomes normal.
Aug 04, 2008 | ViewSonic VP920b 19" LCD Monitor
ViewSonic VE710b 17" Flat Panel LCD Monitor Logo
96 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
