Question about GE WNSE6280BWW Top Load Washer
Agitation GE WNSE6280B washing machine
My washing machine will not agitate.
  • 1314 Answers
SOURCE: WPSF5170W0WW G.E. Profile Performance Washing Machine
most ge washers you just get ya fingers under the bottom and jerk up hard they have a plastic piece under them that has to be replaced from time to time its no big deal
Posted on Jan 18, 2008
  • 71 Answers
SOURCE: GE WHDRR418G1WW Washing Machine will not agitate or spin/rinse cycle
The ge wcxr1070t uses a coupling under the agitator . There is a cap on the top pop it off and remove the screw if you see one , otherwise just pull up , the coupling is under the agitator check to see if it is stripped . dr fixit in the repair service directory will have it if bad
Posted on Dec 15, 2008
  • 408 Answers
If you remove the top cover to the agitator, inside you will see a I believe 9/16" nut.  Remove this to take the agitator off the shaft.
Posted on Mar 12, 2009
  • 544 Answers
SOURCE: washer will not agitate or spin
you can view this site to have some ideas about your agitator problem.
any further question let me know.
Posted on Mar 29, 2009
SOURCE: GE profile washing machine won't agitate it spins out, drains,
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
Posted on Apr 15, 2009
  • 35 Answers
SOURCE: Knocking noise during agitation cycle - GE WNSR2100T8WW
I believe you must have one of the bottom of the line cheapo washers, as I do--the one with the plastic, rather than steel wash tub and basket? These are pretty poor machines. They cut corners drastically in every part of the design. I've replaced the aluminum hub that supports the spin basket ( the hub is bare aluminum and corrodes within about 5 years use from the highly alkaline detergent, then it fractures under mechanical stress. Then the motor burned out. I was able to get a nearly new motor on ebay for $90 incl. shipping. (BTW, if you need appliance parts try GOOD Appliance on ebay for new and salvaged parts--they're excellent! 100% feedback rating) However, I now have the same problem--a fairly loud knocking noise during the agitation phases of the cycle. This is cause by a really crappy transmission design that does not wear well. My advice is just ignore it as long as it works and isn't leaking oil and the tub seal is still good. If it does finally go to pieces get one on ebay--that is if you feel up to doing the job yourself since a repair person would charge more than it's worth to install it. I believe new ones can be had on ebay for about $80, some are sold with seal kits. Bottom line is--if you want a machine that will last you for 15-20 years--don't buy a cheapo model. The front loaders are better as they use far less hot water (energy and water savings) but a good one is going to be anywhere from about $800 to $1600.
Posted on Sep 17, 2009
0 characters
1 Points
GE washer agitation starts normal the progressively slows and then stops agitation. All other modes work fine. Model # unknown. Motor or transmission? Thanx people!!!
Model # located on the back of the control box of top load, just inside of door on front load. Other Op modes ok, problem points to agitator support shaft or the belt drive of the agitator.
Nov 17, 2015 | GE Washing Machines
The agitation does not work like it should!
I suspect u have bad agitator dogs
check THE CAM DOGS INSIDE THE AGITATOR, AS THEY WILL HINDER THE AGITATION PROCESS. However in G.E models the cam dogs are replaced with what is called an agitator coupler. (located at bottom of tub)
Remember to check the agitator spline as well. for worn broken teeth
By the way my advice is free cuz God is good!
25712554-jkb5ybrklduaa4afh4xyzipe-4-9.jpg however if u have a G.E U HAVE A AGITATOR COUPLER INSTEAD OF CAM DOGS SEE FOLLOWING PICS
May 25, 2015 | Washing Machines
My GE washer leaks from Hose Flood during agitation - how do I fix it?
It should be connected right next to the drain hose.
Jul 04, 2014 | GE Washing Machines
My GE top loading washer is making a clunking noise during agitation. Everything else okay
The problem may be in your agitator. The spline may be worn out. It is located under the spindle. Are your clothes becoming clean. That noise might be the agitator not fully engaged.
Feb 06, 2013 | GE Washing Machines
Why is agitator speed the same for all wash cycles on GE Profile WPSE4200A0WW
GE designed it that way. About the only difference is the agitation length of time.
Nov 28, 2012 | GE Profile Prodigy WPSE4200A
My GE WCSR4170D AWW top loading washing machine will not stop filling with water. i can get it to agitate when i blow into the air line hose attached to the water level switch. BUT it never stops filling...
Thanks for choosing FixYa and welcome. You probably have a bad water level switch. As for the agitation, the drive motor controls the agitation, spinning, and draining. It is possible for the machine to not agitate, but yet spin and drain. The motor runs clockwise and counterclockwise. It may be bad and if so, will need changed.
Apr 30, 2011 | General Electric WCSR4170D Top Load Washer
Ginding noise during agitation
From the GE site.....
Front load washers and some compact model washers do not come with a shipping rod. According to the Installation Instructions for these machines there are 4 bolts, 4 yellow plastic spacers, and 4 metal "p" clamps that need to be saved and reinstalled before moving the washer to prevent any damage to the machine.
Jan 31, 2009 | GE Profile WPSR3120WWW
GE Top load washer.
Hello rschneeweis
Sounds like a seal or drain hose is leaking or the clamp on a hose has vibrated loose.
Water leaking out the bottom of the machine when washing machine begins agitation cycle. If the machine is turned off the water stops leaking even with the tub full of water.
Let me know if you found it and how you do.
Please remember to leave a rating
Oct 04, 2008 | GE WBSR3140D Top Load Washer
No agitation in ge hydrowave rinse cycles
you must unplug the washer for just 1 minute open and close the lid 10 times and plug it back in and put it on a light load cycle and let it wash with empty load. shoul work fine after that
Dec 01, 2007 | Washing Machines
Wpsq312026aa agitation problems
sounds like your agitator block may be stripped... pull out agitator and u will see a block that the agatator sets on...
change that block and u should be ok
Oct 21, 2007 | GE Profile WPSR3120WWW
GE WNSE6280BWW Top Load Washer Logo
62 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
