Question about Optoma MovieTime DV10 Multimedia Projector
Loud noise when it is in DVD player, low brightness
After about 10 months, my beloved DV 10 has started acting up.
  1. The picture quality went down perceptibly one fine day. The picture looked smudgy. Even after increasing brightness, it still lacks the clarity and sharpness that existed prior.
  2. Then, a week later, the projector started making a loud whirring noise on start-up. This goes down in a few minutes, but comes back on when the source is switched to DVD mode and continues if a DVD is placed in the slot. Sounds like a problem in the DVD mechanism, yeah?
Anyways, all help will be appreciated.
  • Samm77 Feb 25, 2008
    Turns out the DVD noise was due to a loose part. Got that fixed.
    gprocket > Thanks for the tip. Have given it for repairs and will pass the info on to them to check.
  • anonymous anonymous May 11, 2010
    no it is the projector itself probably but does it still load dvd's?
  • 167 Answers
That suck, try ebay
Posted on Feb 28, 2008
I had a similar sounding problem. When I opened it up I found that the segmented color wheel was missing the clear segment of glass. I have not been successful finding parts for it.
Posted on Feb 24, 2008
Is there a way I can fix the low static sound on my Magnavox DVD player
Magnavox tv has loud static - TV - Streaming Video & TVs
Sep 9, 2014 - After a loud clap of thunder my magnavox tv with built in dvd and vcr developed static sound ... JVC DVD player and Samsung VCR to my new MagnavoxHDMI TV ... Can you connect the cable box with a HDMI cable or component ... and making a loud humming sound how do I fix help · Burning in of static ...
What is that TV Buzzing Noise? - noice fix brokentv ' Ask MetaFilter
Apr 14, 2005 - My TV does this annoying buzzing sort of humming noise (vibrating?) ... It especially seems to do it when I have the volume turned down low (or else I just don't notice .... The capacitors in there can store a charge large enough to kill you for 12 hours or more. ... Although, I feel like I hear it more often on DVD.
? 9:23
Mar 17, 2013 - Uploaded by Tampatec
HOW TO REPAIR FIX VCR VHS DVD COMBO Easy Quick & Simple COMMON FIXES FOR ... this works ...
Magnavox TV help -
Dec 30, 2015 | Magnavox Televison & Video
I have a 2007 Chevy uplander. Yesterday while driving down the road it died on my. I pulled over and it started back up. Went about 10 miles and it died again. We were low in gas but nothing bad. I put...
Clicking noise where ? under the hood in the engine compartment ,the starter , a relay in the fuse box , inside the vehicle etc.... Checking the battery , battery cables and connections , do the headlamps work ,are they bright ?
If the headlamps work and are bright then the battery an connections are Ok . If not bright ,voltage drop test the main battery cables an connections .
How to voltage drop test starter motor circuit
The starting system on your vehicle is different then this , a tipical starting . Your starter system is more complex ,when you turn the key to the start position it inputs a voltage signal to the BCM - body control module , The BCM then sends a message to the PCM - engine computer on the class 2 serial data communication network that start is requested . The PCM will then supply a ground to the control side of the start relay energizing the relay sending B+ voltage to the starter solenoid .
The vehicle dying on you could be any number of thing's ,and without testing we'd only be guessing . When electronic thing's heat up they tend to act like that , till they cool again .
Sep 16, 2017 | 2007 Chevrolet Uplander
Loud hissing noise when I play a DVD
maybe the motor spindle are about to crash
Sep 19, 2012 | Philips DVP3150
DVD tray makes noise when it rotates
This noise can be casued by two things:
1) The tray is not completely in the loaded position and the "clamper" is rubbing. Replace the loading belt and the loading sequence will complete and the noise should stop.
2) The "CD table" that is part of the spindle motor assembly has slipped a bit. This will make the CD/DVD ride too low and strike the lower tray support. This will require that the table be "re-aligned" to the proper height which may not be possible on your model without special measurement equipment. The height is critical to proper operation of the unit.
Try replacing the load belt first and report your results.
May 30, 2009 | Kenwood DV-605 Multi-disc DVD Player
Pioneer Dv 285 powers down after 15sec
Hi There, I've got the same problems with my DV 285. My power started going off approximately 5 to 10 minutes into the DVD. The only button that seems to work is the OPEN/CLOSE button. Once the tray closes, the unit shuts off. I can't even use the on/standby button to turn it on.
Feb 22, 2009 | Pioneer DV-285-S DVD Player
Can u update the codecs on the samsung dvd-hd870?
There is 1 firmware update on this model for only Australia
However there is setup to be check as follow
▶ Symptom
TV shows low picture quality. (Ex) Blotting colors…
In most cases, above symptom is not real defect.
1. Press the MENU button.
3. Select the Display Setup.
4. You can see the "Picture Quality" category.
5. Select the Picture quality.
6. You can adjust "Sharpness" & " Brightness" & " Color Saturation"
I hope that will help you to improve your picture quality
Nov 30, 2008 | Televison & Video
Speakers & Ipod
Not sure which ipod you are using but be sure to use the backlight on the ipod (always on) when you have it connected. It eliminates certain noise heard in the background. Also be sure the level is calibrated how you need it, turn up or down the input level using the SLA adjustment from the sound menu item. It allows you do adjust from as much as +4 louder or decrease it as low as -4. You might either have the signal being too low or too loud causing clipping. Also be sure your ipod has updated firmware, there are certain fixes that address battery, hard drive noise, etc on the units. It may also be your ipod has issue, try using it in someone else's vehicle or try it on another dock connector to test the levels there.
Nov 05, 2007 | Pioneer AVIC-D3 Car DVD Player
Player won't turn on
Loud noise = diode is bad, and the dvd player needs to be repaired/replaced
Jun 16, 2007 | Toshiba SD-K740 DVD Player
Optoma MovieTime DV10 Multimedia Projector Logo
163 people viewed this question
Top Optoma Office Equipment & Supplies Experts
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
