Question about Nokia 7610
Headset problem when i insert headset to my mobile sound coming very slowly
    Sergeant:
    Champion:
  • 270 Answers
I think u ahve inserted a stereo head set into nokia 7610 . 7610 supprt oly mono output . use a single ear piece head set . the volume can be incresed by pressing right key during call
Posted on Dec 05, 2007
I av bluetooth model no ce0889 but it is not conecting with my nokia e5 nokia mobile phone please tell me solution ,thanks
try to insert it in another nokia mobile phone same to your phone, If not functioning you may go to the any nokia mobile phone store & ask them to find you the right nokia wireless bluetooth headset. You may also return it where you buy it, bring your receipt to change what fit to your mobile phone, or consult mobile technician.
May 26, 2011 | Nokia Wireless Bluetooth Headset Headset
Tip
How to connect a (Motorola) Blue Tooth headset to a mobile phone!
The following procedure is dependent to the phone in use! However it is mainly for Motorola brand but it works with many others too!
1. Turn on your mobile phones bluetooth function and go to search for new devices menu.
2. On the headset, From turned off state, Try holding down the power button for at least 5 seconds.
- The light should stay constantly on (or in other brands flashining very fast) which means the headset is in receiving/searching state!
3. search in your mobile phone for blue tooth devices(the phone and headset shouldn't be more than 5 meters away from each other )
4. When you find your blue tooth headset, chose it and hit "connect" or "pair" with the device!
5. you will be asked for a pin, put in "0000" and ok!
now your headset should be paired with your phone (the light flashes slowly) and will be ready to receive calls!
Best wishes
Bruce
on Jan 27, 2010 | Cell Phones
Game in china mobile
if ur phone is connected to pc or pc suit or with bluetooth connect to pc with any way ,in WMD_DATA make folder games insert any ".nes" games because java is not supported ,come out of it means disconnect with pc now in ur mobile go to fun and games then game simulator it works.
if not then .nes games r also not supported to ur chona mobile.
i hope it works.
email rushi_jky@yahoo.com
Apr 19, 2010 | Siemens M56 Earbud Hands Free Headset
Why do I hear music coming from my MP4 player when I have the earphones plugged in?
There is a switch inside the player headset female jack that is deactivated by headset the male jack when it is plugged in. The switch deactivates the outside speakers. In your case, the switch is not deactivated so you hear sound from both. Three things may cause the problem that you need to check.
  1. You are using a not compatible headset. Make sure headset used is compatible with the player.
  2. The headset is not properly inserted. Insert the headset firmly and make sure it sits firmly in.
  3. The switch inside the unit is defective. It may be stuck or broken. Disassemble the unit to check the switch. Insert the headset and make a visual check if it hits the said switch and deactivates it. You may need the help of a person with know-how in electronics.
Nov 07, 2009 | Konaki MP4-NS MP3 Player
Need code for g2 earpeice
Pairing the BLUETREK® G2
Before using the BLUETREK® G2 headset, you must pair it with your Bluetooth® mobile
phone. Pairing is the process of linking 2 Bluetooth® devices, so that they can
communicate.
To initiate pairing:
1. Place the BLUETREK® G2 and your mobile phone within 0.3 meter (1 foot) from
each other.
2. Switch on your phone and select its Bluetooth® discover mode (refer to the
Bluetooth® mobile phone user manual).
3. When the BLUETREK® G2 is switched off, press and hold the TALK button for
about 7 seconds until the indicator light flashes red and blue alternatively. And a
sound can be heard in the speaker.
4. Once the mobile phone detects the headset, a “BlueTrek G2” message will be
displayed. Follow the phone instructions to accept the pairing. The PIN code (or
passkey) is 0000, then press “yes” or “ok”.
If pairing success, the indicator light will switch to blue and flashes slowly.
If you haven’t started the discovery mode within 5 minutes, the headset
RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 19, 2009 | BlueTrek G2 Consumer Headset
Cant connect logitech bluetooth to phone,
the logitech head piece buttons must not be working, seems to charge ok but can't get to flash blue?
Aug 07, 2008 | Logitech Mobile Freedom Wireless Headset
Headset icon problem
Hey mayita,
If ur headset icon is not coming when u insert a headphone, it is due to non-supporting headphone or due to damaged headphone connector.
If u headset icon is continuously showing, it is also due to problem in ur headset connector. At this time, contact mobile technician.
Send me a feedback and rate my solution too.
Dont forget to post a clarification request for ur problem after it is solved.
SAJAN(sajwhat@hotmail.com/sajwhat_2003@yahoo.com)
May 12, 2008 | Nokia N73 Cellular Phone
What is the default passcode for the Logitech F-0228A Mobile Freedom headset?
Guest
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
Pair Your Headset
Before using, you must pair your headset.
1. Turn phone on.
2. With Headset off, push Talk/Volume up button for 10 seconds. Blue LED will flash rapidly.
3. Follow pairing instructions in phone-setup or connect menu. Your phone should find “Logitech
HS04VXX”Headset and prompt you for a passkey pin.
4. Enter “0000”.
5. Press OK on phone.
6. From Headset device list press “Logitech HS04VXX” Headset.
7. Select connect.
When your Headset is successfully paired, the blue LED will flash slowly.
Nov 11, 2007 | Logitech Mobile Freedom Wireless Headset
Nokia 6680 wont connect to Bluetrek G2
Just had the same problem.
But I found some bluetrek instructions on the net & it works
communicate.
each other.
Jun 26, 2007 | BlueTrek G2 Consumer Headset
Nokia 7610 Logo
62 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
