Question about Roper RAX4232KQ Top Load Washer
Washer will not start
Own a top loading Roper RAX4232PQ. washer stopped in middle of washing cycle. Tried to change cycles and wil not respond. I hear a buzz like it wants to but nothing happens. How can i drain water? What may be the problem with washer?
  • tbrigh Oct 14, 2008
    very similar problem, the washer filled with water as expected but when time to cycle to wash everythign stopped. There is no buzzing sound and changing the timer settign ahs no result. It is as if there is no power to the washer but have verified I have power
  • 47 Answers
It sounds like the lid switch may be bad or have come loose. Open the lid and there should be a thing on the underside that pokes into the washer when you close it. At the place where it pokes into the washer you should see the top of the lid switch and it should be flush with the washer body. Stick a screwdriver into that hole to push down the switch and it should click. Pull the screwdriver out and it should click again. If it does click then close the lid slowly and listen closely near the switch to see if you still hear the clicking.
If you don't hear the clicking, then you will have to change the lid switch (usually costs about 30-50 dollars) or just bypass it. If you do bypass it, be careful. It will still spin even with the lid open and can be dangerous.
Posted on Dec 08, 2007
Youre the Man.!!!!!
Posted on May 10, 2008
How do I fix washer that will not start after I opened door and manually advance to next cycle?
Unplug the machine and replug it - also remove the washing and go through the process again
Jul 23, 2014 | Roper Washing Machines
What's wrong with washer that won't start again?
Check the door safety switch. Sometimes you can rock the lid left and right and close it back it might clear what's blocking the switch. Make sure you have the washer on.
Dec 20, 2017 | Roper Washing Machines
Washer only works20 seconds then stops
Maybe at 10 years+ of service it is time to stop dumping money into repairs and buy a replacement.
Mar 14, 2017 | Roper Washing Machines
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Washer stopped in first rinse cycle
do you hear a clicking noise when you close the lid if not check your lid switch
Dec 30, 2008 | Roper RAB2121KW Top Load Washer
Roper washer issue
next time it stops raise lid on right side at edge of opening will be a small opening where lid switch is push down switch with pencil or something small enough to fit if it starts working replace switch ..if switch is not at that location may be under hinge left rear if that is the case ck hinge screws
Aug 20, 2008 | Roper RAS8445KQ Top Load Washer
Roper (Whirlpool) Washer
ohm out the lid switch, with the switch closed it should read contunity if it does not then the lid switch is the issue
Apr 19, 2008 | Roper RAB2121KW Top Load Washer
Maytag Atlantis Top Loading Washer stops after wash cycle
Sound like a bad Brake & Drive Tube sorry to hear that it is not easy but you can fix it..
Aug 27, 2007 | Roper RAS8445KQ Top Load Washer
Roper RAX4232KQ Top Load Washer Logo
349 people viewed this question
Top Roper Washing Machines Experts
Marvin
Marvin
Mike
Sal De
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
