Starts to agitate as soon as cover closes, will not spin
Regardless of the cycle chosen, the washer does not fill with water but instead switches directly to the agitation step. After the agitation step the washer cycle is over - it never goes to the spin step.
It almost sounds like the lid switch is working backwards but I have never seen that happen on a GE. The switch either works or goes bad. One other possibility is a defective water level switch. Thats also called a pressure switch sometimes.
I found what seems to be an easy fix thatt solved the problem with my Maytag Centential washer that stated agitating before it filled with water. After opening the control panel and tilting it back, just pull the clear plastic hose that attaches to the cycle and leveling switch. Blow into the hose and you will probably feel water that's caught in the hose blow out the other end. Reattach the hose to the cycle and leveling switch. Now test it by starting a cycle and hopefully it works for you like it did for me. If you know how to open the control panel, this fix takes about 2 to 3 minutes start to finish. I feel bad for those people that have mentioned having repairmen replace parts that may know actually be at fault. I doesn't appear to be a bad switch, but instead a poor design the sometimes doesn't clear water from the hose causing the leveling sensor to think water is in the tub. This has now happened twice in the three years I had this washer. I hope this fix works for you if you too have premature agitation for the MVWC6ESWW1 washer.
I also have a Whirlpool top load Model # WtW57ESVW auto sensing load washer. I have it it almost a year and it has started to do exactly the same as described above. The repairman said today that it needed a "auto load sensing switch" which he has ordered for me.
Note - you can use your washer until the problem is fixed, but you have to make sure you manually stop the spin cycle prior to it just finishing, for that is the time period that the water starts to fill again.
I also noted that my local Lowes store does NOT sell this model anymore - probably too many customer complaints about this exact same problem. As soon as I showed the problem to the repairman this AM, he immediately diagnosed the issue - said that it was a recurring issue with this particular model.
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
