Question about Pioneer DEH-1800 CD Player
Will not turn on
Hi, have connected all of the wires to the car and the stereo but nothing happens, there is no power at all. and ideas as to what this may be?
  • 140 Answers
Maybe you lack ground connection, connect the antenna cable and connect the unit to the chassis of car.
also check the fuses on back of unit and fuse box.
Posted on Dec 05, 2007
I have got a renault clio mk 2 98-01 its got the cassette play that came with the car so iam changing it for a pioneer 1400 when connect it it wont come on but when i plug the old one back in the player...
How are you wiring the Pioneer DEH 1400 to the Renault?
The Pioneer uses standard radio wiring, you must not have power and ground connected properly if you have nothing happening.
Jan 03, 2018 | Pioneer Deh-1400ub Car Stereo Cd Mp3 Wma...
Yes I have a alpine 7995 cd/tuner it has 12volts and a good ground I also checked for power where the faceplate connects and there is 4.89 volts there but no face illumination and nothing happens when...
sir try to check the wirings of your car stereo to the battery. it must have been out of power and better to see a wiring technician for this because they have tools and knowledge to have the wirings back on its place. hope that helps!
thank you for using fixya
CHARCOIS
Oct 25, 2008 | Alpine Car Audio & Video
Wire touched bare metal and now it wont turn on.
did you check the fuse for the stereo? sometimes if the wires touch it will burn out a fuse.
May 11, 2012 | Dual Xr4115 Mechless Digital Media...
No power to car stereo
1) your CB may provide a phantom drain to ground and run down the battery if you do not have means of interupting all power to it when the vehicle is not running and no key in ignition and radio off. It is usually the powerline filter in the CB that does this.
But the car stereo not wanting to work, it is likely the wire termination at the fuse came apart and is no longer making contact to that power wire for the radio. If you cross tap to the CB power wire a few inches from the fuse block, the stereo should work again.
Feb 07, 2012 | Radio Communications
I bought a jvc kd-s27 stereo but am having trouble installing it in my 2004 chevy blazer because of wire differences please help
when i go to connect my power supply nothing happens the jvc will not turn on, but when i connect my old pioneer it works, what is going on?
Mar 04, 2011 | JVC AM FM CD DET FACE CAR STEREO
I recently bought a JVC KD-R311 car stereo, its a great stereo but my settings dont save, for instance i set the perfect sound adjusting bass/treb/mid/loudness and whenever i turn my car back on after...
You need to have the yellow wire from the stereo connected to constant battery/12 volts. That wire supplies power for the memory, if it is connected to ignition power, when you turn off the car, the power for the memory is off also.
May 13, 2010 | JVC AM FM CD DET FACE CAR STEREO
I just hook up an after market cd player up in my 2001 chrysler 300m and the radio play but the cd player want play, it turns on and everything just no sound. do anyone have any ideas of what i did wrong?
DOES THE RADIO PLAY? HERE ARE THE FACTORY WIRING COLORS FOR THE RADIO HARNESS, RECHECK YOUR WORK. IF U FIND NOTHING THEN IF THE RADIO PLAYS THE CD PLAYER IS DEFECTIVE, IT HAPPENS BELIEVE ME.
2001 Chrysler 300M Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis or Strap
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange
Car Stereo Antenna Trigger Wire: Orange/Red
Car Stereo Cell Phone Mute Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: Located under the rear deck in the trunk.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Nov 05, 2009 | 2000 Chrysler 300M
No power to stereo.
use wiring diagram back of stereo. check 12volts supply by multitester dc.
May 30, 2009 | Kenwood KDC-5011 CD Player
Car Stereo will not turn on
Most headunits (cd players) have fuses of their own. If those are are not blown, connect a simple test light to ground and with the ignition on, test your constant (yellow wire) and accessory (red wire) for power. If all fuses are good and you still have no power you can connect your red and yellow wires (whichever shows no power on the test light) directly to your vehicles fuse panel.
Jan 08, 2008 | Sony CDX-F7710 Car Audio Stereo CD MP3...
Popping noise in new stereo install
Does this only happen when you turn the stereo on? If so, it's perfectly normal. It happens when the amplifier in your stereo powers up. It's an older car with "unshielded" wiring that isn't going to be grounded properly. Oh, and to answer your question, yes, the plus (+) and minus (-) are for positive (+) and negative (-) terminals. Make sure that red is on positive and black is on negative. Reversing the polarity (installing the wires backwards) normally won't make the system stop working but it can damage your new speakers.
You also should make sure that you've connected the stereo ground. It will probably be screwed onto the back of the stereo and if there isn't a provided green wire in the bundle coming from the car than you'll just need to find a place to attach it to the car's metal chassis.
Nov 10, 2007 | Car Audio & Video
Pioneer DEH-1800 CD Player Logo
56 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
