Question about Car Audio Receivers
Rover 220 turbo wiring diagram
Hi there can u help me i have a rover 220 turbo cab and the wires are all over the place have u got diagram for engine and cabin u can send me thanks
  • 626 Answers
SOURCE: wiring diagram
Manual is here; Page 23 has the wiring info. Best of Luck.
Posted on Sep 26, 2007
Testimonial: "Thank you very much for your help, job now done."
  • 22 Answers
SOURCE: need wiring diagram
Posted on Jan 11, 2008
SOURCE: wiring harness
This is on the case of the CD-335X
Line Out
gray (rear)- red/ right, white/ left
Red- ign
Yellow- batt B+
Black- ground = neg12 volt
dark blue- power ant
orange- dimmer
gray- right front (+)
gray/ black- right front (-)
White- Left Front (+)
white/ black- Left Front (-)
voilet- Right rear (+)
violet/ black- Right rear (-)
Green- Left Rear (+)
Green/ black- Left rear (-)
use 4 or 8 ohm speakers
Posted on Mar 25, 2008
kenwood dpx-4020
Posted on Jun 04, 2008
  • 1039 Answers
SOURCE: clarion xa311 wiring diagram. not hing about were
You can download it from Clarion website. Look for installation manual.
Posted on Apr 11, 2010
SOURCE: need a wiring diagram please
wiring diagram or colour code for kenwood cd player model kdc-5108
Posted on Sep 20, 2010
0 characters
1 Points
Hi i am trying to fit a panasonic model number cq-c1110an to my 1995 rover metro but the power supply plug is different and the connecting pins do not fit colour coordinated, can you tell me the correct...
I have to say it, so let's get it out of the way; there are many professionals in your area who are capable of doing this for you. Whether it be Car Stuff or a Land Rover dealership, you can expect to have everything put just the way you want. But I have solved this problem myself once...
I have run into this problem on my Nissan Maxima. My solution was a bit extreme and involved quite a bit of butchery. You may decide to do something else. What I did was cut the connector off(to the original stereo) of the cart and spliced the power wires together. Then I turned on the unit and put in my favorite cd, adjusted balance to the front-left and touched wires together to figure out which was the proper speaker wire. Then did the same for front-right, rear-left, and rear-right. After figuring out the proper way to wire it in, I went back and installed ****-end connectors(wire nuts will work, but take up more space) and re-wrapped with electrical tape, making sure there were no wires or metal to ground out. If you do decide to cut the connector from the vehicle, leave enough wire on the connector so it can be reinstalled at a later date, 2-4 inches of room to work with(just in case you need to reinstall original stereo unit).
Think long and hard about if you decide to make this work. It is dangerous to modify a vehicles electrical system due to a RISK OF FIRE . Let me say it again--there are professional automotive audio people in your area who can do this. Check with Best-Buy.
Oct 12, 2010 | Panasonic Car Audio Receivers
I need a wiring diagram for a DEH-P3100
Hi there
You can find the owners manual and wiring diagram HERE
Hope this help Cheers
Apr 22, 2010 | Pioneer DEH-P3100 CD Player
We cant find the power cable in our rover 420 sdi to re-wire a new stereo..the blocks have been cut off the stereo we brought so no clue as to wats wat and no wire diagram on top of stereo
If its a aftermarket stereo, the red wire is ignition, yellow wire is constant 12 volts, & black wire is ground. The speaker wires should be purple + & purple w/ black stripe - / white + & white w/ black stripe - / green + & w/ black stripe - / gray + w/ black stripe - /....then blue is for power antenna. Thats most aftermarket radios, some have orange for a dimmer but it depends on the brand.
Mar 28, 2010 | Pioneer DEH-P6600 CD Player
Stereo wiring diagram 2003 f250 deisel
2003 Ford F250 Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Light Green/Pink
Car Radio Accessory Switched 12v+ Wire: Black/Violet
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Blue
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Light Blue/White
Left Front Speaker Negative Wire (-): Orange/Light Green
Right Front Speaker Positive Wire (+): Dark Green
Right Front Speaker Negative Wire (-): White/Light Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Tan/Yellow
Left Rear Speaker Negative Wire (-): Gray/Light Blue
Right Rear Speaker Positive Wire (+): Brown/Pink
Right Rear Speaker Negative Wire (-): Orange/Red
Nov 17, 2009 | Car Audio Receivers
Need Wiring Diagram For a Clarion DB245
You can download the user manual here, which includes a simple schematic for the wiring color code:
Feb 06, 2009 | Clarion DB245 CD Player
Need a wiring diagram for 1997 chevy s-10 tryin to install radio is the place to go for all free wiring diagrams.
Dec 04, 2008 | Pioneer DEH-P2900MP CD Receiver...
Clarion radio wiring diagram
please help what wire goes where?? need a wiring diagram or manuel to install. clarion xmd1 marine am fm cd player
Mar 18, 2008 | Clarion DB245 CD Player
1998 ford el xr6, need stereo wiring harness colours
You did not specify if you wanted the wiring diagram for the Expedition or the Explorer, so I got you both. Good Luck
1998 Ford Expedition Stereo Wiring
Constant 12V+ White/Purple Switched 12V+ Black/Pink Ground Black/Green Illumination Blue/Black Dimmer n/a Amplifier Remote Blue Antenna Right Front Front Speakers 6" x 8" Doors Left Front (+) Light Blue/White Left Front (-) Orange/Light Green Right Front (+) Dark Green/Orange Right Front (-) White/Light Green Rear Speakers 6" x 8" Rear Doors Left Rear (+) Tan/Yellow Left Rear (-) Gray/Light Blue Right Rear (+) Brown/Pink Right Rear (-) Orange/Red
1998 Ford Explorer Stereo Wiring Constant 12V+ Light Green Switched 12V+ Yellow/Black Ground Black Illumination Light Blue/Red Dimmer n/a Antenna Trigger Orange/Blue Antenna Right Front Front Speakers 5" x 7" Doors Left Front (+) Orange/Light Green Left Front (-) Light Blue/White Right Front (+) Dark Green/Orange Right Front (-) White/Light Green Rear Speakers 5" x 7" Rear Door Left Rear (+) Gray/Light Blue Left Rear (-) Tan/Yellow Right Rear (+) Orange/Red Right Rear (-) Brown/Pink
Feb 22, 2008 | Car Audio Receivers
Car Audio Receivers Logo
931 people viewed this question
Top Car Audio Receivers Experts
xxxxxx xxx
Are you a Car Audio Receiver Expert? Answer questions, earn points and help others
