My PC no longer recognises the device, despite reinstalling the software. "USB" still shows up on the device itself when I plug it in, but the PC does not know it is there. Help!
Please restart your pc and your Digital voice recorder and reboot it your problem will be solved. If the problem continue then install the USB driver to your pc. It will work.
Consider NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
It is very possible the drivers conflict. You should try uninstalling everything to do with the one you don't want. Then install the drivers/software for the 700. Also what software are you using and what version? Thanks, Lee
We have all had it, yesterday it was fine now it says it doesn't recognise ya USB device.. AARrrgg. Well there are various way to try to fix. Now providing your USB aint Kaput then this works like 99 outa a hundered.
Simply Remove and reinstall all USB controllersTo remove and reinstall all USB controllers, follow these steps:
Click Start, click Run, type sysdm.cpl in the Open box, and then click OK.
Click the Hardware tab.
Click the Device Manager button.
Expand Universal Serial Bus controllers.
Right-click every device under the Universal Serial Bus controllers node, and then click Uninstall to remove them one at a time.
Restart the computer, and "Windows" will then automatically reinstall the USB controllers.
Plug in the removable USB storage device, and then test to make sure that the issue is resolved.
Remember with USB devices. FIRST, install software/drivers, then insert USB device SECOND.
First disconnect PC from power cable for 10 minutes (unplug).Disconnect player from USB. reinstall player software. Then connect back player, it should work.
Restart the computer, and then reinstall the USB controllers.
Good day sir, hi, usually its one or two ports that does not recorgnise a usb device, but if all ports does not recognise the usb device, check the CMOS setup. check this out;
one or two ports does not recognise the usb device, this is a local fault, try to check the CMOS setup, this could also be the port itself is the faulty one having loose connection.
all ports does not recognise the usb device, this is a system fault, check again the CMOS setup if the USB port is enabled, check the USB device itself also. to make sure use another pc to test the usb device.
A computer virus can also cause the usb port to malfunction, run an anti virus software, if possible you can reinstall the XP and test the USB port afterward.
If all else fails, you can buy a USB card and plug it on the expansion slot on your PC.
make sure the software is unstalled via control panel, ad and remove programs, make sure there no mention of finepix
now load the software first,
then plus in the camera
check the usb cable as well
on your computer, under device manager, uninstall all USB devices, upon completion right click the top of the tree, click scan for new devices. this will reinstall the usb devices. then plug in your ext hard drive
