Question about ViewSonic VG2230WM LCD Monitor
LCD monitor fault
LCD monitor doen't display anything.
When powered on it briefly displays then blacks out.
(on bootup and when in windows)
Have tried on other systems and its the same.
  • Anonymous Dec 11, 2007
    Same exact problem here, whenever the monitor is plugged in, it turns itself on, has brief display and then shuts off, then turns back on and repeats the process, happens when computer is off and when computer is on
  • Anonymous May 09, 2009
    Same happens, tried reinstalling drivers but now i can only see resolutions up to 1024x768 and can only get highers on "pan desktop" mode (sliding resolution).
    Cant fix it.
  • 11,361 Answers
Asus z92m laptop doen't startup anymore, no bios screen, just green light on for a second, dvd clicks and runs
Did anything happen recently? If you have an external monitor, plug it into the vga port and see if you get a display on bootup. Does the computer stay on or does it shut itself off right away?
Jun 10, 2011 | ASUS Z92M Notebook
When I turn on my monitor, it briefly displays the image, but then turn to black
This usually means the backlight has failed and it is not cost effective to repair. Some monitors with a faulty power supply will exhibit this fault too. If the power supply is external (a little DC "brick") Try and find a replacement with equal voltage and similar (preferrably more) current rating (e.g. 12VDC, 3 Amp). This can be a cheap fix - especially if you have a spare power supply lying around. Often many different monitors can use the same power supply, so if you have another dead one, or know someone with one, you can try that - the connector will even most likely be the same.
Mar 10, 2011 | Hyundai ImageQuest B90A 19" LCD Monitor
When powered on it briefly displays then blacks out. (on bootup and when in windows)
It does that when attached to another PC also?
Otherwise it may have lamps or caps problem as shown here:
http://s807.photobucket.com/albums/yy352/budm/Samsung%20920NW/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Jan 14, 2011 | Samsung SyncMaster 920NW Monitor
When i turn the notebook on i can see nothing blank black screen
Sounds like one of two issues,
1. You have the internal display turned off. When you turn the laptop on you should hear a single beep. Do you see the Sony Logo during bootup? Have you tried to turn the display back on? Try pressing the Fn+F7, or Fn+F8, key combination. There are only three modes and these key combinations allow you to cycle through these modes. Either the Primary Screen is on, or the External Screen is on, or both are on.
2. You may have a bad video card or the screen is dead. When you power up the laptop, can you see a glow, but the screen is black? Can you see the Bootup Screen with the Sony Logo, but barely? Have you tried to connect an external monitor to the laptop to see if the video card is working? If you get video to the external monitor, the video card is working. If you don't, then the video card may be bad. If you are getting video on the external monitor, try using the key combinations listed above and try to cycle through your Internal/External display modes.If nothing shows up on the laptop display then the LCD screen may be bad. It could be the back light. Those are internal to the LCD. That means you will have to replace the entire LCD display on the laptop.
Hope that helps.
Nov 07, 2010 | Sony VAIO GRZ610 Notebook
Display skcrin black but LED not blinking
First, connect this monitor to another computer, if you still do not get a Windows image on the Samsung LCD monitor then it is faulty. The fault could be a faulty inverter board that supplies high voltage to the CCFL lamp or the fault could be a faulty CCFL lamp.
Parts for this monitor could be avaiable from LCD Parts, theie WEB site is :-
www.lcdparts.net
Jun 23, 2010 | Samsung SyncMaster 510N (Silver) 15 inch...
I turn my monitor on and I see the display breifly
hi. it sounds like the power supply has gone bad... try to purchase a new power supply cord..
thank u
rate me
Jul 19, 2009 | ViewSonic VX800 18" Flat Panel LCD Monitor
Display not show
a possible virus must be on your system, the best solution is to reformat the unit & install again your system.
hope this helps
Jul 07, 2009 | Acer Aspire One AOA110-1955 Notebook PC
Switched from crt to lcd, no display!
You need to install the Display driver shipped or downloaded from net.
Mar 31, 2009 | Samsung SyncMaster 171 V 17" Flat Panel...
Monitor displays image for second and displays black again
Your Monitor has a heat sink issue. A capacitor in the monitor is at fault and when it heats it tells the monitor to turn off the display to save the display from damage....Problem Cost to repair will supercede the cost to replace it...Wal-mart 15" monitor 119bucks --17" monitor 129...same at staples office supply (Poof) problem solved.
Mar 21, 2009 | Gateway FPD 1810 18.1" Flat Panel LCD...
ViewSonic VG2230WM LCD Monitor Logo
754 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
